- 积分
- 1643
- 明经币
- 个
- 注册时间
- 2007-12-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
(DEFUN C:CD () (command "layer" "m" "TXT-1" "c" "1" "" "")(command "LEADER" )(princ)) ;;引出线LEADER尺寸标注
1,我想不出现选项,直接COPY文字,引线进入到指定层DMM,文字进入TXT3层。。
贡献个焊缝程序,也不是我编的,同事给的。。。抛砖引玉,希望坛友们帮帮忙。。
(DEFUN C:HF () ;;绘制焊缝
(PRINC "请按逆时针")
(setq s (getvar "snapang"))
(setq p1 (getpoint "\nstart point:"))
(setq p2 (getpoint p1 "\End point:"))
(setq z (getreal "\nWeld size:"))
(COMMAND "OSNAP" "NONE")
(command "LAYER" "M" "WELD" "C" "8" "" "")
(setq p3 (polar p1 (angle p1 p2) (* 2 z)))
(command "arc" p1 "e" p3 "a" 180)
(setq p4 (polar p3 (- (angle p1 p2) (* 120 (/ PI 180))) Z))
(setq n (- (/ (distance p1 p2) z) 2))
(command "arc" p4 "c" p3 "a" 120)
(setq x 1)
(while (<= x n) (setq x (+ x 1)))
(setvar "snapang" (angle p1 p2))
(command "array" "last" "" "r" "" (- x 1) z)
(setvar "snapang" 0)
(command "OSNAP" "ENDP,MIDP,CENTER,NODE,QUADRANT,intersection,perpendicular")
(COMMAND "LAYER" "m" "DIM" "c" "1" "" "")
