- 积分
- 39308
- 明经币
- 个
- 注册时间
- 2011-5-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
Offset Distance | The user may enter the offset distance at the command line, or onscreen
偏移距离可以在屏幕上指定 | Offset Number | The number of offsets can be increased/decreased using the +/- keys, or alternatively the user may enter the offset number by pressing N
可以通过“-”和"+"号减少或增加偏移的数量,又或者输入N后直接输入偏移的数量 | Offset Factor | The factor of the distance between successive offsets can be altered by pressing F
可以通过“F”键改变连续偏移之间的距离因子 | Offset Settings | Destination Layer/Linetype/LineWeight and Colour can be changed by pressing S
目标图层/线型/线宽和颜色可以按S键来改变 | Offset Mode | Can be changed by pressing Tab, the user has the ability to offset the set of objects to either side, or both sides simultaneously
可以通过按“TAB”键来改变偏移方向和双边偏移 | Object Deletion | The user can retain/delete the original object by pressing D
用户可以按"D"键来保留或删除原来的对象 | Offset to Center | The user can offset to the center of two objects by pressing C
可以偏移到两个对象的中心 按"C"键 | Highlight Offsets | By holding Shift, the user can highlight offset entities (requires Express Tools)
按住Shift键,用户可以突出颜色显示偏移动象(需要ET工具) |
 - (defun c:DynOff (/ ;; --=={ Local Functions }==--
- *error* clean DynOff_Sub txt2num
- ;; --=={ Local Variables }==--
- CODE CPT
- DATA DCFNAME DCTITLE DOC DRFT
- E1 E2 ELST ENTLST ET EXFLAG
- GR
- I IOBJ
- K MSG
- OBJ OBJLST OFF OOBJ OPT OSGRV OSTR
- PROP
- RLST
- SS
- X
- ;; --=={ Global Variables }==--
- ; *dynOff ~ Default Offset Distance
- ; *dynNum ~ Default Offset Number
- ; *dynFac ~ Default Offset Factor
- ; *dynMod ~ Default Offset Mode (bit-coded)
- ; *dynDel ~ Default Delete Option
- ; *DynOffDefaults* ~ Default Dialog Settings
- (setq dcfname "LMAC_DynOff_V2.1.dcl"
- dcTitle "Dynamic Offset V2.1 Settings")
- (or *dynOff (setq *dynOff 10.0))
- (or *dynNum (setq *dynNum 1 ))
- (or *dynFac (setq *dynFac 1.0))
- (or *dynMod (setq *dynMod 2 ))
- (or *dynDel (setq *dynDel nil))
- (or *DynOffDefaults*
- (setq *DynOffDefaults* '("1" "1" 256 256 "*Source*" "*Source*" ;; Layer
- "ByLayer" "ByLayer" ;; Linetype
- "ByLayer" "ByLayer"))) ;; Lineweight
- (setq k -1)
- (mapcar
- (function
- (lambda (value)
- (cond ( (<= 4 (setq k (1+ k)) 5)
- (if (tblsearch "LAYER" value) value "*Source*"))
- ( (<= 6 k 7)
- (if (tblsearch "LTYPE" value) value "ByLayer"))
- (t value)))) *DynOffDefaults*))
- (setq dynMode (nth *dynMod '(1 2 3)))
- ;; --=={ Error Handler }==--
- (defun *error* (err)
- (setq eLst (clean eLst))
- (and doc (vla-EndUndoMark doc))
- (or (wcmatch (strcase err) "*BREAK,*CANCEL*,*EXIT*")
- (princ (strcat "\n** Error: " err " **"))) (redraw) (princ))
- (defun clean (lst / lst)
- (cond (lst (mapcar
- (function
- (lambda (object)
- (if (not (vlax-erased-p object))
- (vla-delete object)))) lst)
- (setq lst nil))))
- (defun DynOff_Sub (obj off / rLst oObj iObj i)
- (if (vl-catch-all-error-p
- (vl-catch-all-apply
- (function
- (lambda ( )
- (if (= 1 (logand 1 dynmode))
- (progn
- (setq i 3 oObj (vlax-invoke obj 'Offset off))
- (if (or (and et (not (acet-sys-shift-down))) (not et)) ;; -- Mod 2.0 --
- (foreach prop '(color layer linetype lineweight)
- (mapcar
- (function
- (lambda (object / val)
- (if (or (vl-position (setq val (nth i *DynOffDefaults*)) '(256 "*Source*"))
- (and (= i 3) (= "1" (cadr *DynOffDefaults*))))
- (vlax-put-property object prop (vlax-get-property obj prop))
- (vlax-put-property object prop (if (< i 9) val (eval (read (strcat "acLnWt" val)))))))) oObj)
- (setq i (+ i 2))))))
- (if (= 2 (logand 2 dynmode))
- (progn
- (setq i 2 iObj (vlax-invoke obj 'Offset (- off)))
- (mapcar
- (function
- (and (= i 2) (= "1" (car *DynOffDefaults*))))
- (vlax-put-property object prop (if (< i 8) val (eval (read (strcat "acLnWt" val)))))))) iObj)
- (setq rLst (append oObj iObj))))))
- (clean (append oObj iObj))
- rLst))
- (defun txt2num (txt)
- (cond ((distof txt 5)) ((distof txt 2)) ((distof txt 1)) ((distof txt 4)) ((distof txt 3))))
- (defun GetOffLen (num fac / result)
- (setq result 0.)
- (while (not (minusp (setq num (1- num))))
- (setq result (+ result (expt fac num))))
- result)
- (setq et (not (vl-catch-all-error-p
- (vl-catch-all-apply (function (lambda nil (acet-sys-shift-down)))))))
- (or et (princ "\nExpress Tools not Loaded - Shift option not Available."))
- (setq doc (vla-get-ActiveDocument
- (vlax-get-acad-object))
- drft (vla-get-drafting
- (vla-get-preferences
- (vlax-get-acad-object)))
- osGrv (osmode-grvecs-lst
- (vla-get-AutoSnapMarkerColor drft)
- (vla-get-AutoSnapMarkerSize drft)))
- (cond ( (not (DC_Write dcfname))
- (princ "\nDCL File could not be Written."))
- (t
- (if (setq ss (ssget "_:L" '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))))
- (progn
- (vla-StartUndoMark doc)
- (setq ObjLst (mapcar 'vlax-ename->vla-object
- (setq EntLst (vl-remove-if 'listp
- (mapcar 'cadr (ssnamex ss))))) oStr "")
- (setq msg '(strcat "\n[TAB] Mode, [+/-] Offset [N]umber, Offset [F]actor"
- "\n[C]enter, [S]ettings"
- (if et ", [SHIFT] Show Offsets" "") ", [D]elete Original = "
- (if *dynDel "Yes" "No")
- "\nSpecify Offset <" (vl-princ-to-string *dynOff) "> : "))
- (princ (eval msg))
- (while
- (progn
- (setq gr (grread 't 15 0) code (car gr) data (cadr gr))
- (redraw)
- (cond ( (and (= 5 code) (listp data))
- (setq EntLst (vl-sort EntLst
- (function
- (lambda (a b)
- (< (distance data (vlax-curve-getClosestPointto a data))
- (distance data (vlax-curve-getClosestPointto b data)))))))
- (setq cPt (vlax-curve-getClosestPointto (car entLst) data)
- off (/ (distance cPt data) (GetOffLen *dynNum *dynFac))) ;; -- Mod 2.0 --
- (grdraw cPt data 3 1)
- (if (and (< 0 (getvar "OSMODE") 16384)
- (setq oPt (vl-remove-if (function null)
- (mapcar
- (function
- (lambda (x / o)
- (if (setq o (osnap data x))
- (list (distance data o) o x data)))) (get_osmode)))))
- (setq oPt (cdar (vl-sort oPt (function (lambda (a b) (< (car a) (car b)))))))
- (setq oPt nil))
- (and oPt (OsMark oPt))
- (foreach obj ObjLst (setq i -1 x 0.)
- (repeat *dynNum
- (setq eLst
- (append eLst (cond ((DynOff_Sub obj
- (* (setq x (+ x (expt *dynFac (setq i (1+ i))))) off))) ((clean eLst)))))))
- (if (and eLst et (acet-sys-shift-down))
- (mapcar
- (function
- (lambda (x) (vla-put-color x acBlue))) eLst)) ;; -- Mod 2.0 --
- t)
- ( (= code 25) nil)
- ( (and (= code 3) (listp data))
- (clean eLst)
- (setq *dynOff off)
- (setq cPt (vlax-curve-getClosestPointto (car entLst) data))
- (mapcar
- (function
- (lambda (x / o)
- (function (lambda (a b) (< (car a) (car b))))))
- data (osnap (caddr oPt) (cadr oPt))
- *dynOff (/ (distance (vlax-curve-getClosestPointto (car entLst) data) data)
- (GetOffLen *dynNum *dynFac))) ;; -- Mod 1.9 --
- (setq oPt nil))
- (repeat *dynNum
- (setq eLst
- (* (setq x (+ x (expt *dynFac (setq i (1+ i))))) *dynoff))) ((clean eLst))))))) nil)
- ( (= code 2)
- (cond ( (or (= 46 data) (< 47 data 58))
- (setq oStr (strcat oStr (chr data)))
- (princ (chr data)))
- ( (vl-position data '(67 99)) (clean eLst)
- (while
- (progn
- (setq e1 (entsel "\nSelect First Object: "))
- (cond ( (vl-consp e1)
- (if (wcmatch (cdr (assoc 0 (entget (car e1)))) "ARC,CIRCLE,ELLIPSE,*LINE")
- (while
- (progn
- (setq e2 (car (entsel "\nSelect Second Object: ")))
- (cond ( (eq 'ENAME (type e2))
- (if (wcmatch (cdr (assoc 0 (entget e2))) "ARC,CIRCLE,ELLIPSE,*LINE")
- (progn
- (setq p1 (vlax-curve-getClosestPointto (car e1) (cadr e1))
- p2 (vlax-curve-getClosestPointto e2 p1))
- (setq *dynOff (/ (distance p1 p2)
- (GetOffLen (1+ *dynNum) *dynFac))) ;; -- Mod 2.0 --
- (repeat *dynNum
- (setq eLst
- (append eLst
- (cond ( (DynOff_Sub obj
- ( (clean eLst)))))))
- (setq exFlag nil))
- (princ "\nInvalid Object Selected.")))
- ( (setq exFlag t) nil))))
- exFlag)
- ( (vl-position data '(43 61))
- (setq *dynNum (1+ *dynNum)))
- ( (vl-position data '(68 100))
- (setq *dynDel (not *dynDel))
- (princ (strcat "\nOriginal Objects "
- (if *dynDel "will" "will not") " be Deleted" (eval msg))))
- ( (vl-position data '(78 110))
- (initget 6)
- (setq *dynNum
- (cond ((getint (strcat "\nSpecify Number of Offsets <" (itoa *dynNum) "> : ")))
- (*dynNum)))
- (princ (eval msg)))
- ( (= data 6)
- (cond ( (< 0 (getvar "OSMODE") 16384)
- (setvar "OSMODE" (+ 16384 (getvar "OSMODE")))
- (princ "\n<Osnap off>"))
- (t (setvar "OSMODE" (- (getvar "OSMODE") 16384))
- (princ "\n<Osnap on>")))
- ( (= data 9)
- (setq dynmode
- (cond ( (= 2 *dynMod)
- (setq *dynMod 0) 1)
- ( (nth (setq *dynMod (1+ *dynMod)) '(1 2 3))))))
- ( (vl-position data '(70 102))
- (initget 6)
- (setq *DynFac
- (cond ((getreal (strcat "\nSpecify Offset Factor <" (vl-princ-to-string *dynFac) "> : ")))
- (*dynFac)))
- ( (vl-position data '(83 115))
- (Off_Settings dcfname (vlax-ename->vla-object (car EntLst)))
- t)
- ( (= data 45)
- (cond ( (= 1 *dynNum)
- (princ (strcat "\nMinimum Offset Number Reached." (eval msg))))
- (t (setq *dynNum (1- *dynNum)))))
- ( (and (< 0 (strlen oStr)) (= data 8))
- (setq oStr (substr oStr 1 (1- (strlen oStr))))
- (princ (vl-list->string '(8 32 8))))
- ( (vl-position data '(13 32))
- (cond ( (zerop (strlen oStr))
- (clean eLst)
- (repeat *dynNum
- (setq eLst
- (append eLst
- ( (clean eLst))))))) nil)
- ( (setq off (txt2num oStr))
- (clean eLst)
- (repeat *dynNum
- (setq eLst
- (append eLst
- (t (princ "\nInvalid Offset Entered.")
- (princ (eval msg)) (setq oStr ""))))
- (t )))
- (t ))))
- (if *dynDel (mapcar (function vla-delete) ObjLst))
- (vla-EndUndoMark doc)))))
- (princ))
- (defun osMark (o / s)
- (setq s (/ (getvar "VIEWSIZE") (cadr (getvar "SCREENSIZE")))
- o (cons (trans (car o) 1 3) (cdr o)))
- (grvecs (cdr (assoc (cadr o) osGrv))
- (list (list s 0. 0. (caar o))
- (list 0. s 0. (cadar o))
- (list 0. 0. s 0.)
- (list 0. 0. 0. 1.))))
- (defun get_osmode nil ; by Evgeniy Elpanov
- (mapcar
- (function cdr)
- (vl-remove-if
- (function (lambda (x) (zerop (logand (getvar "OSMODE") (car x)))))
- '((1 . "_end")
- (2 . "_mid")
- (4 . "_cen")
- (8 . "_nod")
- (16 . "_qua")
- (32 . "_int")
- (64 . "_ins")
- (128 . "_per")
- (256 . "_tan")
- (512 . "_nea")
- (2048 . "_app")))))
- (defun osmode-grvecs-lst (col ass / -ASS ASS COL)
- ; By Evgeniy Elpanov (Modified by Lee Mac)
- (setq -ass (- ass))
- (list (list "_end"
- col (list -ass -ass) (list -ass ass)
- col (list (1- -ass) (1- -ass)) (list (1- -ass) (1+ ass))
- col (list -ass ass) (list ass ass)
- col (list (1- -ass) (1+ ass)) (list (1+ ass) (1+ ass))
- col (list ass ass) (list ass -ass)
- col (list (1+ ass) (1+ ass)) (list (1+ ass) (1- -ass))
- col (list ass -ass) (list -ass -ass)
- col (list (1+ ass) (1- -ass)) (list (1- -ass) (1- -ass)))
- (list "_mid"
- col (list -ass -ass) (list 0. ass)
- col (list (1- -ass) (1- -ass)) (list 0. (1+ ass))
- col (list 0. ass) (list ass -ass)
- col (list 0. (1+ ass)) (list (1+ ass) (1- -ass))
- (list "_cen"
- 7 (list (* -ass 0.2) 0.) (list (* ass 0.2) 0.)
- 7 (list 0. (* -ass 0.2)) (list 0. (* ass 0.2))
- col (list -ass 0.) (list (* -ass 0.86) (* ass 0.5))
- col (list (* -ass 0.86) (* ass 0.5)) (list (* -ass 0.5) (* ass 0.86))
- col (list (* -ass 0.5) (* ass 0.86)) (list 0. ass)
- col (list 0. ass) (list (* ass 0.5) (* ass 0.86))
- col (list (* ass 0.5) (* ass 0.86)) (list (* ass 0.86) (* ass 0.5))
- col (list (* ass 0.86) (* ass 0.5)) (list ass 0.)
- col (list ass 0.) (list (* ass 0.86) (* -ass 0.5))
- col (list (* ass 0.86) (* -ass 0.5)) (list (* ass 0.5) (* -ass 0.86))
- col (list (* ass 0.5) (* -ass 0.86)) (list 0. -ass)
- col (list 0. -ass)(list (* -ass 0.5) (* -ass 0.86))
- col (list (* -ass 0.5) (* -ass 0.86)) (list (* -ass 0.86) (* -ass 0.5))
- col (list (* -ass 0.86) (* -ass 0.5)) (list -ass 0.))
- (list "_nod"
- col (list -ass -ass) (list ass ass)
- col (list -ass ass) (list ass -ass)
- (list "_qua"
- col (list 0. -ass) (list -ass 0.)
- col (list 0. (1- -ass)) (list (1- -ass) 0.)
- col (list -ass 0.) (list 0. ass)
- col (list (1- -ass) 0.) (list 0. (1+ ass))
- col (list 0. ass) (list ass 0.)
- col (list 0. (1+ ass)) (list (1+ ass) 0.)
- col (list ass 0.) (list 0. -ass)
- col (list (1+ ass) 0.) (list 0. (1- -ass)))
- (list "_int"
- col (list -ass (1+ -ass)) (list ass (1+ ass))
- col (list (1+ -ass) -ass) (list (1+ ass) ass)
- col (list -ass (1+ ass)) (list ass (1+ -ass))
- col (list (1+ -ass) ass) (list (1+ ass) -ass))
- (list "_ins"
- col (list (* -ass 0.1) (* -ass 0.1)) (list -ass (* -ass 0.1))
- col (list -ass (* -ass 0.1)) (list -ass ass)
- col (list -ass ass) (list (* ass 0.1) ass)
- col (list (* ass 0.1) ass) (list (* ass 0.1) (* ass 0.1))
- col (list (* ass 0.1) (* ass 0.1)) (list ass (* ass 0.1))
- col (list ass (* ass 0.1)) (list ass -ass)
- col (list ass -ass) (list (* -ass 0.1) -ass)
- col (list (* -ass 0.1) -ass) (list (* -ass 0.1) (* -ass 0.1))
- col (list (1- (* -ass 0.1)) (1- (* -ass 0.1))) (list (1- -ass) (1- (* -ass 0.1)))
- col (list (1- -ass) (1- (* -ass 0.1))) (list (1- -ass) (1+ ass))
- col (list (1- -ass) (1+ ass)) (list (1+ (* ass 0.1)) (1+ ass))
- col (list (1+ (* ass 0.1)) (1+ ass)) (list (1+ (* ass 0.1)) (1+ (* ass 0.1)))
- col (list (1+ (* ass 0.1)) (1+ (* ass 0.1))) (list (1+ ass) (1+ (* ass 0.1)))
- col (list (1+ ass) (1+ (* ass 0.1))) (list (1+ ass) (1- -ass))
- col (list (1+ ass) (1- -ass)) (list (1- (* -ass 0.1)) (1- -ass))
- col (list (1- (* -ass 0.1)) (1- -ass)) (list (1- (* -ass 0.1)) (1- (* -ass 0.1))))
- (list "_tan"
- col (list (* -ass 0.5)(* -ass 0.86)) (list (* -ass 0.86) (* -ass 0.5))
- col (list (* -ass 0.86)(* -ass 0.5)) (list -ass 0.))
- (list "_per"
- col (list -ass 0.) (list 0. 0.)
- col (list -ass -1.) (list 0. -1.)
- col (list 0. 0.) (list 0. -ass)
- col (list -1. 0.) (list -1. -ass))
- (list "_nea"
- (list "_app"
- col (list ass -ass) (list -ass ass)
- col (list (1+ ass) (1- -ass)) (list (1- -ass) (1- -ass)))))
- ;; ----=={ DCL Section }==----
- (defun Off_Settings (fname obj / mklst img layCol mk_arc lays dcTag lLay lLin bsCol bsflag)
- (mapcar 'set '(*dyniCols *dynoCols *dyniCol *dynoCol *dynilay
- *dynolay *dynilin *dynolin *dyniwgt *dynowgt) *DynOffDefaults*)
- (defun mklst (key lst)
- (start_list key) (mapcar 'add_list lst) (end_list))
- (defun img (key col)
- (start_image key)
- (fill_image 0 0 (dimx_tile key) (dimy_tile key) col)
- (end_image))
- (setq doc (cond (doc) ((vla-get-ActiveDocument
- (vlax-get-acad-object))))
- lays (vla-get-layers doc))
- (defun layCol (lay)
- (vla-get-color (vla-item lays lay)))
- (setq bsCol
- (cond ( (vl-position (setq bsCol (vla-get-Color obj)) '(256 0))
- (setq bsflag t)
- (layCol (vla-get-Layer obj)))
- (bsCol)))
- (defun mk_arc nil
- (vec_arc (if (= "1" *dyniCols)
- (if bsFlag
- (laycol
- (if (eq "*Source*" *dynilay)
- (vla-get-layer obj) *dynilay)) bsCol)
- (if (= 256 *dyniCol)
- (if (eq "*Source*" *dynilay) bsCol
- (laycol *dynilay))
- *dyniCol))
- bsCol
- (if (= "1" *dynoCols)
- (if bsFlag
- (laycol
- (if (eq "*Source*" *dynolay)
- (vla-get-layer obj) *dynolay)) bsCol)
- (if (= 256 *dynoCol)
- (if (eq "*Source*" *dynolay) bsCol
- (laycol *dynolay))
- *dynoCol))))
- (cond ( (<= (setq dcTag (load_dialog fname)) 0)
- (princ "\nDialog File not Found."))
- ( (not (new_dialog "dsett" dcTag))
- (princ "\nSettings Dialog could not be Loaded."))
- (t
- (vlax-for lay (vla-get-layers doc)
- (setq lLay (cons (vla-get-Name lay) lLay)))
- (setq lLay (cons "*Source*" (acad_strlsort lLay)))
- (vlax-for lin (vla-get-linetypes doc)
- (setq lLin (cons (vla-get-Name lin) lLin)))
- (setq lLin (append '("*Source*" "ByLayer") (acad_strlsort (cddr (reverse lLin)))))
- (setq lWgt '("*Source*" "ByLayer"
- "000" "005" "009" "013" "015" "018" "020" "025" "030"
- "035" "040" "050" "053" "060" "070" "080" "090" "100"
- "106" "120" "140" "158" "200" "211"))
- (mapcar 'mklst '("ilay" "olay" "ilin" "olin" "olw" "ilw")
- (list lLay lLay lLin lLin lWgt lWgt))
- (mapcar 'set_tile '("ilay" "olay" "ilin" "olin" "ilw" "olw")
- (mapcar 'itoa
- (mapcar 'vl-position
- (list *dyniLay *dynoLay *dyniLin *dynoLin *dyniWgt *dynoWgt)
- (list lLay lLay lLin lLin lWgt lWgt))))
- (set_tile "icols" *dyniCols)
- (set_tile "ocols" *dynoCols)
- (set_tile "dtitle" dcTitle)
- (mode_tile "icol" (atoi (get_tile "icols")))
- (mode_tile "ocol" (atoi (get_tile "ocols")))
- (logo)
- (mk_arc)
- (mapcar 'img '("icol" "ocol") (list *dyniCol *dynoCol))
- (action_tile "ilay"
- (vl-prin1-to-string
- (quote
- (progn
- (setq *dynilay (nth (atoi $value) lLay)) (mk_arc)))))
- (action_tile "olay"
- (quote
- (progn
- (setq *dynolay (nth (atoi $value) lLay)) (mk_arc)))))
- (action_tile "ilin"
- (quote
- (progn
- (setq *dyniLin (nth (atoi $value) lLin))))))
- (action_tile "olin"
- (quote
- (progn
- (setq *dynoLin (nth (atoi $value) lLin))))))
- (action_tile "ilw"
- (quote
- (progn
- (setq *dyniWgt (nth (atoi $value) lWgt))))))
- (action_tile "olw"
- (quote
- (progn
- (setq *dynoWgt (nth (atoi $value) lWgt))))))
- (action_tile "icol"
- (quote
- (progn
- (setq *dyniCol (cond ((acad_colordlg *dyniCol)) (*dyniCol)))
- (img "icol" *dyniCol)
- (mk_arc)))))
- (action_tile "ocol"
- (quote
- (progn
- (setq *dynoCol (cond ((acad_colordlg *dynoCol)) (*dynoCol)))
- (img "ocol" *dynoCol)
- (mk_arc)))))
- (action_tile "icols"
- (quote
- (progn
- (mode_tile "icol" (atoi (setq *dyniCols $value)))
- (mk_arc)))))
- (action_tile "ocols"
- (quote
- (progn
- (mode_tile "ocol" (atoi (setq *dynoCols $value)))
- (mk_arc)))))
- (action_tile "accept"
- (quote
- (progn
- (list *dyniCols *dynoCols *dyniCol *dynoCol *dynilay
- *dynolay *dynilin *dynolin *dyniwgt *dynowgt))
- (done_dialog)))))
- (action_tile "cancel" "(done_dialog)")
- (start_dialog)
- (unload_dialog dcTag))))
- (defun DC_Write (fname / wPath ofile)
- (if (not (findfile fname))
- (if (setq wPath (findfile "ACAD.PAT"))
- (progn
- (setq wPath (vl-filename-directory wPath))
- (or (eq "\\" (substr wPath (strlen wPath)))
- (setq wPath (strcat wPath "\\")))
- (setq ofile (open (strcat wPath fname) "w"))
- (foreach str
- "//-------------------=={ Dynamic Offset }==-------------------//"
- "// DynOff.dcl for use in conjunction with DynOff.lsp //"
- "// Author: Lee Mac, Copyright ?2009 - www.lee-mac.com //"
- "// Sub-Assembly Definitions"
- "pop : popup_list { fixed_width = false; alignment = centered; }"
- "col : image_button { alignment = centered; height = 1.5; width = 4.0;"
- " fixed_width = true; fixed_height = true; color = 2; }"
- "// Main Dialog"
- "dsett : dialog { key = \"dtitle\";"
- " spacer;"
- " : row {"
- " : boxed_column { label = \"Offset Preview\"; fixed_width = false; "
- " : boxed_row { label = \"Outer Colour\"; fixed_width = true;"
- " alignment = centered;"
- " spacer;"
- " : col { key = \"ocol\"; }"
- " spacer;"
- " : toggle { key = \"ocols\"; label = \"Source\"; }"
- " spacer;"
- " } // boxed_row"
- " : image { key = \"dimage\"; alignment = centered;"
- " width = 24.64 ; fixed_width = true;"
- " height = 11.39; fixed_height = true; color = -2; }"
- " : boxed_row { label = \"Inner Colour\"; fixed_width = true;"
- " spacer;"
- " : col { key = \"icol\"; }"
- " spacer;"
- " : toggle { key = \"icols\"; label = \"Source\"; }"
- " spacer;"
- " } // boxed_row"
- " } // column"
- " : column { "
- " : boxed_column { label = \"Outer Offset\";"
- " : pop { label = \"Layer:\"; key = \"olay\"; }"
- " : pop { label = \"Linetype:\"; key = \"olin\"; }"
- " : pop { label = \"Lineweight:\"; key = \"olw\" ; }"
- " spacer;"
- " } // boxed_column"
- " spacer;"
- " : boxed_column { label = \"Inner Offset\";"
- " : pop { label = \"Layer:\"; key = \"ilay\"; }"
- " : pop { label = \"Linetype:\"; key = \"ilin\"; }"
- " : pop { label = \"Lineweight:\"; key = \"ilw\" ; }"
- " spacer;"
- " } // column"
- " } // row"
- " spacer;"
- " : row {"
- " : spacer { width = 19.33; height = 3.18; }"
- " ok_cancel;"
- " spacer;"
- " : image { key = \"logo\" ; alignment = centered;"
- " width = 19.33; fixed_width = true;"
- " height = 3.18; fixed_height = true; color = -15; }"
- " } // row"
- "} // dialog"
- "// End of File //"
- (write-line str ofile))
- (close ofile)
- t)
- nil)
- t))
- (defun logo nil
- (start_image "logo")
- (mapcar 'vector_image
- '(24 21 19 18 17 16 15 14 1 1 0 0 17 8 0 0 1 1 1 1 8 8 7 7 7 7 7 7 33 33 35
- 37 38 39 41 48 47 46 46 54 52 51 50 49 41 42 43 44 45 46 46 47 47 48 48 48
- 48 48 49 49 49 49 48 48 48 47 47 44 46 47 48 49 49 50 50 51 52 52 53 53 53
- 53 53 53 53 52 52 52 52 51 51 51 51 52 54 54 55 56 58 59 60 62 70 70 68 67
- 65 64 62 61 59 58 57 55 64 63 63 63 63 62 61 71 70 69 69 69 69 69 68 69 69
- 69 47 26 27 28 28 28 28 28 27 27 26 25 36 34 33 33 33 46 46 47 77 77 77 76
- 75 74 73 73 73 72 72 72 72 72 72 72 72 73 73 74 75 79 76 76 76 75 75 75 75
- 75 76 76 76 77 77 78 78 79 80 81 83 84 85 86 93 76 77 87 87 81 80 88 88 88
- 88 86 86 94 93 92 92 92 92 92 92 93 113 113 112 111 109 108 107 105 109 111
- 112 113 113 113 96 94 93 93 93 93 93 94 95 96 97 98 99 101 102 104 105 107
- 108 104 103 101 100 100 99 99 98 98 98 98 98 99 100 102 103 104 101 99 98
- 96 94 105 107 108 109 110 112 113 114 114 114 112 111 110 108 107 105 103 102)
- '(16 18 19 20 21 21 21 21 22 23 23 24 24 0 0 0 1 2 3 21 21 21 20 19 18 1 1 0 1
- 1 2 2 3 4 5 5 4 3 3 1 1 2 3 4 5 6 7 9 10 12 12 13 15 16 18 19 21 23 25 25 27
- 28 30 31 33 34 35 40 38 37 36 34 34 33 31 30 28 28 26 25 23 21 21 19 18 16 15
- 14 13 11 10 10 9 8 7 6 5 4 3 3 2 2 0 0 0 0 0 0 0 0 0 0 0 0 1 20 21 22 22 23
- 24 24 23 23 22 21 20 4 3 2 2 0 0 0 1 2 2 4 4 20 21 23 23 24 24 23 22 21 20 1
- 1 0 4 5 6 7 8 9 11 12 13 15 16 18 20 20 22 23 25 26 27 29 30 34 30 29 27 26
- 24 22 21 19 18 16 15 13 12 12 10 9 8 7 6 5 4 4 3 3 3 4 10 10 12 12 19 19 20
- 21 22 22 21 21 20 19 6 6 5 3 13 14 15 16 17 18 19 19 20 19 18 17 15 14 5 9 11
- 12 14 14 16 17 18 19 20 21 21 22 22 22 22 21 21 20 19 19 18 18 17 16 14 12 11
- 10 8 7 6 6 5 5 3 3 3 3 3 5 5 6 6 6 7 7 7 7 6 5 4 4 3 3 3 3 3)
- '(21 19 18 17 16 15 14 8 1 0 0 17 24 0 0 1 1 1 1 1 8 7 7 7 7 7 7 8 33 35 37 38
- 39 41 41 47 46 46 46 52 51 50 49 48 42 43 44 45 46 46 47 47 48 48 48 48 48 49
- 49 49 49 48 48 48 47 47 44 46 47 48 49 49 50 50 51 52 52 53 53 53 53 53 53 53
- 52 52 52 52 51 51 51 51 52 54 54 55 56 58 59 60 62 64 70 68 67 65 64 62 61 59
- 58 57 55 54 63 63 63 63 62 61 71 70 69 69 69 69 69 68 69 69 69 70 26 27 28 28
- 28 28 28 27 27 26 25 36 34 33 33 33 33 46 47 47 77 77 76 75 74 73 73 73 72 72
- 72 72 72 72 72 72 73 73 74 75 79 76 76 76 75 75 75 75 75 76 76 76 77 77 78 78
- 79 80 81 83 84 85 86 87 76 77 77 87 81 80 88 88 88 88 86 86 94 93 92 92 92 92
- 92 92 93 93 113 112 111 109 108 107 105 104 111 112 113 113 113 113 94 93 93
- 93 93 93 94 95 96 97 98 99 101 102 104 105 107 108 109 103 101 100 100 99 99
- 98 98 98 98 98 99 100 102 103 104 105 99 98 96 94 96 107 108 109 110 112 113
- 114 114 114 112 111 110 108 107 105 103 102 101)
- '(18 19 20 21 21 21 21 21 23 23 24 24 16 0 0 1 2 3 21 22 21 20 19 18 1 1 0 0 1 2
- 2 3 4 5 5 4 3 3 1 1 2 3 4 5 6 7 9 10 12 12 13 15 16 18 19 21 23 25 25 27 28 30
- 31 33 34 35 40 38 37 36 34 34 33 31 30 28 28 26 25 23 21 21 19 18 16 15 14 13
- 11 10 10 9 8 7 6 5 4 3 3 2 2 1 0 0 0 0 0 0 0 0 0 0 0 1 20 21 22 22 23 24 24 23
- 23 22 21 20 4 3 2 2 0 0 0 1 2 2 4 4 20 21 23 23 24 24 23 22 21 20 1 1 0 0 5 6 7
- 8 9 11 12 13 15 16 18 20 20 22 23 25 26 27 29 30 34 30 29 27 26 24 22 21 19 18
- 16 15 13 12 12 10 9 8 7 6 5 4 4 4 3 3 4 10 10 12 12 19 19 20 21 22 22 21 21 20
- 19 6 6 5 3 3 14 15 16 17 18 19 19 20 19 18 17 15 14 13 9 11 12 14 14 16 17 18 19
- 20 21 21 22 22 22 22 21 21 20 19 19 18 18 17 16 14 12 11 10 8 7 6 6 5 5 5 3 3 3
- 3 5 5 6 6 6 7 7 7 7 6 5 4 4 3 3 3 3 3 3)
- '(14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14
- 14 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166
- 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166 166
- 166 166 166 166))
- (end_image))
- (defun vec_arc (iCol bCol oCol)
- (start_image "dimage")
- '(0 48 48 48 48 47 46 45 44 43 42 40 39 37 35 33 31 29 26 24 21 19 16 14 11 8 5 2)
- '(0 146 143 141 138 135 132 130 127 124 122 119 117 115 113 111 109 107 105 104 103 101 100 99 99 98 98 97)
- '(0 48 48 48 47 46 45 44 43 42 40 39 37 35 33 31 29 26 24 21 19 16 14 11 8 5 2 0)
- '(0 143 141 138 135 132 130 127 124 122 119 117 115 113 111 109 107 105 104 103 101 100 99 99 98 98 97 97)
- (list iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol
- iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol iCol))
- '(0 42 39 35 32 28 25 21 18 14 10 7 3 42 39 35 32 28 25 21 18 14 10 7 3 71 69 66 63
- 60 58 55 52 48 45 71 69 66 63 60 58 55 52 48 45 93 92 90 89 88 86 84 82 80 78 76
- 74 93 92 90 89 88 86 84 82 80 78 76 74 97 97 97 97 96 96 95 94 97 97 97 97 96 96 95 94)
- '(0 58 57 55 54 53 52 51 50 50 49 49 49 58 57 55 54 53 52 51 50 50 49 49 49 80 77 75
- 72 70 68 65 63 62 60 80 77 75 72 70 68 65 63 62 60 117 114 111 107 104 101 97 94 91
- 88 85 82 117 114 111 107 104 101 97 94 91 88 85 82 146 143 139 135 132 128 125 121
- 146 143 139 135 132 128 125 121)
- '(0 39 35 32 28 25 21 18 14 10 7 3 0 39 35 32 28 25 21 18 14 10 7 3 0 69 66 63 60 58
- 55 52 48 45 42 69 66 63 60 58 55 52 48 45 42 92 90 89 88 86 84 82 80 78 76 74 71 92
- 90 89 88 86 84 82 80 78 76 74 71 97 97 97 96 96 95 94 93 97 97 97 96 96 95 94 93)
- '(0 57 55 54 53 52 51 50 50 49 49 49 48 57 55 54 53 52 51 50 50 49 49 49 48 77 75 72
- 70 68 65 63 62 60 58 77 75 72 70 68 65 63 62 60 58 114 111 107 104 101 97 94 91 88
- 85 82 80 114 111 107 104 101 97 94 91 88 85 82 80 143 139 135 132 128 125 121 117 143
- 139 135 132 128 125 121 117)
- (list bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol
- bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol bCol
- bCol bCol bCol bCol bCol))
- '(56 51 47 43 39 35 30 26 22 17 13 8 4 0 106 103 100 97 93 90 86 83 79 75 72 68 64 60
- 146 146 146 146 145 144 144 143 142 141 139 138 137 135 133 131 129 127 125 123 120
- 118 115 112 109)
- '(11 9 8 6 5 4 3 2 1 1 0 0 0 0 46 42 39 36 34 31 28 25 23 21 18 16 14 12 146 142 137 133
- 129 124 120 115 111 107 103 98 94 90 86 82 78 74 70 67 63 59 56 52 49)
- '(51 47 43 39 35 30 26 22 17 13 8 4 0 0 103 100 97 93 90 86 83 79 75 72 68 64 60 56 146
- 146 146 145 144 144 143 142 141 139 138 137 135 133 131 129 127 125 123 120 118 115 112 109 106)
- '(9 8 6 5 4 3 2 1 1 0 0 0 0 0 42 39 36 34 31 28 25 23 21 18 16 14 12 11 142 137 133 129
- 124 120 115 111 107 103 98 94 90 86 82 78 74 70 67 63 59 56 52 49 46)
- (list oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol
- oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol oCol
- oCol oCol oCol oCol oCol))
- (end_image))
- (vl-load-com)
- (princ "\n:: DynOff.lsp | Version 2.1 | ?Lee Mac 2009 www.lee-mac.com ::")
- (princ "\n:: Type \"DynOff\" to Invoke ::")
- (princ)
