查看: 1233|回复: 0
[提问] 请问各位大哥,快速打印不能设置打印机还有纸张为变量么,麻烦大哥帮忙改改
发表于 2014-4-13 16:32:15 | 显示全部楼层 |阅读模式
(defun c:xa3() (/ zhizhang dayinji)
(setq zhizhang "A3")
(setq dayinji "Adobe PDF")
(dayin))
(defun c:a3() (/ zhizhang dayinji)
(setq dayinji "HP 5100")
(dayin))
(defun c:a2() (/ zhizhang dayinji)
(setq zhizhang "A2")
(setq dayinji "HP DJ500")
(dayin))
(defun dayin() (/ ent fx i maxpoint maxx0 maxy0 minpoint minx0 miny0 os pmax pmin ptlist ss sstk zhizhang dayinji)
  (vl-load-com)
  (setvar "cmdecho" 0) (setq os (getvar "osmode")   ss (ssadd)    sstk (ssadd)  )
  (princ "\n 请选取矩形图框:")
  (while (setq ss (ssget ":S" (list '(0 . "LWPOLYLINE") '(90 . 4))))
    ;(while (setq ss (ssget (list '(0 . "LWPOLYLINE") '(90 . 4))))
    (setq ent (ssname ss 0))
    (vla-getboundingbox (vlax-ename->vla-object ent) 'minpoint 'maxpoint)
    (setq pmax (vlax-safearray->list maxpoint)  pmin (vlax-safearray->list minpoint)
          minx0 (car pmin)  miny0 (cadr pmin)   maxx0 (car pmax)  maxy0 (cadr pmax))
    (if (>= (- maxx0 minx0) (- maxy0 miny0))   (setq fx "L")      (setq fx "P") )
        ;;;生成矩形的对角线并将对角线加入选择集sstk
    (entmake (list '(0 . "LINE") (cons 62 6) (cons 10 (list minx0 miny0 0)) (cons 11 (list maxx0 maxy0 0))))
    (setq sstk (ssadd (entlast) sstk))
    (entmake (list '(0 . "LINE") (cons 62 6) (cons 10 (list minx0 maxy0 0)) (cons 11 (list maxx0 miny0 0))))
        ;;;生成矩形的对角线并将对角线加入选择集sstk结束
    (setq ptlist (cons (list pmin pmax fx) ptlist))
  (initget "Y N ")
  (if (/= (getpoint (strcat "\n 确定批量打印?[确认(Y)/退出(N)]:<Y> ")) "N")
      (command "erase" sstk "")
      (repeat (setq i (length ptlist))
        (setq ent (nth (setq i (1- i)) ptlist )  pmin (car ent) pmax (cadr ent) fx (last ent))
        (command "_.PLOT" "Y" "" dayinji zhizhang "M" fx "N" "W" pmin pmax "F" "C" "Y" "TArch9.ctb" "Y" "N" "N" "N" "Y")
        (princ (strcat "\n 程序正在打印第" (itoa (- (length ptlist) i)) "张>>>>>>>> "))
  (setvar "osmode" os)                 ; 恢复捕捉模式
原来的快速打印见
http://bbs.mjtd.com/forum.php?mo ... mp;page=2#pid557901
17楼,我中间完全没改动
GMT+8, 2025-5-24 19:26 , Processed in 0.151968 second(s), 30 queries , Gzip On.
