查看: 2110|回复: 7
[源码] 查斜线程序的缺陷改进
发表于 2013-12-9 08:26:21 | 显示全部楼层 |阅读模式
2明经币
画图时稍不当心会把正交线画得稍微斜一点点,肉眼看不清楚,标注尺寸时会发觉出现小数点,下面的程序可以查斜线,但有部分正交线也被当成斜线打成红色,请高手帮忙再改进,附件是测试用图纸。
(defun c:bias()
   (setq ss_first (ssget "X" '((0 . "line"))))
   (setq n 0)
   (setq ss_kill (ssadd))
   (while (< n (sslength ss_first))
      (setq en (ssname ss_first n))
      (setq en_data (entget en))
      (setq pt_st (cdr (assoc 10 en_data)))
      (setq pt_en (cdr (assoc 11 en_data)))
      (setq ang (/ (* 180 (angle pt_st pt_en)) pi))
    (if (and (/= ang 0) (equal ang 0 0.3))
       (ssadd en ss_kill)
    (if (and (/= ang 90) (equal ang 90 0.3))
       (ssadd en ss_kill)
     (if (and (/= ang 180) (equal ang 180 0.3))
       (ssadd en ss_kill)
    (if (and (/= ang 270) (equal ang 270 0.3))
       (ssadd en ss_kill)
     (if (and (/= ang 360) (equal ang 360 0.3))
       (ssadd en ss_kill)
      (setq n (1+ n))
   (if ss_kill
      (command "_.chprop" ss_kill "" "c" 1 "")
      (princ (strcat "\n------------- 有\t" (itoa (sslength ss_kill)) "  条斜线。"))
     (princ "\n没有斜线!")
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2013-12-9 09:18:09 | 显示全部楼层
  1. (defun c:bias()
  2.    (setq ss_first (ssget "X" '((0 . "line"))))
  3.    (setq n 0)
  4.    (setq ss_kill (ssadd))
  5. (while (< n (sslength ss_first))
  6.       (setq en (ssname ss_first n))
  7.       (setq en_data (entget en))
  8.       (setq pt_st (cdr (assoc 10 en_data)))
  9.       (setq x1 (car pt_st) y1 (cadr pt_st))
  10.       (setq pt_en (cdr (assoc 11 en_data)))
  11.       (setq x2 (car pt_en) y2 (cadr pt_en))
  12. (if
  13. (or (= "0" (rtos (- y2 y1)) ) (= "0" (rtos (- x2 x1)) ) )
  14. (setq n (1+ n))
  15. (progn (ssadd en ss_kill)(setq n (1+ n))
  16. ))
  17. )
  18.    (if (/= 0 (sslength ss_kill))
  19.     (progn
  20.       (setvar "cmdecho" 0)
  21.       (command "_.chprop" ss_kill "" "c" 1 "")
  22.       (setvar "cmdecho" 1)
  23.       (mapcar  'princ (list "\n------------- 有\t" (sslength ss_kill) "  条斜线。"))
  24.      )
  25.      (alert "\n没有斜线!")
  26.     )
  27. (prin1)
  28. )
s678z + 1
发表于 2013-12-11 10:57:14 | 显示全部楼层
这下应该解决了吧
s678z + 1
 楼主| 发表于 2013-12-16 08:10:16 | 显示全部楼层
菜卷鱼 发表于 2013-12-11 10:57
这下应该解决了吧
改进后查斜线程序检查的dwg图纸见附件,图中部分斜线没显示,但直线已经没有被误为斜线,这已经改进了,另外,查出的斜线能否另外建个图层,以便和正常的线条颜色区别开来,感谢网友的帮忙。
发表于 2013-12-16 08:44:40 | 显示全部楼层
单独设置图层的话就把 (command "_.chprop" ss_kill "" "c" 3 "")  改成  (command "_.chprop" ss_kill "" "c" 3 "LA" "斜线的图层" ""),
部分斜线没显示出来就是斜线的角度超过了0.3,你就把(/ pi 600)中的 600改小一点,(/ pi 600)就是0.3°,就是把0.3改大一点
发表于 2013-12-16 09:33:36 | 显示全部楼层
菜卷鱼 发表于 2013-12-16 08:44
单独设置图层的话就把 (command "_.chprop" ss_kill "" "c" 3 "")  改成  (command "_.chprop" ss_kill ""  ...
能不能支持多义线呀。。那要怎样修改呢?
发表于 2013-12-16 11:24:35 | 显示全部楼层
chenming10 发表于 2013-12-16 09:33
能不能支持多义线呀。。那要怎样修改呢?
我也是菜鸟,多义线的话要找高手,是我自己的话我会把多义线炸开
 楼主| 发表于 2013-12-17 10:26:51 | 显示全部楼层
查斜线程序已好用,这个问题你看看有无办法http://bbs.mjtd.com/thread-108134-1-1.html
GMT+8, 2025-5-25 22:42 , Processed in 0.172351 second(s), 27 queries , Gzip On.
