查看: 1431|回复: 2
[已解答] 请教,下面的程序如何让宽度不随长度变化?
发表于 2014-4-9 14:25:04 | 显示全部楼层 |阅读模式
以下的程序中,现在是宽度随长度变化,需要的是宽度不随长度变化,该怎么修改程序?
源程序:
(Defun C:QLINE        (/ p1 p2 qd a)
  (setvar "cmdecho" 0)
  (command "LAYER" "m" "$QLine" "C" 4 "" "")
  (initget 1)
  (setq p1 (getpoint "\n点取桥绘制的第一点: "))
  (initget 1)
  (setq p2 (getpoint p1 "\n点取桥绘制的第二点: "))
  (setq        qd (getdist "\n桥宽 m<6>: ")
        qd (if qd
             qd
             6
        sc (getvar "userr1")
  (setvar "plinewid" 0)
  (setq d (distance p1 p2))
  (command "PLINE"
           (polar p1 (+ (setq a (angle p1 p2)) (* 0.75 pi)) (* 0.2 d))
           P1
           P2
           (polar p2 (+ a (* 0.25 pi)) (* 0.2 d))
           "Move"
           (entlast)
           p1
           (polar p1
                  (+ a (* 0.5 pi))
                  (+ (* 0.707 0.2 d) (* 0.5 qd sc))
           "MIRROR"
           (entlast)
           p1
           p2
           "n"
  (setvar "clayer" "0")
发表于 2014-4-9 20:33:55 | 显示全部楼层
  1. (defun C:QLINE (/ p1 p2 qd a)
  2.   (setvar "cmdecho" 0)
  3.   (command "LAYER" "m" "$$QLine" "C" 4 "" "")
  4.   (initget 1)
  5.   (setq p1 (getpoint "\n点取桥绘制的第一点: "))
  6.   (initget 1)
  7.   (setq p2 (getpoint p1 "\n点取桥绘制的第二点: "))
  8.   (setq qd (getdist "\n桥宽 m<6>: ")
  9.         qd (if qd qd 6)
  10.         sc (getvar "userr1"))
  11.   (setvar "plinewid" 0)
  12.   (setq d (distance p1 p2))
  13.   (command "PLINE"
  14.            (polar p1 (+ (setq a (angle p1 p2)) (* 0.75 pi)) (* 0.2 d))
  15.            P1
  16.            P2
  17.            (polar p2 (+ a (* 0.25 pi)) (* 0.2 d))
  18.            ""
  19.            "Move"
  20.            (entlast)
  21.            ""
  22.            p1
  23.            (polar p1 (+ a (* 0.5 pi)) qd)
  24.            "MIRROR"
  25.            (entlast)
  26.            ""
  27.            p1
  28.            p2
  29.            "n"
  30.            )
  31.   (setvar "plinewid" 0)
  32.   (setvar "clayer" "0")
  33.   (princ)
  34. )
 楼主| 发表于 2014-4-9 20:51:56 | 显示全部楼层
谢谢ZZXXQQ,使用ZZXXQQ修改后的程序发现,两边的斜线有点长,比较难看,现给修改成固定的了。
程序如下:
  (initget 1)
  (initget 1)
        qd (if qd qd 6)
  (command "PLINE"
           (polar p1 (+ (setq a (angle p1 p2)) (* 0.75 pi)) 3)
           P1
           P2
           (polar p2 (+ a (* 0.25 pi)) 3)
           "Move"
           (entlast)
           p1
           "MIRROR"
           (entlast)
           p1
           p2
           "n"
GMT+8, 2025-5-15 01:45 , Processed in 0.209903 second(s), 31 queries , Gzip On.
