查看: 1630|回复: 6
[提问] 求批量标注弧长
发表于 2014-2-26 18:44:27 | 显示全部楼层 |阅读模式
从网上下载了个标注弧下,不能批量,还要指定标注点,哪位高手能不能批量标注弧长,不要指定尺寸文字点
;          弧长标注
(defun C:hu (/ obj sel el e r ang angs ange larc pnt multi)
  (setvar "CMDECHO" 0)
  (setq multi (getvar 'dimlfac));;;add 2002.5.15 can remove
  (setq obj (entsel "\nSelect ARC:<Exit> "))
  (setq sel (car obj))
  (setq pnt (getpoint "point"))
  (terpri)
  (if (/= sel nil)
      (setq el (entget sel))
      (setq e (assoc 0 el))
      (if (= "ARC" (cdr e))
   (setq r (assoc 40 el))
   (setq r (cdr r))
   (setq angs (assoc 50 el))
   (setq angs (cdr angs))
   (setq ange (assoc 51 el))
   (setq ange (cdr ange))
   (setq ang (- ange angs))
   (if (< ang 0)
     (setq ang (- (* 2 pi) (abs ang)))
   (setq larc (* r ang))
   (setq larc (* larc multi));;;add 2002.2.20 can remove
                                   ;;;add muti as multiple
   ;;;(princ "Angle = ")
   ;;;(prin1 (* (/ ang pi) 180))
   ;;;(princ " , Radius = ")
   ;;;(prin1 r)
   ;;;(princ "\nLength of ARC is : ")
   ;;;(prin1 larc)
(princ "Object is not a ARC !")
  (setq larc  (rtos larc 2 1) )
(command "dimangular"  obj  "t" larc pnt )
发表于 2014-2-26 18:55:42 | 显示全部楼层
文字点角度可以取弧标注的两个基点取中与圆心的角度,偏移距离取半径加(或减)标注文字高度的倍数
发表于 2014-2-26 19:14:03 | 显示全部楼层
下图是在某个群里看到的演示
 楼主| 发表于 2014-2-28 10:56:48 | 显示全部楼层
自已顶一顶,争取顶出高手来
发表于 2014-3-19 12:59:04 | 显示全部楼层
帮顶,  高手楼下
发表于 2014-6-20 10:03:27 | 显示全部楼层
同求,这个特别犀利
发表于 2014-6-20 10:57:02 | 显示全部楼层
emk 发表于 2014-2-26 19:14
下图是在某个群里看到的演示
这是那个工具箱的?
GMT+8, 2025-5-24 13:47 , Processed in 0.190379 second(s), 26 queries , Gzip On.
