查看: 1446|回复: 2
[提问] 如何复制源图,并只对复制图进行炸开等操作
发表于 2014-3-7 13:26:43 | 显示全部楼层 |阅读模式
4明经币
(defun c:tz (/ ss sl i el pr dn lyr addlyr layers)
  (vl-load-com)
  (defun addlyr        (lyr)
    (vla-add layers lyr)
  (if (and (setq ss0 (ssget '((0 . "TCH_PIPE,TCH_EQUIPMENT"))))
(setq ss (ssget "p" '((0 . "TCH_PIPE")))))
      (setq sl           (sslength ss)
            i           sl
            layers (vla-get-layers
                     (vla-get-activedocument (vlax-get-acad-object))
      (repeat sl
        (setq e (ssname ss (setq i (1- i)))
        el  (entget e)
              pr  (cdr (assoc 301 el))
              dn  (cdr (assoc 140 el))
              lyr (strcat pr (rtos dn 2 0))
        (if (tblsearch "layer" lyr)
          nil
          (addlyr lyr)
      (entmod (subst (cons 8 lyr) (assoc 8 el) el))
      (setvar "QAFLAGS" 1)
         (command "_explode" ss0 "")
         (command "_explode" (ssget "p" '((0 . "*Polyline")))"" )
      (setvar "QAFLAGS" 0)
怎么先复制“TCH_PIPE”源管线 ,并只对复制管线进行炸开等处理 ,不动TCH_PIPE源管线?
现有思路如下,抛砖引玉吧
(setq a (car (entsel)))
(entmake (entget a))
(command "_explode" (entlast))
哪位高手帮改改,谢谢!!
发表于 2014-3-8 12:29:50 | 显示全部楼层
你把复制出来的图块保留在原地,然后把原图移动出来炸掉,这样你就可以炸
(setq ss(ssget))
(command "_.copy" ss)
(command "_.move" ss)
(command "_explode" ss)
发表于 2014-3-12 11:25:09 | 显示全部楼层
GMT+8, 2025-5-25 08:20 , Processed in 0.150471 second(s), 25 queries , Gzip On.
