查看: 9432|回复: 32
[已解答] 如何检查直线是否断开(寻找开口)
发表于 2013-11-26 21:34:14 | 显示全部楼层 |阅读模式
20明经币
效果如图:检查出孤立端点并标记,如果孤立的端点在园内,则不用标记。谁能帮帮忙,不甚感激!
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2013-11-26 21:52:54 | 显示全部楼层
(defun c:tt ( / a c1 ent ent1 i p1 p2 r1 ss sslast x1)
  (setq sslast (ssadd))
  (if (setq ss (ssget '((0 . "LINE"))))
      (setq i -1)
      (repeat (sslength ss)
(setq ent (entget (ssname ss (setq i (1+ i))))
       p1 (cdr (assoc 10 ent))
       p2 (cdr (assoc 11 ent))
       x1 (ssget "C" p1 p2 '((0 . "CIRCLE")))
(if x1
   (if (= (sslength (ssget "C" p1 p1)) 1)
     (foreach a (vl-remove-if 'listp (mapcar
           'cadr
           (ssnamex x1)
       (setq ent1 (entget a)
      c1 (cdr (assoc 10 ent1))
      r1 (cdr (assoc 40 ent1))
       (if (> (distance p1 c1) r1)
    (command "CIRCLE" p1 10)
    (ssadd (entlast) sslast)
(if x1
   (if (= (sslength (ssget "C" p2 p2)) 1)
           'cadr
           (ssnamex x1)
       (if (> (distance p2 c1) r1)
    (command "CIRCLE" p2 10)
  (sssetfirst nil sslast)
发表于 2013-11-26 22:01:56 来自手机 | 显示全部楼层
查悬挂点,,楼主是不是同行哦?
发表于 2013-11-26 22:33:21 | 显示全部楼层
燕秀有这种功能
发表于 2013-11-26 22:42:47 | 显示全部楼层
  1. (defun c:tt ()
  2. (if (setq ss (ssget '((0 . "LINE")))) (progn
  3.   (setq i -1)
  4.   (repeat (sslength ss)
  5.    (setq ent (entget(ssname ss (setq i (1+ i))))
  6.        p1 (cdr(assoc 10 ent))
  7.        p2 (cdr(assoc 11 ent)))
  8.    (if (= (sslength(ssget "C" p1 p1)) 1)
  9.     (command "CIRCLE" p1 10)
  10.    )
  11.    (if (= (sslength(ssget "C" p2 p2)) 1)
  12.     (command "CIRCLE" p2 10)
  13.    )
  14.   )
  15. ))
  16. (princ)
  17. )
哪来的pc点?  发表于 2013-11-27 13:53
低级错误太多:(if (= (sslenth(ssetq "C" p1 p1)) 1) (command "CIRCLE" pc 10) )  发表于 2013-11-27 07:54
发表于 2013-11-26 22:54:00 | 显示全部楼层
ZZXXQQ 发表于 2013-11-26 22:42
no function definition: SSETQ
 楼主| 发表于 2013-11-26 23:12:03 | 显示全部楼层
; 错误: no function definition: SSETQ
 楼主| 发表于 2013-11-26 23:15:48 | 显示全部楼层
Z版主,再帮看看,谢谢!
 楼主| 发表于 2013-11-26 23:17:55 | 显示全部楼层
flyfox1047 发表于 2013-11-26 22:33
燕秀有这种功能
恩,,,,,,,,,,,
发表于 2013-11-26 23:19:13 | 显示全部楼层
改成试试(= (sslength(ssget "C" p1 p1)) 1)
GMT+8, 2025-5-26 01:21 , Processed in 0.216950 second(s), 28 queries , Gzip On.
