查看: 1627|回复: 9
[已解答] 请教个问题 一直困扰着我
发表于 2013-10-4 14:20:19 | 显示全部楼层 |阅读模式
如题:在一个包括直线 缓和曲线 等多种元素的多义线上从一个已知点开始 取一定的长度 有没有什么小工具?就像线路软件里面标里程桩号那样的
发表于 2013-10-4 17:31:55 | 显示全部楼层
看看这个是否 有用?
(vl-load-com)
(defun c:zhcx ();桩号查询
(prompt "2010-07-27 zo roo  CGGC 武赤公路")
(prompt "*查询线路任意点桩号* << C:zhcx>> *计算中桩坐标*")
(setq old_lay (getvar "clayer"))
(if (=(tblobjname "LAYER" "桩号标注") nil)
        (entmake (list
                    '(0 . "LAYER")
                    '(100 . "AcDbSymbolTableRecord")
                    '(100 . "AcDbLayerTableRecord")
                    '(6 . "CONTINUOUS")
                    '(62 . 3)
                    '(70 . 0)
                    (cons 2 "桩号标注")
(setvar "clayer" "桩号标注")
(setq en  (entsel "\n选择道路中心线: ")
a (getreal "\n请输入起点桩号:")
e   (car en)
pt  (cadr en)
(if (setq len (getreal "\n输入垂线长度(道路半幅宽):")) ;此处要加入非法输入的控制
(setq OBJ (vlax-ename->vla-object (car en)))
(while (setq pt0 (getPoint "\n选择查询点:"))
;画曲线的垂线
(setq Perpt (vlax-curve-getClosestPointTo OBJ pt0 T)
    LST   (vlax-curve-getfirstderiv OBJ (vlax-curve-getparamatpoint OBJ Perpt))
    ANG   (atan (/ (cadr LST) (car LST)))
    pt1   (polar Perpt (+ ANG (* 0.5 pi)) len)
    pt2   (polar Perpt (- ANG (* 0.5 pi)) len)
     ;此处就是你画出来的是水平线的原因,变量换个方向即可
(setq ang2 (angtos (angle pt2 pt1)0 4) )
   (command "pline" pt1 pt2 "")
;计算桩号
  (setq leng (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))
  leng1 (+ a (vlax-curve-getDistAtPoint e Perpt))
  leng2   (- leng leng1)
;计算桩号
(if (< leng1 0.0) (setq fh "-") (setq fh "+"))
(setq nn1 (fix (/ leng1 1000.0 )))
(setq nn2 (abs(- leng1 (* 1000.0 nn1 ))))
     (if  (= nn2 0.0) (setq str_1 (strcat fh "00" )))
     (if  (and (> nn2 0) (< nn2 10.0)) (setq str_1 (strcat (strcat fh "00" ) (rtos nn2 2 3))))
     (if  (and (> nn2 10.0) (< nn2 100.0)) (setq str_1 (strcat (strcat fh "0" ) (rtos nn2 2 3))))
     (if  (>= nn2 100.0)  (setq str_1 (strcat fh (rtos nn2 2 3))))
  (setq str_1 (strcat "K"(rtos nn1 2 0)"+" (rtos nn2 2 3) ))
  (setq pt4 (polar pt1 (+ (* pi 0.45) ang) (* -2 (* 1.65406 0.67))))
  (command "text" "j" "MC" pt4 "0.3" ang2 str_1)
(setq py (rtos (nth 0 pt0)));提取测量坐标系Y值
(setq px (rtos (nth 1 pt0)));提取测量坐标洗X值
(setq pxy (strcat str_1"中桩坐标:X="px",Y="py))
(princ pxy)
发表于 2013-10-5 16:47:29 | 显示全部楼层
好不好楼主发个话啊。。。别让热心凉一边去啊
 楼主| 发表于 2013-10-14 15:41:45 | 显示全部楼层
不好意思哈 出差了几天 才来回复
 楼主| 发表于 2013-10-14 15:43:02 | 显示全部楼层
spp_wall 发表于 2013-10-4 17:31
看看这个是否 有用?
(vl-load-com)
楼主这个是线路上用的 我说的就是一个弯桥这个的 比如我要分跨 从一个已知点过去29.92m这样的 能点取不呢?
 楼主| 发表于 2013-10-14 15:45:11 | 显示全部楼层
我的意思大概就像直线上的offset一样的那样 不过是在曲线上 的offset功能
发表于 2013-10-14 20:52:34 | 显示全部楼层
  1. (defun c:tt (/ i ss s1 pt)
  2.   (setq dist (Udist 7 "" "距离<输入或鼠标直接量取>" dist nil))
  3.   (setq s1 (car (entsel "\n选择曲线: ")))
  4.   (while (setq p1 (getpoint "\n基点<退出>: "))
  5.     (setq pt (vlax-curve-getclosestpointto s1 p1))
  6.     (setq l1   (xyp-Get-LengthAtPoint s1 pt)
  7.           leng (xyp-get-CurveLength s1)
  8.     )
  9.     ;|(if (>= (setq l2 (- l1 dist)) 0)
  10.       (progn
  11.         (setq p1 (xyp-Get-CurvePointAtDist s1 l2))
  12.         (xyp-Cross p1 200 1)
  13.       )
  14.     )|;
  15.     (if        (<= (setq l2 (+ l1 dist)) leng)
  16.       (progn
  17.         (setq p1 (xyp-Get-CurvePointAtDist s1 l2))
  18.         (xyp-Cross p1 200 1)
  19.       )
  20.     )
  21.   )
  22.   (princ)
  23. )
 楼主| 发表于 2013-10-15 10:54:52 | 显示全部楼层
xyp1964 发表于 2013-10-14 20:52
运行提示错误 为什么呢?
emk
需要加载院长的库文件,呵呵  发表于 2013-10-15 20:23
发表于 2013-10-15 22:57:44 | 显示全部楼层
 楼主| 发表于 2013-10-16 13:11:18 | 显示全部楼层
liu_159 发表于 2013-10-15 10:54
运行提示错误 为什么呢?
院长帮我搞定了 谢谢
GMT+8, 2025-5-26 07:50 , Processed in 0.190402 second(s), 27 queries , Gzip On.
