查看: 1194|回复: 1
[基础] 下面这个函数有哪些作用?
发表于 2014-4-6 10:43:52 | 显示全部楼层 |阅读模式
下面这个函数有哪些作用?用在哪的?
   (defun find( str1 str2 / pos len found ret len1 )
        (setq pos 1 found 0)
        (setq len (strlen str1) )
       (setq len1 (strlen str2) )
       (while ( <= pos len )
      (if (= str2 (substr str1 pos len1 ) )
    ( setq found pos )
    ( setq pos len ) ) )
    ( setq pos (1+ pos ) ) )
   ( setq ret found ))
发表于 2014-4-6 10:58:06 | 显示全部楼层
類似vl-string-search,str1 str2對調
GMT+8, 2025-5-25 03:45 , Processed in 0.176031 second(s), 25 queries , Gzip On.
