查看: 4454|回复: 5
[源码] opendcl版的统计属性块数量
发表于 2014-1-18 17:48:41 | 显示全部楼层 |阅读模式
;统计属性块数量 2014.1.18 需安装opendcl才能使用
(defun c:tjk ()
(command "opendcl")
(setq odcl '("YWt6AyQHAAD2O6cjBuIL7bUxLT9quMF1U/IWTty4++VkT2bLJhZzw1AiZhwC/p5dV/U4ErU7/zx3"
"X6TObulaxg/ddaOGeRZKj+/GqvPQinFODzWcDZ+8WYvi3wqQg9yJGBCYSaGy502h58XHyCT9yhOD"
"RvJCoCHFyQJfoQtP6dUeaH8YTvhstEZAqfN/4r3OsBPguVrYnn8GpXQSrvByCYS23DFo8r05ZPnu"
"6hF0ROQ6OPxrElFVEXjDrJXtTyEY8vfs6Cs7h3jM4zPX2G9N3HtMXV0VLNxY+62MaBI68yzq4BEZ"
"hkjcUTM5C2mTFbJS5M4v/RTciKd3nbceg29XAHJrsh9kQ04BrixpQiMakGwhXyBe0G/BXcBkn2Nb"
"T8BaCPC8m070X8+A+sp3sjVVNndYzl4g5qVqk3gP9WmbIdop9yHfHaP5xF+YUhyVPZTmJwq40zYj"
"snW6bwQy+a3p2hnkwyY6ATiEbbmhKwE0hB2sAS1AxV3bpeR2o6SnnrOzeoqT6zWvXakc8zgeIDko"
"v5LzkBxR9iSt0F05hvzmjRwAK/QPKvQqqxWMcZ3kHmT5QDY32YARlDFLS5gyqw4YtpdkqkI6qqo5"
"atHz5vXKu8/zSW1HoNg/h8dtrFC1T7WMWK5RoTVOsSNgQUqxUpNtVAAr9Qn1ioPquQhEqc6d0bR5"
"YslXWfeJL4LpmrVn9MH1tKBjVIXclmE2oT2VMUXA0JlFm6awZ15gWkA3ki2AAlPFNnEjrWubRoOh"
"iZcBAD6iMCIQuskPs2qPCh1BkeWoxTyEWg/vnFFvmfZ9nBucRboHnDFzwagGq5sdg4QyhwM6FfpF"
"F4NpCSDV8TmJrZlRh8eDKg=="))
  (dcl_project_import odcl nil nil)
  (dcl_form_show ck_Form1)
(defun c:ck_Form1_OnInitialize (/)
  (setq
    bkname (assoc 2 (entget (car (entsel "\n指定要统计的属性块:"))))
  (setq lst1 nil
lst2 nil
  (setq ss (ssget (list '(0 . "INSERT") bkname)))
  (setq ssn 0)
  (repeat (sslength ss)
    (setq ss2 (cdr (assoc 1 (entget (entnext (ssname ss ssn))))))
    (setq lst1 (append lst1 (list ss2)))
    (setq ssn (1+ ssn))
  (while lst1
    (setq lst2
    (append
      lst2
      (list
        (list (car lst1)
       (- (length lst1)
   (length (setq lst1 (vl-remove (car lst1) lst1)))
  (setq str1 "             ")
  (setq str "")
  (foreach x lst2
    (setq str (strcat str
        (setq str2 (car x))
        (substr str1 (1+ (strlen str2)) (strlen str1))
        (rtos (last x) 2)
        "\r\n"
  (dcl_Control_SetText
    ck_Form1_TextBox1
    (strcat "属性值" (setq str1 "             ") "数量\r\n" str)
发表于 2014-1-18 20:01:00 | 显示全部楼层
opendcl太麻烦,用的时候还要安装多一个opendcl
发表于 2014-1-19 13:09:26 | 显示全部楼层
不错,我比较喜欢opendcl的 界面了,毕竟比较丰富些
发表于 2014-1-19 17:52:07 | 显示全部楼层
可惜没有纯LISP的属性块统计....................
发表于 2014-1-21 09:35:09 | 显示全部楼层
不过这个有界面,还是挺好的。值得再扩展
发表于 2014-1-22 08:56:14 | 显示全部楼层
里面的乱码好吓人
GMT+8, 2025-5-25 16:45 , Processed in 0.188885 second(s), 26 queries , Gzip On.
