查看: 2133|回复: 1
[经验] 做建筑底图处理的小程序
发表于 2014-4-12 10:43:52 | 显示全部楼层 |阅读模式
给像和我一样的朋友,需要做处理建筑底图
(defun c:0T()
     (setq ceng "0-建筑底图")
     (PRINC "\n---将所选对象设置为")(princ ceng)(PRINC ",属性随层")
     (if (= (TBLOBJNAME "LAYER" ceng) nil)
     (command "layer" "n" ceng "c" "8" ceng "lt" "" "bylayer" ""))
     (while(setq a (ssget":s"))
     (setvar "cmdecho" 0)
     (command "change" a "" "p" "c" "bylayer" "la" ceng "lw" "bylayer" "")
     (command "clayer" ceng)
哎呀呀,发现bug了,刚才找了半天没找到编辑这个选项,求管理员删除
发表于 2014-6-10 13:43:03 | 显示全部楼层
继续写这个帖子  设备的都需要
GMT+8, 2025-5-20 11:00 , Processed in 0.204054 second(s), 30 queries , Gzip On.
