查看: 2644|回复: 5
[经验] 串联多段线的退出问题
发表于 2013-10-6 12:36:59 | 显示全部楼层 |阅读模式
2明经币
;|    已经相连的线串联多段线, 不足的是退不出来,
  现象: ;;选择多段线或 [多条(M)]:   选择多段线或 [多条(M)]: 选择多段线或 [多条(
  要按esc才可以退出, 有什么解决方法?   |;
(defun c:test()
(setq stn ( ssget ) stnl(sslength stn) nn 0 stnnlst nil)
(repeat stnl
    (setq stnn(ssname stn nn) stnnlst(cons stnn stnnlst) )
    (setq nn(1+ nn))
(foreach stnn stnnlst
   ( command "pedit" stnn "" "J" stn"" "" )
( command "" )
最佳答案
查看完整内容
(defun c:qqq(/ b) (setvar "peditaccept" 1) (if (setq b (ssget '((0 . "*LINE,ARC")))) (command "pedit" "m" b "" "j" "0" "" ) ) (setvar "peditaccept" 0) (prin1) )
发表于 2013-10-6 12:37:00 | 显示全部楼层
(defun c:qqq(/ b)
(prin1)
发表于 2013-10-6 15:10:09 | 显示全部楼层
(defun c:test()
(setq stn ( ssget ))
(command "pedit" "M" stn "Y" "J" "" "")
 楼主| 发表于 2013-10-6 18:10:47 | 显示全部楼层
3Q,但是新问题又来了; 错误: 函数被取消
发表于 2013-10-6 22:08:32 | 显示全部楼层
pedit   不支持选择集
发表于 2013-10-7 09:24:29 | 显示全部楼层
defun c:test()
(command "pedit" "M" stn "" "Y" "J" "" "")
GMT+8, 2025-5-26 06:00 , Processed in 0.157054 second(s), 27 queries , Gzip On.
