借花献佛,试试看是不是这样.
 - (defun myss (minl maxl / e len n obj ss)
- (if (setq ss (ssget '((0 . "*LINE"))))
- (repeat (setq n (sslength ss))
- (setq e (ssname ss (setq n (1- n))))
- (setq obj (vlax-ename->vla-object e))
- (setq len (vlax-get obj 'length))
- (if (or
- (< len minl)
- (> len maxl)
- (ssdel e ss)
- ss
- (defun c:sss (/ a b ss)
- (if (not (setq a (getdist "\n请指定最小长度<0.5>:")))
- (setq a 0.5)
- (if (not (setq b (getdist "\n请指定最大长度<2.5>:")))
- (setq b 2.5)
- (if (and
- a
- b
- (if (setq ss (myss a b))
- (command "._select" ss "" "._pselect" ss "")
- (princ)
