- 积分
- 6397
- 明经币
- 个
- 注册时间
- 2006-1-13
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
;;;生成并加载菜单文件及工具条
(vl-load-com)
;;;功能:尝试获取菜单对象 *
;;;参数:无 *
;;;返回:若成功,返回对象;否则,返回nil。 *
;;; (fun-20140211-GetMyMenu "制图工具")
(defun FUN-20140211-GETMYMENU (STR / MENUGROUPS MENUS I TMPMENU MYMENU)
;;检查菜单在当前菜单组中是否已经存在
(setq MENUGROUPS (vla-get-menugroups (vlax-get-acad-object)))
(setq MYMENU NIL
J 0
(repeat (vla-get-count MENUGROUPS)
(setq MENUS (vla-get-menus (vla-item MENUGROUPS J))
I 0
(repeat (vla-get-count MENUS)
(setq TMPMENU (vla-item MENUS I))
;;(alert (vla-get-name TMPMENU))
(if (= (vla-get-name TMPMENU) STR)
(setq MYMENU TMPMENU)
(setq I (1+ I))
(setq J (1+ J))
;;返回
MYMENU
;;; 生成并加载菜单文件
(defun make-MNUfile (/ FILE LST X)
;;0、文件放置位置选择
(if (or (setq FILENAME (findfile "acad.mnu"))
(setq FILENAME (findfile "acad.cui"))
(setq FILENAME (findfile "acad.exe"))
(setq FILENAME "c:\\")
(setq
FILENAME (strcat (vl-filename-directory FILENAME)
"\\制图工具tool.mnu"
;;1、生成菜单文件
(setq FILE (open FILENAME "W"))
(foreach X
'("***MENUGROUP=制图工具G"
;; 菜单
"\n\n***POP1"
"\nID_Mycad [制图工具]"
"ID_MyCom [->环境建立hjjl]"
"ID_MyCom [新建图层A001] ^C^C^P_A001"
"ID_MyCom [DCL转换LSPA002] ^C^C^P_A002"
"ID_MyCom [图名线A003] ^C^C^P_A003"
"ID_MyCom [获取文件名A004] ^C^C^P_A004"
"ID_MyCom [剖切线A005] ^C^C^P_A005"
"ID_MyCom [双向阵列对象A006] ^C^C^P_A006"
"ID_MyCom [折断线A007] ^C^C^P_A007"
"ID_MyCom [布局粘贴图元A008] ^C^C^P_A008"
"ID_MyCom [加载交通标线A009] ^C^C^P_A009"
"ID_MyCom [布局删除图元A010] ^C^C^P_A010"
"ID_MyCom [修改随层颜色A011] ^C^C^P_A011"
"ID_MyCom [智能中心线A012] ^C^C^P_A012"
"ID_MyCom [<-删除重复图元A013] ^C^C^P_A013"
"ID_MyCom [->文字工具wzgj]"
"ID_MyCom [修改文字B001] ^C^C^P_B001"
"ID_MyCom [文字加注释线B002] ^C^C^P_B002"
"ID_MyCom [<-文字加前后缀B003] ^C^C^P_B003"
"ID_MyCom [卸载树形菜单] ^C^C^P_qq"
"ID_MyCom [卸载工具条] ^C^C^P_ee"
;; 工具条
"\n\n***TOOLBARS\n**TEMPTOOLBAR"
"ID_ZCT001 [_Toolbar(\"工具条01\", _Floating, _Hide, 10, 340, 1)]"
"ID_ZCT011 [_Button(\"轴测图直线\", \"RCDATA_16_OSNEND\", \"RCDATA_16_OSNEND\")]^C^Cline"
"ID_ZCT012 [_Button(\"轴测图标注\", \"RCDATA_16_DIMOBL\", \"RCDATA_16_DIMOBL\")]^C^Cdim"
"ID_ZCT013 [_Button(\"轴测图文字\", \"RCDATA_16_TEXEDI\", \"RCDATA_16_TEXEDI\")]^C^Ctext"
"ID_ZCT014 [_Button(\"轴测图更改\", \"RCDATA_16_DIMOVE\", \"RCDATA_16_DIMOVE\")]^C^Cch"
(princ (strcat X "\n") FILE) ; 将定义工具栏内容写入mnu文件
(close FILE) ;_ 关闭mnu文件
;;2、 加载菜单
(command "menuload" FILENAME)
;;;功能:显示树形菜单、工具条 *
(defun C:RR ()
;;0、判断是否需要加在
(or (menugroup "制图工具G") ;_判断是否已加载菜单
( make-MNUfile );_生成并加载菜单文件
;;1、显示树形菜单
;;****zml84 修改于 2014-02-11
(and
MENUS (vla-get-menus (vla-item MENUGROUPS 0))
MYMENU (FUN-20140211-GETMYMENU "制图工具")
(= (vla-get-onmenubar MYMENU) :vlax-false)
(vla-insertinmenubar MYMENU 99)
;;2、显示工具条
(command "TOOLBAR" "工具条01" "S") ; 显示工具栏
(defun C:QQ ()
(alert "\n\n即将卸载树形菜单")
(and (setq MYMENU (FUN-20140211-GETMYMENU "制图工具"))
(= (vla-get-onmenubar MYMENU) :vlax-true)
(vla-removefrommenubar MYMENU) ;_取消菜单显示
(defun C:EE ()
(alert "\n\n即将卸载工具条")
(command "TOOLBAR" "工具条01" "H")
(c:rr)
为什么读入八进制不对
