查看: 3197|回复: 3
[源码] 自己编的直线交叉打断,line线正常,Pline线不正常,请高手指教!
发表于 2013-11-2 05:25:25 | 显示全部楼层 |阅读模式
(vl-load-com)
(setq $tom_dis 3.0 )
;;;获取单选line线、pl线  的选择点,两端点坐标,及线角度值,线类型,并返回列表 子程序
(defun TT-get-ptang (ent1 / x n ok ent0 pt0 pt1 pt2 pt3 pt4 pt5 ang type0 plw1 lay)
;;;pt0 为pl线端点列表 pt1为选择点 pt4为选择点与线的垂足点 pt5为就近2端点列表
(setq pt1 (cadr ent1) pt4 (reverse(cdr(reverse(osnap pt1 "MID")))) )
(setq ent0 (entget (car ent1)))
(setq type0 (cdr (assoc 0 ent0)))
(if (equal type0 "LWPOLYLINE")
  (foreach x ent0
   (if (= (car x) 10) (setq pt0 (cons (cdr x) pt0)) )
  );end foreach由此取得pl线所有端点的倒序列表,需反转
  (setq pt0 (reverse pt0) plw1 (cdr (assoc 41 ent0)) lay (cdr (assoc 8 ent0)) n 0)
  (while  (not ok)
    (setq pt2  (nth n pt0)
   pt3 (nth (1+ n) pt0)
   ang (angle pt2 pt3) ;为弧度值
   n (1+ n)
    (if (or (= ang (angle pt2 pt4)) (= ang (angle pt3 pt4))) (setq ok t pt5 (list pt2 pt3)) )
);progn
);if
(if (equal type0 "LINE")
(setq pt2 (reverse (cdr (reverse (cdr (assoc 10 ent0)))))
pt3 (reverse (cdr (reverse (cdr (assoc 11 ent0)))))
pt5 (list pt2 pt3)
plw1 (getvar "PLINEWID")
);if
(setq ang (angle pt2 pt3));求角度
(setq pt4 (inters pt2 pt3 pt1 (polar pt1 (+ ang (/ pi 2)) 1) nil));取得选择点与线的垂足点
;;;  (if (zerop plw1) (setq plw1 nil) )
  (cons (append (list type0 pt1 pt4 ang lay plw1) pt5) pt0)
);end sub
    ;;交点打断,按线-线选择,打断
    ;;单线打断
    (defun c:c4 (/ loop msg dis  dis1  s1 bl1 ent0
    ent1  ent1_pt1  ent1_pt2
    ent2  ent2_pt1  ent2_pt2  ent2_ang
    ent_bk ent_intpt  ent2_bkpt1   ent2_bkpt2 )
      (acet-error-init (list(list "CMDECHO" 0 "OSNAPCOORD"  2 "OSMODE" 0) t ))
      (setq bl1 (getvar "HPSCALE") dis1 (/ (* $tom_dis bl1) 2) loop nil)
    (while (not loop)
       (setq msg (strcat "[打断长度(" (rtos $tom_dis 2 1) ")<X>]")
      ent0 (clh-entsel (strcat "\n选择打断线" msg ": ") "X" '((0 . "*POLYLINE,LINE")) "\n所选对像不符合要求!请重新选择:")
    (if (not ent0)  (setq loop t))
    (cond
      ((= ent0 "X")
    (if (setq dis (getreal (strcat "\n设置打断长度<" (rtos $tom_dis 2 1) ">:")))
    (setq $tom_dis dis )
    (setq dis1 (/ (* $tom_dis bl1) 2))
    );part1
    ((= (type ent0) 'list)
      (setq s1 (car ent0) ent2 (entget s1))
      (setq ent1 (entget (car (TT-entsel "\n选择参考线: " '((0 . "*POLYLINE,LINE")) ))) )
      (redraw s1 4)
      (if (eq (cdr (assoc 0 ent1)) "LWPOLYLINE")
       (setq ent1_pt1 (cdr (assoc 10 ent1))
       ent1_pt2 (cdr (assoc 10 (reverse ent1))))
      );if
      (if (eq (cdr (assoc 0 ent1)) "LINE")
       (setq ent1_pt1 (reverse (cdr (reverse (cdr (assoc 10 ent1)))))
       ent1_pt2 (reverse (cdr (reverse (cdr (assoc 11 ent1))))))
      );if
      (if (eq (cdr (assoc 0 ent2)) "LWPOLYLINE")
       (setq ent2_pt1 (cdr (assoc 10 ent2))
       ent2_pt2 (cdr (assoc 10 (reverse ent2))))
      );if
      (if (eq (cdr (assoc 0 ent2)) "LINE")
       (setq ent2_pt1 (reverse (cdr (reverse (cdr (assoc 10 ent2)))))
       ent2_pt2 (reverse (cdr (reverse (cdr (assoc 11 ent2))))))
      );if
      (setq ent2_ang (angle ent2_pt1 ent2_pt2))
      (if (setq ent_intpt (inters ent1_pt1 ent1_pt2 ent2_pt1 ent2_pt2))
      (setq ent2_bkpt1 (polar ent_intpt ent2_ang dis1))
      (setq ent2_bkpt2 (polar ent_intpt (+ pi ent2_ang) dis1))
      (setq ent_bk (list s1 ent2_bkpt1))
      (command "break" ent_bk ent2_bkpt2)
       );progn
      );if
    );part2
    );end cond
    );end while
      (acet-error-restore)
      );defun
引用了ET工具的错误处理,自己不会写,呵呵!
 楼主| 发表于 2013-11-2 05:31:30 | 显示全部楼层
基本上都是在论坛里找的源码,自己学着改的,前后有半年了吧!也不知道都是用的谁的源码了,不好意思了!
 楼主| 发表于 2013-11-2 13:17:32 | 显示全部楼层
没有高手指教下。
 楼主| 发表于 2013-11-2 14:41:58 | 显示全部楼层
顶下,不沉底,求高手指教!
GMT+8, 2025-5-26 05:44 , Processed in 0.168046 second(s), 25 queries , Gzip On.
