查看: 1632|回复: 3
[讨论] 这样的程序如何简化?
发表于 2013-11-29 11:27:01 | 显示全部楼层 |阅读模式
  1. (defun c:ddd ()
  2.   (setq n -1)
  3.   (if (setq ss (ssget '((0 . "LEADER"))))
  4.     (while (setq entname (ssname ss (setq n (+ 1 n))))
  5.       (setq ViewportOnCode ;获得箭头样式
  6.        (Vlax-Get (Vlax-Ename->Vla-Object entname)
  7.            'ArrowheadType
  8.        )
  9.       )
  10.       (if (= 0 ViewportOnCode)
  11.   (progn
  12.     (Vlax-Put-Property
  13.       (Vlax-Ename->Vla-Object entname)
  14.       'ArrowheadType
  15.       3        ;箭头样式
  16.     )
  17.     (Vlax-Put-Property
  18.       (Vlax-Ename->Vla-Object entname)
  19.       'ArrowheadSize
  20.       1        ;箭头的大小
  21.     )
  22.     (Vlax-Put-Property
  23.       (Vlax-Ename->Vla-Object entname)
  24.       'ScaleFactor
  25.       (* 1.5 (getvar "dimscale"))  ;箭头全局比例
  26.     )
  27.   )
  28.   (progn
  29.     (Vlax-Put-Property
  30.       (Vlax-Ename->Vla-Object entname)
  31.       'ArrowheadType
  32.       0        ;箭头样式
  33.     )
  34.     (Vlax-Put-Property
  35.       (Vlax-Ename->Vla-Object entname)
  36.       'ArrowheadSize
  37.       1        ;箭头的大小
  38.     )
  39.     (Vlax-Put-Property
  40.       (Vlax-Ename->Vla-Object entname)
  41.       'ScaleFactor
  42.       (* 4 (getvar "dimscale"))  ;箭头全局比例
  43.     )
  44.   )
  45.       )
  46.     )
  47.   )
  48.   (princ)
  49. )
以上 代码如何简化,谢谢!
发表于 2013-11-29 15:33:21 | 显示全部楼层
  1. (defun c:ddd (/ n ss entname ViewportOnCode obj)
  2.   (setq n -1)
  6.              (Vlax-Get (setq obj (Vlax-Ename->Vla-Object entname))
  7.                        'ArrowheadType
  8.              )
  9.       )
  11.         (progn
  12.           (mapcar 'Vlax-Put-Property
  13.                   (list obj obj obj)
  14.                   (list 'ArrowheadType 'ArrowheadSize 'ScaleFactor)
  15.                   (list 3 1 (* 1.5 (getvar "dimscale")))
  16.           )
  17.         )
  18.         (progn
  19.           (mapcar 'Vlax-Put-Property
  20.                   (list obj obj obj)
  21.                   (list 'ArrowheadType 'ArrowheadSize 'ScaleFactor)
  22.                   (list 0 1 (* 4 (getvar "dimscale")))
  23.           )
  24.         )
  25.       )
  26.     )
  27.   )
  28.   (princ)
  29. )
 楼主| 发表于 2013-11-29 17:11:57 | 显示全部楼层
snddd2000 发表于 2013-11-29 15:33
谢谢前辈。不过觉得好象还是有点啰嗦,但又不知道怎么优化!
发表于 2013-11-29 17:25:15 | 显示全部楼层
  1. (defun c:ddd (/ n ss entname ViewportOnCode obj Tornil)
  2.   (setq n -1)
  5.       (setq obj                   (Vlax-Ename->Vla-Object entname)
  6.             ViewportOnCode (Vla-Get-ArrowheadType
  7.                              (setq obj (Vlax-Ename->Vla-Object entname))
  8.                            )
  9.             Tornil           (equal 0 ViewportOnCode)
  10.       )
  11.       (mapcar 'Vlax-Put-Property
  12.               (list obj obj obj)
  13.               (list 'ArrowheadType 'ArrowheadSize 'ScaleFactor)
  14.               (list (if        Tornil
  15.                       3
  16.                       0
  17.                     )
  18.                     1
  19.                     (* (if Tornil
  20.                          1.5
  21.                          4
  22.                        )
  23.                        (getvar "dimscale")
  24.                     )
  25.               )
  26.       )
  27.     )
  28.   )
  29.   (princ)
  30. )
GMT+8, 2025-5-26 00:36 , Processed in 0.207449 second(s), 29 queries , Gzip On.
