- 积分
- 39162
- 明经币
- 个
- 注册时间
- 2009-1-8
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2014-1-8 23:07:52
显示全部楼层
 - (defun c:get( / b1 b2 b3 d dat_file ff n path1 txt1 x y
- CH FX I LC OLD_CMD P1 P2 P3 P4 P5 P6 PT SL STR STR_LST )
- ; 用于lsp与txt之间数据传输
- (setq path1 (getvar "dwgprefix"))
- (setq ff (open (strcat path1 "样表" ".txt" ) "w")) ;写文件,如不存在则新建文件,如存在新资料将覆盖旧资料。
- (write-line "C1215,1200,1500,20,左10右10,2层" ff)
- (write-line "C1515,1500,1500,16,左8右8,4层" ff)
- (write-line "C1815,1800,1500,22,左11右11,4层" ff)
- (write-line "C2118,2100,1800,14,左7右7,12层" ff)
- (write-line "C0921,900,2100,6,左6,4层" ff)
- (close ff)
- (setq dat_file (getfiled "选择txt的文件或样表" path1 "txt" 2))
- (setq n 1 b1 '() b2 '() b3 '() ff (open dat_file "r"))
- (setq str_lst '())
- (while (setq txt1 (read-line ff))
- (setq b1 (parse txt1 ","))
- (setq str_lst(cons b1 str_lst))
- ;(setq d (nth 0 b1) x (atof (nth 1 b1)) y (atof (nth 2 b1)) )
- ;(setq b2 (list n d x y) b3 (cons b2 b3) n (1+ n) )
- (setq str_lst (reverse str_lst))
- (setq pt(getpoint "\n请指定插入点:") i 0)
- (if (and pt str_lst)
- (progn
- (setq old_cmd(getvar "cmdecho"))
- (setvar "cmdecho" 0)
- (command "_.undo" "be")
- (repeat (length str_lst)
- (setq str(nth i str_lst))
- (setq p1(list(+(car pt) 4 )(- (cadr pt) 5))
- p2(list(+(car pt) 40 )(- (cadr pt) 5))
- p3(list(+(car pt) 54 )(- (cadr pt) 5))
- p4(list(+(car pt) 4 )(- (cadr pt) 13))
- p5(list(+(car pt) 254 )(- (cadr pt) 13))
- p6(list(+(car pt) 138 )(- (cadr pt) 5))
- (setq ch(car str)
- x (cadr str)
- y (caddr str)
- sl (cadddr str)
- fx(nth 4 str)
- lc(nth 5 str))
- (command "_.text" "_non" p1 3 0 ch nil)
- (command "_.text" "_non" p2 3 0 x nil)
- (command "_.text" "_non" p3 3 0 y nil)
- (command "_.text" "_non" p4 3 0 sl nil)
- (command "_.text" "_non" p5 3 0 fx nil)
- (command "_.text" "_non" p6 3 0 lc nil)
- (setq i(1+ i)
- pt(list(+(car pt) 0 )(- (cadr pt) 23))
- (command "_.undo" "e")
- (setvar "cmdecho" old_cmd)
- ;;; (setq b3 (reverse b3))
- ;;; (setq d (nth 1 (nth 2 b3)) )
- ;;; (setq p1 (getpoint "\n请指定插入点:"))
- ;;; (command "text" p1 100 0 d "")
- ;;; (print b3) (print "第3行第1个数值:")(princ d)
- (princ)
- (defun parse (str delim / lst pos)
- ;明经Gu-xl编写,将字符串按照区别符delim分成表str
- (setq pos (vl-string-search delim str))
- (while pos
- (setq lst (cons (substr str 1 pos) lst)
- str (substr str (+ pos 2))
- pos (vl-string-search delim str)
- (if (> (strlen str) 0)
- (setq lst (cons str lst))
- (if (= " " delim) (setq lst (vl-remove "" lst)))
- (reverse lst)
- ;测试
- ; (setq s (list 'a 'b 'c))
