查看: 2112|回复: 1
[基础] 请教DCL问题
发表于 2013-10-22 16:25:07 | 显示全部楼层 |阅读模式
为什么1选择"一线"和"全部"按钮都是调用一线的子程序cc1, cc2如何才能调用呢?2文本框的值无法获取,get_title "kd"没有值。3删除对话框文件貌似无法删除 有谁可知道原因呢。
;加宽拾取的一个片断的线
(defun cc1 ()
  ( setq
           vo  (vlax-ename->vla-object (car(setq et(entsel"选择多段线" ))))
           pt  (cadr et)
           pte (vlax-curve-getclosestpointto vo pt )
           n   (fix ( vlax-curve-getparamatpoint vo pte ) )
  ( vlax-invoke-method vo 'setwidth n (setq wd(getdist)) wd )
;加宽全部的
(defun cc2 ()
  (command "pedit" "m" (ssget) "" "w" (getdist) "")
(defun c:cc ()
  ;建立临时对话框
  (setq tempname (vl-filename-mktemp "d:/temp.dcl") ;返回路径
           filen    (open tempname "w") ;打开文件并覆盖 无文件会自动建文件
           stream
        "cc:dialog{
        \n label =\"多段线加宽\";
        \n :edit_box{label=\"多段线宽度: \";key=\"kd\";width=3;value=\"0.35\";}
        \n :radio_column{key=\"ak\";:radio_button{label=\"加宽拾取的一段\";key =\"1\";}}
        \n :radio_column{key=\"bp\";:radio_button{label=\"加宽全部的\";key =\"2\";}}
        \n  ok_cancel;}
  (write-line stream  filen) ;将字符写入文件
  (close filen) ;关闭文件才能将字符写入
  (setq dclname tempname)
  (setq dcl_re (load_dialog dclname)) ;装入指定对话框文件
  (new_dialog "cc" dcl_re) ;初始化对话框
  ;(if (not(new_dialog "cc" dcl_re))(progn (princ"无对话框")(exit))) ;无对话框定义退出
  (setq std (start_dialog)) ;启动对话框
  ;(setq kd (atof(get_tile "kd"))) ;获得当前值
  (action_tile "ak" (cc1))
  (action_tile "bp" (cc2))
  (action_tile "accept" "(done_dialog 1)") ;终止显示当前对话框
  (action_tile "cancel" "(done_dialog)") ;终止显示当前对话框
  (unload_dialog dcl_re)  ;卸载指定对话框文件
  ;(vl-file-delete dclname)  ;删除对话框文件
  (vl-file-delete dcl_re)
发表于 2013-11-27 19:10:07 | 显示全部楼层
 把这句 ' (setq std (start_dialog)) ;启动对话框' 移到'(unload"_dialog dcl_re)'前面即可。
GMT+8, 2025-5-26 01:42 , Processed in 0.181977 second(s), 28 queries , Gzip On.
