查看: 6907|回复: 10
[源码] 源码分享 画圆柱截断线
发表于 2014-4-24 18:12:55 | 显示全部楼层 |阅读模式
  1. ;;;=================================================================*                                        *
  2. ;;;zml84  2010-03-18                                        *
  3. (defun c:tt ()
  4.   (if (and (setq pt1 (getpoint "\nPT1: "))
  5.     (setq pt2 (getpoint pt1 "\nPT2: "))
  6.       )
  7.     (progn
  8.       (tt-01 pt1 pt2)
  9.       (if (setq pt3 (getpoint pt2 "\nPT3: "))
  10. (tt-01 pt3
  11.         (polar pt3 (angle pt2 pt1) (distance pt2 pt1))
  12. )
  13.       )
  14.     ) ;
  15.   )
  16.   (princ)
  17. )
  18. ;;;=================================================================*                            *
  19. (defun tt-01 (pt1 pt2 / ang dist pt_tmp1)
  20.   (setq ang  (angle pt1 pt2)
  21. dist (distance pt1 pt2)
  22.   )
  23.   (setq pt_tmp1 (polar pt1 ang (* 0.5 dist)))
  24.   (command "_.pline"
  25.     "non"
  26.     pt1
  27.     "a"
  28.     "d"
  29.     (+ (* 180 (/ ang pi)) -45)
  30.     "non"
  31.     pt_tmp1
  32.     "non"
  33.     pt2
  34.     "d"
  35.     (+ (* 180 (/ ang pi)) 180 45)
  36.     "non"
  37.     pt_tmp1
  38.     ""
  39.   )
  40.   t
  41. )
个人觉得既然是圆柱,那么P1,P2不一定需要在它的投影矩形边上,可以考虑用它的半径参与计算其投影点,p3也一样 这样才能相当于用两个平行的刀砍掉圆柱的中间部分  发表于 2014-4-25 01:14
参与人数 3明经币 +4 收起 理由
lucas_3333 + 1 赞一个!
flyfox1047 + 1 赞一个!
xyp1964 + 2 赞一个!
发表于 2014-4-24 20:50:04 | 显示全部楼层
还算实用~
源码分享~ 推~
发表于 2014-4-24 23:46:44 | 显示全部楼层
挺好用,有点意见:
1、第二点的时候,设定捕捉垂足
2、第三点的时候,最好能把点自动控制在与第二点沿线上,或者设定捕捉最近点
理由:
1、避免1、2点不垂直
2、平时画图我都不打开最近点的,但是画剖断线不需要太精确,可以用最近点,不用人为切换
 楼主| 发表于 2014-4-25 08:39:34 | 显示全部楼层
  1. ;; put break pipe symbols and break pipe within
  2. (defun C:SYP(/ ang ang+ ang- cop osm p1 p2 pc pp sset symp)
  3. (alert "Pick two pipe sides to be trimmed at the end")
  4. (setq osm (getvar 'osmode))
  5. (setvar 'osmode 512)
  6. (setq p1 (getpoint "\nFirst Line: "))
  7. (setq sset (ssadd))
  8. (setq pp (ssname (ssget p1) 0))
  9. (ssadd pp sset)
  10. (setvar 'osmode 128)
  11. (setq p2 (getpoint p1 "\nSecond Line: "))
  12. (setq pc (mapcar '* (mapcar '+ p1 p2) (list 0.5 0.5 0.5)))
  13. (setq ang  (angle p1 p2)
  14.       ang- (- ang (/ pi 4))
  15.       ang+ (+ (+ ang pi) (/ pi 4))
  16.       ang- (vl-princ-to-string (/ (* ang- 180) pi))
  17.       ang+ (vl-princ-to-string (/ (* ang+ 180) pi))
  18. )
  19. (command "_PLINE"         "_non"         p1         "A"         "D"         ang-
  20.          "_non"         pc         "_non"         p2         "D"         ang+         "_non"
  21.          pc         ""
  22.         )
  23. (setq symp (entlast))
  24. (ssadd symp sset)
  25. (command "_copy" symp "" "_non" pc "_non" pc)
  26. (command "_rotate" (entlast) "" "_non" pc "180")
  27. (setvar 'osmode 512)
  28. (command "_move"
  29.          (entlast)
  30.          ""
  31.          "_non"
  32.          p1
  33.          "_non"
  34.          (getpoint p1 "\nNew Location: ")
  35. )
  36. (setq cop (entlast))
  37. (ssadd cop sset)
  38. (command "_trim" sset "" pause pause "")
  39. (setvar 'osmode osm)
  40. (princ)
  41.   )
669423907 + 1 赞一个!
发表于 2014-4-25 09:40:22 | 显示全部楼层
发表于 2014-4-25 09:53:40 | 显示全部楼层
更BT的情形:
真实的传说!  发表于 2014-4-29 21:23
呵呵,院成的演示一向很“牛”  发表于 2014-4-25 16:28
怎么BT的好东西,为啥不分享一下捏  发表于 2014-4-25 11:15
发表于 2014-4-25 10:33:00 | 显示全部楼层
院长无敌,境界高深啊!
发表于 2014-4-26 14:43:45 | 显示全部楼层
lyqiezi 发表于 2014-4-24 23:46
挺好用,有点意见:
1、第二点的时候,设定捕捉垂足
2、第三点的时候,最好能把点自动控制在与第二点沿线 ...
哈哈。。。跟我的作图习惯完全相同。。。顶一个
发表于 2014-4-28 15:30:07 | 显示全部楼层
不错,谢谢
发表于 2014-4-29 21:18:43 | 显示全部楼层
非常感谢楼主分享好程序,提一点小建议:
如果按这个比例,是不是可以省去第三点呢?
一點就好  发表于 2014-5-3 07:49
两点足够  发表于 2014-4-29 23:57
GMT+8, 2025-5-24 20:26 , Processed in 0.232526 second(s), 32 queries , Gzip On.
