查看: 3007|回复: 3
[提问] 求1读取CAD中XYZ坐标到电子表格以及反向操作的LSP
发表于 2014-1-18 13:36:39 | 显示全部楼层 |阅读模式
求1读取CAD中XYZ坐标到电子表格以及反向读取CSV输序号标注到CAD的LSP
读取到CAD中是为了排序以检查坐标,
读取CSV是为了输入数据
请大神们帮忙
 楼主| 发表于 2014-1-18 13:42:51 | 显示全部楼层
  1. (defun c:tu()
  2.   (setvar "cmdecho" 0)
  3.   (COMMAND ".UNDO" "BE")
  4.   (command "-units" "2" "3" "2" "3" "" "")
  5.   (setq fp (open "d:/POINT.xls" "a") s (getvar "cmdecho") n (getint "TOTAL NO: "))
  6.   (princ "NO" fp)(princ "\t" fp)
  7.   (princ "X" fp)(princ "\t" fp)
  8.   (princ "Y" fp)(princ "\n" fp)
  9.   (repeat n
  10.        (setq k (getstring "\NO(如:1)!")
  11.              p (getpoint "SELECT POINT!")
  12.              x (strcat "X=" (rtos (nth 0 p)))
  13.              y (strcat "Y=" (rtos (nth 1 p))))
  14.     (princ k fp)(princ "\t" fp)
  15.     (princ x fp)(princ "\t" fp)
  16.     (princ y fp)(princ "\n" fp))
  17.     (close fp)
  18.   (setvar "cmdecho" s))
  19.   (princ "\n提示:INPUT TU!")
  20.   (princ)
 楼主| 发表于 2014-1-18 13:43:22 | 显示全部楼层
与我想要的有一些区别
发表于 2015-7-1 23:43:26 | 显示全部楼层
请见此连接,可参照修改:http://bbs.mjtd.com/thread-113519-1-1.html
GMT+8, 2025-5-21 17:44 , Processed in 0.169378 second(s), 31 queries , Gzip On.
