查看: 6121|回复: 15
[源码] 求两个LiSP小程序,一个是加编号的,一个是加边框的
发表于 2014-3-8 23:00:45 | 显示全部楼层 |阅读模式
加边框的能达到图片的效果就行了,加编号的,不要像图片那样非得选择实体的东西,我需要的就是输入命令后直接用鼠标到处去点就能够出来编号了的!谢谢大家了
发表于 2014-7-3 22:48:54 | 显示全部楼层
  1. ;;加边框
  2. (Defun c:tt(/ *AcadObject* *DwgObject* *ModelSpace* *Layers* *Blocks* *LineTypes*
  3.       RightDis UpDis selecollection index ptlist VlaObject maxpoint minpoint
  4.       pt1 pt2 pt3 pt4 polylinept polypt )
  5.   (vl-load-com)
  6.   (setq  *AcadObject* (vlax-get-acad-object)
  7.   *DwgObject*  (vla-get-activedocument *AcadObject*)
  8.   *ModelSpace* (vla-get-modelspace *DwgObject*)
  9.   *Layers*     (vla-get-layers *DwgObject*)
  10.   *Blocks*     (vla-get-blocks *DwgObject*)
  11.   *LineTypes*  (vla-get-linetypes *DwgObject*)
  12.   )
  13.   (if (not RightDis_1)(setq RightDis_1 10.0))
  14.   (setq RightDis(getreal (strcat"\n请输入左右偏移距离:<"(rtos RightDis_1)">")))
  15.   (if RightDis(setq RightDis_1 RightDis)(setq RightDis RightDis_1))
  16.   (if (not UpDis_1)(setq UpDis_1 10.0))
  17.   (setq (getreal (strcat"\n请输上下偏移距离:<"(rtos UpDis_1)">")))
  18.   (if UpDis(setq UpDis_1 UpDis)(setq UpDis UpDis_1))
  19.   (setq selecollection(ssget))
  20.   (while selecollection
  21.     (setq index 0 ptlist nil)
  22.     (repeat (sslength selecollection)
  23.   (setq VlaObject(vlax-ename->vla-object(ssname selecollection index)))
  24.   (vlax-invoke-method VlaObject 'GetBoundingBox 'minpoint 'maxpoint)
  25.         (setq maxpoint(vlax-safearray->list maxpoint))
  26.   (setq minpoint(vlax-safearray->list minpoint))
  27.   (setq ptlist(append ptlist(list maxpoint minpoint)))
  28.   (setq index(1+ index))
  29.   )
  30.     (setq MinPoint(apply 'mapcar (cons 'min ptlist)))
  31.     (setq MaxPoint(apply 'mapcar (cons 'max ptlist)))
  32.     (setq pt1(list(-(car MinPoint)RightDis)(-(cadr MinPoint)UpDis)0))
  33.     (setq pt3(list(+(car maxpoint)RightDis)(+(cadr maxpoint)UpDis)0))
  34.     (setq pt2(list(car pt3)(cadr pt1)0))
  35.     (Setq pt4(list(car pt1)(cadr pt3)0))
  36.     (setq polylinept(append pt1 pt2 pt3 pt4 pt1))
  37.     (setq polypt(vlax-make-safearray vlax-vbDouble '(0 . 14)))
  38.     (vlax-safearray-fill polypt  polylinept)
  39.     (vlax-invoke-method *modelspace* 'addpolyline polypt)
  40.     (setq selecollection(ssget))
  41.     )
  42.   (prin1)
  43.   )
发表于 2014-7-3 23:42:08 | 显示全部楼层
  1. ;;加边框
  2. ;;design:guowei
  3. ;;2014/07/03
  4. (Defun c:tt(/ *AcadObject* *DwgObject* *ModelSpace* *Layers* *Blocks* *LineTypes*
  5.       RightDis UpDis selecollection index ptlist VlaObject maxpoint minpoint
  6.       pt1 pt2 pt3 pt4 polylinept polypt )
  7.   (vl-load-com)
  8.   (setq  *AcadObject* (vlax-get-acad-object)
  9.   *DwgObject*  (vla-get-activedocument *AcadObject*)
  10.   *ModelSpace* (vla-get-modelspace *DwgObject*)
  11.   *Layers*     (vla-get-layers *DwgObject*)
  12.   *Blocks*     (vla-get-blocks *DwgObject*)
  13.   *LineTypes*  (vla-get-linetypes *DwgObject*)
  14.   )
  15.   (if (not RightDis_1)(setq RightDis_1 10.0))
  16.   (setq RightDis(getreal (strcat"\n请输入左右偏移距离:<"(rtos RightDis_1)">")))
  17.   (if RightDis(setq RightDis_1 RightDis)(setq RightDis RightDis_1))
  18.   (if (not UpDis_1)(setq UpDis_1 10.0))
  19.   (setq UpDis(getreal (strcat"\n请输上下偏移距离:<"(rtos UpDis_1)">")))
  20.   (if UpDis(setq UpDis_1 UpDis)(setq UpDis UpDis_1))
  21.   (setq selecollection(ssget))
  22.   (while selecollection
  23.     (setq index 0 ptlist nil)
  24.     (repeat (sslength selecollection)
  25.   (setq VlaObject(vlax-ename->vla-object(ssname selecollection index)))
  26.   (vlax-invoke-method VlaObject 'GetBoundingBox 'minpoint 'maxpoint)
  27.         (setq maxpoint(vlax-safearray->list maxpoint))
  28.   (setq minpoint(vlax-safearray->list minpoint))
  29.   (setq ptlist(append ptlist(list maxpoint minpoint)))
  30.   (setq index(1+ index))
  31.   )
  32.     (setq MinPoint(apply 'mapcar (cons 'min ptlist)))
  33.     (setq MaxPoint(apply 'mapcar (cons 'max ptlist)))
  34.     (setq pt1(list(-(car MinPoint)RightDis)(-(cadr MinPoint)UpDis)0))
  35.     (setq pt3(list(+(car maxpoint)RightDis)(+(cadr maxpoint)UpDis)0))
  36.     (setq pt2(list(car pt3)(cadr pt1)0))
  37.     (Setq pt4(list(car pt1)(cadr pt3)0))
  38.     (setq polylinept(append pt1 pt2 pt3 pt4 pt1))
  39.     (setq polypt(vlax-make-safearray vlax-vbDouble '(0 . 14)))
  40.     (vlax-safearray-fill polypt  polylinept)
  41.     (vlax-invoke-method *modelspace* 'addpolyline polypt)
  42.     (setq selecollection(ssget))
  43.     )
  44.   (prin1)
  45.   )
  46. ;;加编号
  47. ;;desing:guowei
  48. ;;2014/07/03
  49. (DEFUN C:EE(/ *AcadObject* *DwgObject* *ModelSpace* *Layers* *Blocks* *LineTypes*
  50.       TxtHeight txt index InsertPoint TextString)
  51.   (vl-load-com)
  52.   (setq  *AcadObject* (vlax-get-acad-object)
  53.   *DwgObject*  (vla-get-activedocument *AcadObject*)
  54.   *ModelSpace* (vla-get-modelspace *DwgObject*)
  55.   *Layers*     (vla-get-layers *DwgObject*)
  56.   *Blocks*     (vla-get-blocks *DwgObject*)
  57.   *LineTypes*  (vla-get-linetypes *DwgObject*)
  58.   )
  59.   (setq TxtHeight(getvar "dimtxt"))
  60.   (if(not txt_1)(setq txt_1 "荣鑫刀模hg140301-"))
  61.   (setq txt(getstring (strcat"\n请输入前辍:<"txt_1">")))
  62.   (if(or(= txt "")(= txt nil))(setq txt txt_1)(setq txt_1 txt))
  63.   (if(not index_1)(setq index_1 1))
  64.   (setq index(getint (strcat "\n请输入序号:<"(rtos index_1 2 0)">")))
  65.   (if index(setq index_1 index)(setq index index_1))
  66.   (while(setq InsertPoint(trans(getpoint "\n输入序号插入点:")1 0))
  67.     (setq TextString(strcat txt(rtos index 2 0)))
  68.     (vlax-invoke-method *ModelSpace* 'addtext TextString(vlax-3d-point InsertPoint) TxtHeight)
  69.     (setq index_1(setq index(1+ index)))
  70.     )
  71.   (prin1)
  72.   )
参与人数 1明经币 +1 金钱 +20 收起 理由
如梦 + 1 + 20 神马都是浮云
发表于 2014-7-4 08:33:58 | 显示全部楼层
  1. ;; 加边框,需要e派工具箱(XCAD)的支持
  2. (defun c:tt ()
  3.   (setq dd (Udist 1 "" "边框宽度<输入或鼠标直接量取>" dd nil))
  4.   (while (setq ss (ssget))
  5.     (setq p1 (xyp-Pt2XY (xyp-9pt ss 1) (- dd) (- dd))
  6.           p9 (xyp-Pt2XY (xyp-9pt ss 9) dd dd)
  7.           s1 (xyp-rectang p1 p9)
  8.     )
  9.   )
  10.   (princ)
  11. )
发表于 2014-7-4 08:38:56 | 显示全部楼层
  1. ;尾号递增
  2. (defun c:tt ()
  3. (setvar "CMDECHO" 0)
  4. (vl-load-com)
  5. (setq n 1)
  6. (setq str (if (= (type str) 'STR) str ""))
  7. (setq str (getstring (strcat "\n文字前缀" str ": ")))
  8. (while (setq pt (getpoint "\n封闭区域内一点: "))
  9.   (setq s1 (entlast) ss  (ssadd))
  10.   (command "boundary" pt "")
  11.   (while (setq s1 (entnext s1)) (ssadd s1 ss))
  12.   (if (> (sslength ss) 0) (progn
  13.    (setq i -1 plst (list))
  14.    (repeat (sslength ss)
  15.     (setq en (ssname ss (setq i (1+ i))))
  16.     (vla-getboundingbox(vlax-ename->vla-object en) 'p1 'p2)
  17.     (setq plst (append plst (list(vlax-safearray->list p1)(vlax-safearray->list p2))))
  18.    )
  19.    (command "_.ERASE" ss "")
  20.    (setq p1 (apply 'mapcar (cons 'min plst)))
  21.    (setq p2 (apply 'mapcar (cons 'max plst)))
  22. ;   (setq p1 (list (apply 'min (mapcar 'car plst)) (apply 'min (mapcar 'cadr plst))))
  23. ;   (setq p2 (list (apply 'max (mapcar 'car plst)) (apply 'max (mapcar 'cadr plst))))
  24.    (setq pm (mapcar '(lambda (a b) (/ (+ a b) 2)) p1 p2))
  25.    (command "_.TEXT" "M" pm 300 "" (strcat str (itoa n)))
  26.    (setq n (1+ n))
  27.   ))
  28. )
  29. (setvar "CMDECHO" 1)
  30. (princ)
  31. )
  1. ;;加边框
  2. (defun c:ttt ()
  4. (vl-load-com)
  5. (setq bx (getdist "\nEnter Around Space 输入四周间隔: "))
  6. (while (progn (princ "\n选择加框物体: ") (setq ss (ssget)))
  7.   (setq i -1 plst (list))
  8.   (repeat (sslength ss)
  9.    (setq en (ssname ss (setq i (1+ i))))
  10.    (vla-getboundingbox(vlax-ename->vla-object en) 'p1 'p2)
  11.    (setq plst (append plst (list(vlax-safearray->list p1)(vlax-safearray->list p2))))
  12.   )
  13.   (setq p1 (apply 'mapcar (cons 'min plst)))
  14.   (setq p2 (apply 'mapcar (cons 'max plst)))
  15.   (setq p1 (mapcar '- p1 (list bx bx)))
  16.   (setq p2 (mapcar '+ p2 (list bx bx)))
  17.   (command "_.RECTANG" p1 p2)
  18. )
  19. (setvar "CMDECHO" 1)
  20. (prin1)
  21. )
发表于 2014-7-4 08:41:39 | 显示全部楼层
;; e派工具箱内置功能
 楼主| 发表于 2014-7-4 20:22:28 | 显示全部楼层
xyp1964 发表于 2014-7-4 08:41
;; e派工具箱内置功能
院长,我那个图片就是你内置的,坦白讲,你的确实很好,但是我们这个行业用不着那么大的工具箱,加载太慢了。。。。让你分离出来。你不愿意。。我只能在这里求兄弟们了。。。
兄弟,你太较劲了  发表于 2014-7-5 09:39
 楼主| 发表于 2014-7-4 20:52:06 | 显示全部楼层
362896182 发表于 2014-7-3 23:42
谢谢,兄弟你那个加板框的还有问题,文字是块的那种会出现问题,你的加编号是是很好的,没有问题,zz的编号是不对的,你这个板框和zz的是一样的问题,希望能给改进下
发表于 2014-7-4 22:19:11 | 显示全部楼层
如梦 发表于 2014-7-4 20:52
谢谢,兄弟你那个加板框的还有问题,文字是块的那种会出现问题,你的加编号是是很好的,没有问题,zz的编 ...
程序调试没问题。要不给个调试图。
发表于 2014-7-11 22:14:28 | 显示全部楼层
新手路过学习一下,谢谢分享。
GMT+8, 2025-10-25 03:45 , Processed in 0.841857 second(s), 36 queries , Gzip On.
