查看: 1083|回复: 3
[提问] 怎样取得弧标
发表于 2014-4-4 17:01:36 | 显示全部楼层 |阅读模式
各位大神请帮忙看一下这组代码哪时出了问题:
(defun c:CV()
   (vl-load-com)
   (setq aca(vlax-get-acad-object))
   (setq dwg(vla-get-activedocument aca))
   (setq msp(vla-get-modelspace dwg))
   (setq en(car(entsel "请选择弧:")))
   (setq xx(vlax-ename->vla-object en))
   (setq bu (vlax-curve-getStartPoint xx))
   (setq bu1 (vlax-curve-getendpoint xx))
   (setq bbb(vla-addline msp bu bu1))
   (vla-zoomextents aca)
   (princ "已完成!")
发表于 2014-4-4 19:12:27 | 显示全部楼层
  1. (defun c:tt ()
  2.   (vl-load-com)
  3.   (setq en  (car (entsel "请选择弧: "))
  4.         ao  (vlax-get-acad-object)
  5.         ad  (vla-get-ActiveDocument ao)
  6.         mp  (vla-get-ModelSpace ad)
  7.         ob  (vlax-ename->vla-object en)
  8.         bu  (vlax-curve-getStartPoint ob)
  9.         bu  (vlax-3D-point bu)
  10.         bu1 (vlax-curve-getendpoint ob)
  11.         bu1 (vlax-3D-point bu1)
  12.         bbb (vla-addline mp bu bu1)
  13.   )
  14.   (princ)
  15. )
 楼主| 发表于 2014-4-15 14:50:49 | 显示全部楼层
你的真简洁,非常感谢!
发表于 2014-4-15 15:40:03 | 显示全部楼层
  1. (defun c:CV()
  2.    (vl-load-com)
  3.    (setq aca(vlax-get-acad-object))
  4.    (setq dwg(vla-get-activedocument aca))
  5.    (setq msp(vla-get-modelspace dwg))
  6.    (setq en(car(entsel "请选择弧:")))
  7.    (setq xx(vlax-ename->vla-object en))
  8.    (setq bu (vla-get-startpoint xx));;;vlax-curve-getStartPoint得到的结果需要进行了转换,这样可以不进行转换了,但多线段等别的图元对象不适用,下同
  9.    (setq bu1 (vla-get-endpoint xx))
  10.    (setq bbb(vla-addline msp bu bu1))
  11.    (vla-zoomextents aca)
  12.    (princ "已完成!")
  13.   )
GMT+8, 2025-5-24 23:25 , Processed in 0.183973 second(s), 27 queries , Gzip On.
