查看: 2521|回复: 10
[基础] 【请教】高手们帮帮忙啊~~~我写的这个lisp哪里有问题啊
发表于 2013-10-24 11:59:14 | 显示全部楼层 |阅读模式
对lisp还不是很熟悉,大家帮帮忙,看看我下面的代码哪些地方有问题啊~~
(defun c:hjht()
  (setq os (getvar "OSMODE"))
  (setvar "CMDECHO" 0)
  (setvar "OSMODE" 0)
  (setvar "OSMODE" os)
  (setvar "CMDECHO" 1)
  (dcl_hangji)
  (prin1)
(defun dcl_hangji()
  (setq dcl_id (load_dialog "C:/3.dcl"))
  (if (< dcl_id 0)(exit))
  (while (= dd 1)
  (if (not (new_dialog "hangji" dcl_id))(exit))
  (set_tile "b_c" "0.0")
  (set_tile "b_k" "0.0")
  (set_tile "tc_a" "0.0")
  (set_tile "bc_a" "0.0")
  (set_tile "bk_a" "0.0")
  (set_tile "tc_b" "0.0")
  (set_tile "bc_b" "0.0")
  (set_tile "bk_b" "0.0")
  (set_tile "tbc_b" "0.0")
  (set_tile "tbk_b" "0.0")
  (set_tile "tbc_c" "0.0")
  (set_tile "tbk_c" "0.0")
  (set_tile "cj" "0.0")
  (set_tile "tuc_a" "航迹名")
  (set_tile "y_s" "10")
  (set_tile "wjm" ".txt")
  (set_tile "dc" user_dc)
  (dc_user user_dc);
  (set_tile "tc_a" user_tca)
  (tca_user user_tca)
  (set_tile "tc_b" user_tcb)
  (tcb_user user_tcb)
  (action_tile "dc" "(dc_user (get_tile \"dc\")) (getdata)")
  (action_tile "tc_a" "(tca_user (get_tile \"tc_a\")) (getdata)")
  (action_tile "tc_b" "(tcb_user (get_tile \"tc_b\")) (getdata)")
  (action_tile "p_b" "(sub_get_file)")
  (action_tile "accept" "(getdata)(done_dialog 1)")
  (action_tile "cancel" "(done_dialog 0)")
   (setq dd(start_dialog))
   (if(= dd 1)
     (ok_hangji)
  (unload_dialog dcl_id)
(defun dc_user (user_dc)
  (if (= user_dc "0")
     (progn ;开关为关闭状态时
(mode_tile "b_c" 1);禁用
     (mode_tile "b_k" 1);禁用
    (progn ;自开关为打开状态时
(mode_tile "b_c" 0);设置
     (mode_tile "b_k" 0);设置
(defun tca_user (user_tca)
  (if (= user_tca "0")
     (progn ;自开关为关闭状态时
(mode_tile "bc_a" 1);禁用
(mode_tile "bk_a" 1);禁用
       (mode_tile "tbc_a" 1);禁用
(mode_tile "tbk_a" 1);禁用
    (progn ;开关为打开状态时
(mode_tile "bc_a" 0);设置
(mode_tile "bk_a" 0);设置
       (mode_tile "tbc_a" 0);设置
(mode_tile "tbk_a" 0);设置
(defun tcb_user (user_tcb)
  (if (= user_tcb "0")
     (progn ;开关为关闭状态时
(mode_tile "bc_b" 1);禁用
(mode_tile "bk_b" 1);禁用
       (mode_tile "tbc_b" 1);禁用
(mode_tile "tbk_b" 1);禁用
       (mode_tile "tbc_c" 1);禁用
(mode_tile "tbk_c" 1);禁用
    (progn ;开关为打开状态时
(mode_tile "bc_b" 0);设置
(mode_tile "bk_b" 0);设置
       (mode_tile "tbc_b" 0);设置
(mode_tile "tbk_b" 0);设置
      (mode_tile "tbc_c" 0);设置
(mode_tile "tbk_c" 0);设置
(defun sub_get_file()
  (setq f (getfiled "选择文件.txt" "" "" 4))
  (set_tile "wjm" (strcat (getvar "txtprefix") (getvar "txtname")))
(defun getdata()
  (setq d (atof (get_tile "cj")))
  (setq tc (get_tile "tuc_a"))
  (setq ys (atof (get_tile "y_s")))
  (setq user_dc(get_tile "dc"))
  (setq user_tca(get_tile "tca"))
  (setq user_tcb(get_tile "tcb"))
  (if (/= user_dc "0")
  (setq cc (atof (get_tile "b_c")))
  (setq ck (atof (get_tile "b_k")))
  (if (/= user_tca "0")
  (setq cc (atof (get_tile "bc_a")))
  (setq ck (atof (get_tile "bk_a")))
  (setq tbca (atof (get_tile "tbc_a")))
  (setq tbka (atof (get_tile "tbk_a")))
  (if (/= user_tcb "0")
  (setq cc (atof (get_tile "bc_b")))
  (setq ck (atof (get_tile "bk_b")))
  (setq tbcb (atof (get_tile "tbc_b")))
  (setq tbkb (atof (get_tile "tbk_b")))
  (setq tbcc (atof (get_tile "tbc_c")))
  (setq tbkc (atof (get_tile "tbk_c")))
(defun ok_hangji()
   (getdata)
   (command "layer" "m" tc "c" ys "" "")
   (setq ff (open f "r"))
   (while(SETQ text0 (READ-LINE ff))
      (setq len (strlen text0))
      (setq n (vl-string-position (ascii ",") text0))
      (setq n0 (vl-string-position (ascii ",") text0 (1+ n)))
      (setq n1 (vl-string-position (ascii ",") text0 (1+ n0)))
      (setq n2 (vl-string-position (ascii ",") text0 (1+ n1)))
      (setq x1 (atof(substr text0 (+ n 2) (- n0 (1+ n))))
            y1 (atof (substr text0 (+ n0 2) (- n1 (1+ n0))))
            x2 (atof(substr text0 (+ n1 2) (- n2 (1+ n1))))
            y2 (atof(substr text0 (+ n2 2))))
     ;(setq dh(atof(substr text0 1 n)) )
     (setq pt1 (list x1 y1))
     (setq pt2 (list x2 y2))
     (setq ang (angle pt1 pt2))
     (setq pt3 (polar pt1 ang d))
     ;(setq pt4(polar pt3 (/ pi 4) 2))
     (setq ang1 (angle pt3 pt1))
     (setq pt5 (polar pt3 ang1 (- cc 15)))
      (setq ang2 (angle pt5 pt3))
      (setq pt6 (polar pt3 (+ (/ pi 2) ang1) (/ ck 2)))
      (setq pt7 (polar pt3 (+ (* pi 1.5) ang1) (/ ck 2)))
      (setq pt8 (polar pt5 (+ (/ pi 2) ang1) (/ ck 2)))
      (setq pt9 (polar pt5 (+ (* pi 1.5) ang1) (/ ck 2)))
      (setq pt10 (polar pt3 ang2 15))
      (setq pt11 (polar pt10 (+ (/ pi 2) ang1) (/ ck 4)))
      (setq pt12 (polar pt10 (+ (* pi 1.5) ang1) (/ ck 4)))
     (command "pline" pt11 pt12 pt7 pt9 pt8 pt6 "C")
      (SETVAR "PLINEWID" 0.5)
    (setq pt13 (polar pt1 (+ (/ pi 2) ang1) (/ ck 2)))
    (setq pt14 (polar pt1 (+ (/ pi 2) ang1) (+ (/ ck 2) (/ tbka 2))))
    (setq pt15 (polar pt1 (+ (/ pi 2) ang1) ck))
    (setq pt16 (polar pt14 ang2 20))
    (setq pt17 (polar pt16 (+ (/ pi 2) ang1) (/ tbka 4)))
    (setq pt18 (polar pt16 (+ (* pi 1.5) ang1) (/ tbka 4)))
    (setq pt19 (polar pt16 ang1 tbca))
    (setq pt20 (polar pt19 (+ (/ pi 2) ang1) (/ tbka 2)))
    (setq pt21 (polar pt19 (+ (* pi 1.5) ang1) (/ tbka 2)))
    (command "pline" pt17 pt18 pt13 pt21 pt20 pt15 "C")
    (setq pt17 (polar pt16 (+ (/ pi 2) ang1) (/ tbkb 4)))
    (setq pt18 (polar pt16 (+ (* pi 1.5) ang1) (/ tbkb 4)))
    (setq pt19 (polar pt16 ang1 tbcb))
    (setq pt20 (polar pt19 (+ (/ pi 2) ang1) (/ tbkb 2)))
    (setq pt21 (polar pt19 (+ (* pi 1.5) ang1) (/ tbkb 2)))
    (setq pt22 (polar pt16 ang2 4))
    (setq pt23 (polar pt22 (+ (/ pi 2) ang1) (/ tbkc 2)))
    (setq pt24 (polar pt22 (+ (* pi 1.5) ang1) (/ tbkc 2)))
    (setq pt25 (polar pt22 ang2 tbcc))
    (setq pt26 (polar pt25 (+ (/ pi 2) ang1) (/ tbkc 4)))
    (setq pt27 (polar pt25 (+ (* pi 1.5) ang1) (/ tbkc 4)))
    (setq pt28 (polar pt16 ang2 (- tbcc 15)))
    (setq pt29 (polar pt28 (+ (/ pi 2) ang1) (/ tbkc 2)))
    (setq pt30 (polar pt28 (+ (* pi 1.5) ang1) (/ tbkc 2)))
    (command "pline" pt16 pt13 pt21 pt20 pt15 "C")
    (command "pline" pt26 pt27 pt30 pt24 pt23 pt29 "C")
    (command "")
  (if ff (close ff))
  (alert "自动生成完毕!")
发表于 2013-10-24 12:13:26 | 显示全部楼层
你现在的问题出在什么地方?
程序较长,看起来很慢,
没看到DCL定义,不好调试
 楼主| 发表于 2013-10-24 12:37:12 | 显示全部楼层
llsheng_73 发表于 2013-10-24 12:13
你现在的问题出在什么地方?
程序较长,看起来很慢,
没看到DCL定义,不好调试
这个是DCL,之前对话框闪一下就消失了,但是后来我修改了一下,结果对话框直接不出来了,还不报错
hangji:dialog{
label="航迹图绘制:";
:row{//第一行开始,该行有两个列
:column{
:row{
:boxed_column{
:toggle{label="单  船";//切换开关
key="dc";
value="0";}
:edit_box{label = "船  长:";//定位点x编辑框
key = "b_c";
edit_width =12;
:edit_box{label = "船  宽:";//定位点y编辑框
key = "b_k";
edit_width =12;
:row{
:boxed_column{
:toggle{label="多船-一拖";//切换开关
key="tc_a";
value="0";}
:boxed_column{
key = "bc_a";
edit_width =12;
key = "bk_a";
edit_width =12;
:boxed_column{
:edit_box{label = "拖船长:";//定位点x编辑框
key = "tbc_a";
edit_width =12;
:edit_box{label = "拖船宽:";//定位点y编辑框
key = "tbk_a";
edit_width =12;
:boxed_column{
:toggle{label="多船-二拖";//切换开关
key="tc_b";
value="0";}
:column{
:boxed_column{
key = "bc_b";
edit_width =12;
key = "bk_b";
edit_width =12;
:column{
:boxed_column{
:edit_box{label = "拖船1长:";//定位点x编辑框
key = "tbc_b";
edit_width =12;
:edit_box{label = "拖船1宽:";//定位点y编辑框
key = "tbk_b";
edit_width =12;}
:column{//第二列开始,该列有两个加框列
:boxed_column{
:edit_box{label = "拖船2长:";//定位点x编辑框
key = "tbc_c";
edit_width =12;
:edit_box{label = "拖船2宽:";//定位点y编辑框
key = "tbk_c";
edit_width =12;
:row{//第二行开始,该行有两个列
:edit_box{label = "测距(米):";
key = "cj";
edit_width =8;
height =1.2;
:edit_box{label = "新图层名:";
key = "tuc_a";
edit_width =8;
height =1.2;
:edit_box{label = "图层颜色值(0~255):";
key = "y_s";
edit_width =8;
height =1.2;
:row{
:popup_list{label="文件名:";
                  key="wjm";
                  value=".txt";
:button{label = "浏  览";//光标拾取按钮
key = "p_b";
width =3;
fixed_width=true;
height =1.5;}
:row{//第三行开始,该行有两个列
spacer_1;
    :button{label= "确定";
            key = "accept";
            width =3;
            is_default=true;
spacer_1;
    :button{label= "取消";
            key = "cancel";
            width =3;
    spacer_1;
发表于 2013-10-24 12:45:47 | 显示全部楼层
也就是说你现在问题是对话框没有按需要出来让你操作?确实是这样的,你在(load_dialog dclfile)之后,运行了
(new_dialog dlgname dcl_id [action [screen-pt]]),这些只是运行对话框的预处理,并不是真正的运行对话框,
要让对话框真正运行起来,得在后边运行(strat_dialog)
你仔细看下我给的例子
(setq dcl(load_dialog "SZGX")ctl 3)
      (while (> ctl 2) (new_dialog "DKSZ" dcl)
(setq ldfz(getvar"USERR2")
       lz(fix(/ ldfz 100))
       lf(fix(/(- ldfz(* lz 100)) 10))
       ld(fix(- ldfz(+(* lz 100)(* lf 10)))))
(set_tile "BMX"(RTOS(getvar"USERR3")2 0))
(set_tile "BMZ"(RTOS(getvar"USERR4")2 0))
(set_tile "BMC"(RTOS(getvar"USERR5")2 0))
(set_tile "LZ"(RTOS lz 2 0))
(set_tile "LF"(RTOS lf 2 0))
(set_tile "LD"(RTOS ld 2 0))
(action_tile "GO" "(getdata)(done_dialog 1)")
(action_tile "ESC" "(done_dialog 0)")
(setq ctl (start_dialog)))
 楼主| 发表于 2013-10-24 12:52:14 | 显示全部楼层
是的,估计lisp代码里面还有一些问题,那个打开文件sub_get_file这里我也不知道对不对~~~可不可以麻烦指导一下啊
发表于 2013-10-24 13:02:01 | 显示全部楼层
jayan1210 发表于 2013-10-24 12:52
是的,估计lisp代码里面还有一些问题,那个打开文件sub_get_file这里我也不知道对不对~~~可不可以麻烦指导 ...
你先看下我在上边给你的例子,让对话框出现让你可以操作了再去调试哪里有没问题吧
 楼主| 发表于 2013-10-24 13:14:18 | 显示全部楼层
我对照你上面给的那个例子修改了下面这段代码,但是对话框还是闪一下就没有了啊~~~~~
(defun dcl_hangji()
  (setq dcl_id (load_dialog "C:/3.dcl") dd 2)
  ;(if (< dcl_id 0)(exit))
  (while (> dd 1)(new_dialog "hangji" dcl_id)
  (dc_user user_dc);
  (tca_user user_tca)
  (tcb_user user_tcb)
   (if(= dd 1)
     (ok_hangji)
  ;(unload_dialog dcl_id)
发表于 2013-10-24 13:55:05 | 显示全部楼层
(defun dcl_hangji ...
   (dc_user user_dc);
   (tca_user user_tca)
   (tcb_user user_tcb)
上边红色标出来的地方都是不行的,好象它们都没有事先定义哦
我把它们都去掉了就出来了。。
 楼主| 发表于 2013-10-24 14:27:05 | 显示全部楼层
   (dc_user user_dc);
非常感谢~~~还想麻烦问一下,要怎么提取我打开文件的文件名呢?在运行的时候会提示错误: 【参数类型错误: stringp nil】,并且我把这个提取文件名的注释掉之后,虽然可以运行,但是点击确定的时候也提示错误【参数类型错误: stringp nil】,这是为什么啊,麻烦啦~
发表于 2013-10-24 14:32:07 | 显示全部楼层
jayan1210 发表于 2013-10-24 14:27
非常感谢~~~还想麻烦问一下,要怎么提取我打开文件的文件名呢?在运行的时候会提示错误: 【参数类型错误: ...
什么文件名?
当前图形文件还是用(Getfiled ) 得到的
GMT+8, 2025-5-26 06:08 , Processed in 0.182497 second(s), 26 queries , Gzip On.
