查看: 2389|回复: 4
[源码] 对齐天正对象命令
发表于 2013-12-13 01:48:55 | 显示全部楼层 |阅读模式
(princ "\n天正标高对齐 命令: TT")
(defun c:tt1()
        (SETQ OS (GETVAR "OSMODE") ss nil)
        (if (setq TargetPt (getpoint "请选择要基准点:")) (setq ss (ssget '((0 . "TCH_ELEVATION")))))
        (setvar "osmode" 0)
        (if ss
                 (initget "H V")
                 (if (= (setq x (getkword "是否确定[竖向对齐-默认(V)/水平对齐(H)]: ")) nil)(setq x "V"))
                 (SETQ TargetPtX (car TargetPt) TargetPtY (cadr TargetPt))
                 (repeat (setq n (sslength ss))
                     (setq BasisPt (CDR (assoc '10 (entget (ssname ss (setq n (1- n)))))))
                     (SETQ BasisPtX (car BasisPt) BasisPtY (cadr BasisPt))
                     (if (= x "V") (command "_move" (ssname ss n) "" BasisPt (list TargetPtX BasisPtY 0.0)))
                     (if (= x "H") (command "_move" (ssname ss n) "" BasisPt (list BasisPtX TargetPtY 0.0)))
        (SETVAR "OSMODE" OS)
发表于 2013-12-14 02:51:09 | 显示全部楼层
必须支持一下。
发表于 2014-2-22 11:23:56 | 显示全部楼层
收藏了!支持。
发表于 2014-4-26 16:27:28 | 显示全部楼层
收藏了!支持。
发表于 2014-4-26 19:01:52 | 显示全部楼层
路过,收藏看看
GMT+8, 2025-6-11 03:56 , Processed in 0.140402 second(s), 25 queries , Gzip On.
