查看: 3593|回复: 9
[提问] 动态移动标注中的文字,用lsp程序实现
发表于 2014-3-17 14:49:04 | 显示全部楼层 |阅读模式
2明经币
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2014-3-17 15:14:38 | 显示全部楼层
(defun c:TT( / Flag ObjName ObjType VlaObj )
        (princ "\n **********************************")
        (setq *error* *myerror*)
        (SD1028)
        (setq Flag nil)
        (while (null Flag)
                (setvar "ERRNO" 0)
                (setq ObjName nil ObjType nil)
                        (setq ObjName (car (entsel        "\n Select DIMENSION :")))        ;追加
                                (if         ObjName
                        (setq ObjType (SD3511 0 ObjName))
                        (setq Flag nil)
                (cond        ((= ObjType "DIMENSION")(Procedure_1316 ObjName))
                                ((= (getvar "ERRNO") 52)(setq Flag T))
        (SD2056)
        (setq *error* nil)
(defun Procedure_1316 (ObjName / )
        (setq VlaObj (vlax-ename->vla-object ObjName))
        (vlax-put-property VlaObj 'TextMovement acMoveTextAddLeader)
        (vlax-put-property VlaObj 'Fit acBestFit)
        (command "dim" "TE" ObjName pause "exit")
(defun SD1028 ()
  (setq OldCmdEcho (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (command "undo" "be")
  (setq OldOsmode (getvar "OSMODE"))
  (setq OldLayer (getvar "CLAYER"))
  (setq OldLType (getvar "CeLType"))
  (setq OldCeLWeight (getvar "CeLWeight"))
  (setq OldColor (getvar "CeColor"))
  (setq OldOrtho (getvar "ORTHOMODE"))
  (setq OldDStyle  (getvar "DIMSTYLE"))
  (setq OldExpert (getvar "Expert"))
  (setvar "EXPERT" 0)
  (setq Path_Lang "HKEY_CURRENT_USER\\Software\\SpeedDraftLT")
  (if (vl-registry-read Path_Lang "SD_Language" )
          (setq SD:Lang (vl-registry-read Path_Lang "SD_Language" ))
          (progn        (setq SD:Lang "J")
                          (vl-registry-write Path_Lang "SD_Language" "J")
(defun SD2056 ()
  (setvar "OSMODE" OldOsmode)
  (command "undo" "end")
  (setvar "CLAYER" OldLayer)
  (setvar "CeLType" OldLType)
  (setvar "CeLWeight" OldCeLWeight)
  (setvar "CeColor" OldColor)
  (setvar "ORTHOMODE" OldOrtho)
  (setvar "Expert" OldExpert)
  (if (and (/= (getvar "DIMSTYLE") OldDStyle)(tblsearch "DIMSTYLE" OldDStyle))
          (command "-dimstyle" "Restore" OldDStyle)
  (princ "\n (C)OffshoreCad&Management")
  (setvar "CMDECHO" OldCmdEcho)
(defun SD3511 (g e)
        (cond
                ((= (type e) 'ename) (cdr (assoc g (entget e))))
                ((= (type e) 'list) (cdr (assoc g e)))
(defun *myerror* (msg)
        (setq *error* nil)
        (SD2056)
        (princ "\n Error in SpeedDraftLT")
 楼主| 发表于 2014-3-17 15:28:20 | 显示全部楼层
运行不了,acad提示 **********************************
只调整标注文字的位置而标注线不移动
期待高手浮出水面
发表于 2014-3-17 15:49:30 | 显示全部楼层
Error in SpeedDra ...
楼上修改了,再试试
发表于 2014-3-18 11:59:00 | 显示全部楼层
aidimtextmove 不行?
 楼主| 发表于 2014-3-19 11:04:42 | 显示全部楼层
菜卷鱼 发表于 2014-3-18 11:59
aidimtextmove 不行?
回复yaokui25   不要出现引出线   望修改一下
发表于 2020-4-30 21:51:04 来自手机 | 显示全部楼层
这个cad不是有自带的命令吗
发表于 2024-1-5 00:10:04 | 显示全部楼层
这个软件真熟
发表于 2024-1-12 17:18:21 | 显示全部楼层
源泉工具箱里有这样的功能!
发表于 2024-6-20 17:34:16 | 显示全部楼层
aidimtextmove 不行?
啊哈哈。又碰到这种事情。。。我得好好了解下cad自带命令先。
GMT+8, 2025-5-8 05:10 , Processed in 0.194602 second(s), 27 queries , Gzip On.
