- 积分
- 5765
- 明经币
- 个
- 注册时间
- 2006-12-19
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2014-6-11 07:25:51
显示全部楼层
功能很强大的交点打断源码。
;;;=======================[ BreakObjects.lsp ]==============================
;;; Author: Copyright? 2006,2007 Charles Alan Butler
;;; Contact @ www.TheSwamp.org
;;; Version: 1.3 April 9,2007
;;; Purpose: Break All selected objects
;;; permitted objects are lines, lwplines, plines, splines,
;;; ellipse, circles & arcs
;;; Function c:BreakAll - Break all objects selected
;;; Function c:BreakwObjects - Break many objects with a single object
;;; Function c:BreakObject - Break a single object with many objects
;;; Function c:BreakWith - Break selected objects with other selected objects
;;; Function c:BreakTouching - Break objects touching the single Break object
;;; Function c:BreakSelected - Break selected objects with any objects that touch it
;;; Sub_Routines:
;;; break_with
;;; ssget->vla-list
;;; list->3pair
;;; onlockedlayer
;;; get_interpts Return a list of intersect points
;;; break_obj Break entity at break points in list
;;; Requirements: objects must have the same z-value
;;; Restrictions: Does not Break objects on locked layers
;;; Returns: none
;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED ;
;;; WARRANTY. ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR ;
;;; PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED. ;
;;; You are hereby granted permission to use, copy and modify this ;
;;; software without charge, provided you do so exclusively for ;
;;; your own use or for use by others in your organization in the ;
;;; performance of their normal duties, and provided further that ;
;;; the above copyright notice appears in all copies and both that ;
;;; copyright notice and the limited warranty and restricted rights ;
;;; notice below appear in all supporting documentation. ;
