查看: 4449|回复: 5
[函数] 特殊字符处理(用于文字替换等)
发表于 2013-10-9 14:40:26 | 显示全部楼层 |阅读模式
;;[功能] 特殊字符处理(用于文字替换等)
;;示例(ACET-STR-ESC-WILDCARDS1 "#a@b");"`#a`@b"
;;注:没有安装ET时用,安装ET后用(ACET-STR-ESC-WILDCARDS "#a@b")
;;http://bbs.mjtd.com/forum.php?mo ... d=608841&page=2中定义XD::String:Replace
(defun ACET-STR-ESC-WILDCARDS1 (A / X LST)
  ;;(ACET-STR-REPLACE "B" "2" "ssABCsBs");"ssA2Cs2s"
  (defun ACET-STR-REPLACE1 (o n s)
    (XD::String:Replace (strcat "[" o "]") s n "I")
  (SETQ LST '("#" "@" "." "*" "?" "~" "[" "]" ","))
  (foreach X LST
    (SETQ A (ACET-STR-REPLACE1 X (STRCAT "`" X) A))
  A
本帖被以下淘专辑推荐:
发表于 2013-11-26 22:09:01 | 显示全部楼层
打不开
能否直接贴出XD::String:Replace?
谢谢黄兄
发表于 2013-11-26 22:22:53 | 显示全部楼层
找到了
;; 用正则表达式替换字符 by 梁雄啸.2007.7
(defun XD::String:Replace (pat str nstr key / end)
  (vl-load-com)
  (if (not *xxvbsexp)
    (setq *xxvbsexp (vlax-get-or-create-object "VBScript.RegExp"))
  (vlax-put *xxvbsexp 'Pattern pat)
  (if (not key)(setq key ""))
  (setq key (strcase key))
  (setq keys '(("I"  "IgnoreCase")("G"  "Global")("M"  "Multiline")))
  (mapcar '(lambda(x)
             (if (wcmatch key (strcat "*" (car x) "*"))
               (vlax-put *xxvbsexp (read(cadr x)) 0)
               (vlax-put *xxvbsexp (read(cadr x)) -1)
          keys)
  (vlax-invoke *xxvbsexp 'replace str nstr)
发表于 2018-8-2 13:27:17 | 显示全部楼层
print1985 发表于 2013-11-26 22:22
找到了
(defun XD::String:Replace (pat str nstr key / end) ...
怎么用啊??????
发表于 2018-8-26 03:21:29 | 显示全部楼层
大神牛牛牛牛!
发表于 2019-4-5 21:33:34 | 显示全部楼层
;函数名称:        XD::String:Replace
;调用格式:        (XD::String:Replace old new str)
;参数说明:        old ---- 旧字符串
;new ---- 新字符串
;str --- 字符串
;返回值:        字符串
;函数简介:        字符串替换
;函数来源:        原创
;函数作者:        marting
(defun XD::String:Replace (oldtext newtext textstring / i n)
  (setq n (strlen newtext))
  (while (setq i (vl-string-search oldtext textstring i))
    (setq textstring
                        (vl-string-subst newtext oldtext textstring i)
                        i (+ i n)
  textstring
GMT+8, 2025-12-2 08:18 , Processed in 0.152604 second(s), 29 queries , Gzip On.
