查看: 1388|回复: 1
[提问] 关于WHILE程序的使用问题
发表于 2014-3-3 20:05:31 | 显示全部楼层 |阅读模式
最近,我编了一个程序,其中用到WHILE函数,但是怎么也循环不起来,不知为什么,请高手指点一二,谢谢,程序如下:
(defun c:bygg ()
;----------从TEXT文件中读取数据
(defun jstxt (fname fa)
(setq f (open fname "r"))
(setq vb (read (read-line f)))
(setq loop t)
(while loop
(setq jb (read (read-line f)))
(if (equal fa (car jb)) (setq jb1 jb loop nil)
(setq j -1 jb1 (cdr jb1))
(repeat (length vb)
(setq j (1+ j) x (nth j vb))
(setq x (nth j jb1))
(close f)
jb1)
(setq wj "D:/byqtj.TXT")
(setq numb (getint "请输入起始变压器序号:"))
(if (= numb "")
(setq numb 1))
(setq loop T)
(while loop
(setq slist (jstxt wj numb))
(setq n 0)
(setq a (nth n slist))
(print (strcat "现在要更改的是" (vl-prin1-to-string a)))
(repeat 7
(cond
((= n 0)
(setq enna (entsel "现在要更改的是变压器名!"))
(setq database (entget (car enna)))
(setq database (subst (cons 1 (vl-prin1-to-string a)) (assoc '1 database) database))
(entmod database)
);progn
((= n 1)
(setq enna (entsel "现在要更改的是变压器容量!"))
(setq database (subst (cons 1 (strcat "SCB10H-" (itoa a) "/10")) (assoc '1 database) database))
(entmod database)
);progn
((= n 2)
(setq enna (entsel "现在要更改的是装设功率!"))
(setq database (subst (cons 1 (rtos a 2 2)) (assoc '1 database) database))
(entmod database)
);progn
((= n 3)
(setq enna (entsel "现在要更改的是需要系数!"))
(entmod database)
);progn
((= n 4)
(setq enna (entsel "现在要更改的是功率因数!"))
(entmod database)
);progn
((= n 5)
(setq enna (entsel "现在要更改的是计算电流!"))
(entmod database)
);progn
((= n 6)
(setq enna (entsel "现在要更改的是电容补偿量!"))
(setq database (subst (cons 1 (strcat "折算后电容" (itoa a) "kvar")) (assoc '1 database) database))
(entmod database)
);progn
);cond
(setq n (+ n 1))
);repeat
(if (= (strcase (getstring "是否需要继续?Y/N(N)")) "N")
(setq loop nil)
(setq numb (+ numb 1))
);if
);while
发表于 2014-3-4 00:08:37 | 显示全部楼层
格式。。。眼花。。。
把最后的(if (= (strcase (getstring "是否需要继续?Y/N(N)")) "N")改为
(if (= (getstring "是否需要继续?Y/N(N)") "N")
试试
GMT+8, 2025-5-25 10:57 , Processed in 0.250681 second(s), 27 queries , Gzip On.
