查看: 3182|回复: 8
[源码] 文字加前後綴(視窗化)..好用小程序
发表于 2014-1-6 03:41:33 | 显示全部楼层 |阅读模式
給需要的人使用...如有不周的地方..請給小弟批評指教,謝謝!!
本帖被以下淘专辑推荐:
发表于 2014-1-6 07:52:13 | 显示全部楼层
感谢分享,好像挺好用的样子
另外,可以考虑增加多选功能
发表于 2014-1-6 17:55:46 | 显示全部楼层
  1. defun c:tt2 nil
  2.   ;(setvar "cmdecho" 0)
  3.   (TET_DL2)
  4.   (princ)
  5. )
  6. (defun TET_DL2(/ txt1 num1 txt2 en end_1 old_name new_name)
  7.     (setq dcl_id (load_dialog "TET.dcl"))
  8.     (new_dialog "tet" dcl_id)
  9.     (action_tile "accept" "(ok_KK)(done_dialog 1)")
  10.      (setq dd(start_dialog))
  11.       (if (= dd 1)
  12.       (ok_ch2)
  13.       )
  14.     (unload_dialog dcl_id)
  15.   )
  16. ;;------------------------------------------------
  17. (defun ok_KK()
  18.     (setq txt1 (get_tile "Text1"))
  19.     (setq txt2 (get_tile "Text2"))
  20.     (setq num1 (ATOF (get_tile "nume1") ))
  21.   );;;ok_ext
  22. (defun ok_ch2()
  23.   (princ "\n按顺序选择:")
  24.    (if (setq ss(ssget '((0 . "*text"))))
  25.        (while(setq en (ssname ss 0))
  26.        (setq en_1 (entget   en))
  27.        (setq old_name (assoc 1 en_1))
  28.    (cond
  29.          ((AND (/= txt1 "")  (/= txt2 "") (/= num1 0.0))
  30.            (setq new_name (strcat txt1 "-" (cdr old_name) "-" txt2 (RTOS num1 2) ))
  31.            )
  32.          ((AND (/= txt1 "")(= txt2 "")(= num1 0.0))
  33.           (setq        new_name (strcat txt1 "-" (cdr old_name) ))
  34.            )
  35.           ((AND (= txt1 "") (/= txt2 "") (/= num1 0.0))
  36.           (setq        new_name (strcat (cdr old_name) "-" TXT2 (RTOS num1 2) ))
  37.          )
  38.          ((AND (= txt1 "") (= txt2 "") (/= num1 0.0))
  39.           (setq        new_name (strcat (cdr old_name) "-" (RTOS num1 2) ))
  40.          )
  41.          ((AND (= txt1 "") (/= txt2 "") (= num1 0.0))
  42.           (setq        new_name (strcat (cdr old_name) "-" TXT2 ))
  43.          )
  44.    );;end cond
  45.          (setq en_1 (subst (cons 1 new_name) (assoc 1 en_1) en_1))
  46.          (entmod en_1)
  47.          (if (/= num1 0.0)
  48.               (setq num1 (+ num1 1))
  49.              )
  50.          (setq ss(ssdel en ss))
  51.     );;end while
  52.      )
  53.        (princ)
  54. )
  55. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  56. (defun c:tet nil
  57.   ;(setvar "cmdecho" 0)
  58.   (TET_DL)
  59.   (princ)
  60. )
  61. (defun TET_DL(/ txt1 num1 txt2 en end_1 old_name new_name)
  62.     (setq dcl_id (load_dialog "TET.dcl"))
  63.     (new_dialog "tet" dcl_id)
  64.     (action_tile "accept" "(ok_KK)(done_dialog 1)")
  65.      (setq dd(start_dialog))
  66.       (if (= dd 1)
  67.       (ok_ch)
  68.       )
  69.     (unload_dialog dcl_id)
  70.   );;end TET_DL
  71.
  72. ;;------------------------------------------------
  73. (defun ok_ch()
  74.    (while
  75.       (setq en (entsel "\n 选取文字:"))
  76.        (setq en_1 (entget (car en)))
  77.        (setq old_name (assoc 1 en_1))
  78.    (cond
  79.          ((AND (/= txt1 "")  (/= txt2 "") (/= num1 0.0))
  80.            (setq new_name (strcat txt1 "-" (cdr old_name) "-" txt2 (RTOS num1 2) ))
  81.            )
  82.          ((AND (/= txt1 "")(= txt2 "")(= num1 0.0))
  83.           (setq        new_name (strcat txt1 "-" (cdr old_name) ))
  84.            )
  85.           ((AND (= txt1 "") (/= txt2 "") (/= num1 0.0))
  86.           (setq        new_name (strcat (cdr old_name) "-" TXT2 (RTOS num1 2) ))
  87.          )
  88.          ((AND (= txt1 "") (= txt2 "") (/= num1 0.0))
  89.           (setq        new_name (strcat (cdr old_name) "-" (RTOS num1 2) ))
  90.          )
  91.          ((AND (= txt1 "") (/= txt2 "") (= num1 0.0))
  92.           (setq        new_name (strcat (cdr old_name) "-" TXT2 ))
  93.          )
  94.    );;end cond
  95.          (setq en_1 (subst (cons 1 new_name) (assoc 1 en_1) en_1))
  96.          (entmod en_1)
  97.          (if (/= num1 0.0)
  98.               (setq num1 (+ num1 1))
  99.              )
  100.     );;end while
  101.        (princ)
  102. );;end ok_ch
  1. tet:dialog
  2. {
  3. label = "文字加前后缀";
  4.     :boxed_column
  5.     {
  6.      label = "前缀:" ;
  7.      fixed_width = true ;
  8.      width = 10 ;
  9.         :edit_box
  10.         {
  11.             key = "Text1";
  12.             label = " 前缀英文或英数字:" ;
  13.             width = 8 ;
  14.             height = 1 ;
  15.             fixed_width = true ;
  16.         }
  17.         spacer_1;
  18.     }
  19.     :boxed_column
  20.     {
  21.     label = "后缀:" ;
  22.     fixed_width = true ;
  23.     width = 10 ;
  24.         :edit_box
  25.         {
  26.             key = "Text2";
  27.             label = "                后缀英文:" ;
  28.             width = 8 ;
  29.             height = 1 ;
  30.             fixed_width = true ;
  31.         }
  32.         :edit_box
  33.         {
  34.             key = "nume1";
  35.             label = "                后缀数字:" ;
  36.             width = 8 ;
  37.             height = 1 ;
  38.             fixed_width = true ;
  39.         }
  40.         spacer_1;
  41.     }
  42.     spacer_1;
  43.     :text
  44.     {
  45.         key = "Label3" ;
  46.         value = "说明:您可加前后缀,或者只加前缀,或者只加后缀, 三种摸式" ;
  47.         fixed_width = true ;
  48.         fixed_height = true ;
  49.         width = 30 ;
  50.         height = 3 ;
  51.     }
  52. ok_cancel ;
  53. }
发表于 2014-1-6 20:50:57 | 显示全部楼层
edata 发表于 2014-1-6 17:55
; error: no function definition: TET_DL2
发表于 2014-1-6 22:52:14 | 显示全部楼层
less a "("
  1. (defun c:tt2 nil
  3.   (TET_DL2)
  4.   (princ)
  5. )
  11.       (if (= dd 1)
  12.       (ok_ch2)
  13.       )
  15.   )
  17. (defun ok_KK()
  21.   );;;ok_ext
  22. (defun ok_ch2()
  28.    (cond
  31.            )
  34.            )
  37.          )
  40.          )
  43.          )
  44.    );;end cond
  46.          (entmod en_1)
  49.              )
  51.     );;end while
  52.      )
  53.        (princ)
  54. )
  58.   (TET_DL)
  59.   (princ)
  60. )
  66.       (if (= dd 1)
  67.       (ok_ch)
  68.       )
  70.   );;end TET_DL
  71.
  73. (defun ok_ch()
  74.    (while
  78.    (cond
  81.            )
  84.            )
  87.          )
  90.          )
  93.          )
  94.    );;end cond
  96.          (entmod en_1)
  99.              )
  100.     );;end while
  101.        (princ)
  102. );;end ok_ch
发表于 2014-1-8 13:58:06 | 显示全部楼层
批量操作才是王道
发表于 2016-3-16 15:50:52 | 显示全部楼层
楼主,程序很好,要做到加减前缀后缀都可以,这样进退自由想加就加想减就减,毕竟在工作需要中编辑文字没有固定式(不可能只加不减),框选批量修改才好,我看了你的截图,我想了想一个一的点文字多的话要到什么时候?希望楼主再接再厉完善程序,为在一线绘图的绘图员造福!!!!!
发表于 2016-5-25 17:27:56 | 显示全部楼层
刚看到,不知道能不能添加文字或者特殊符号,先顶!了
发表于 2019-8-27 07:02:11 | 显示全部楼层
批量操作才是王道
GMT+8, 2025-10-28 04:28 , Processed in 0.197282 second(s), 32 queries , Gzip On.
