查看: 9468|回复: 18
[讨论] 面积计算并统计(请帮忙修改)
发表于 2014-5-9 16:42:17 | 显示全部楼层 |阅读模式
存在问题:1程序比较扎乱,不简练。2面积标注与统计(实际上是求和)要选2次。请求修改为一次选择即可完成面积标注与统计标注,谢谢!程序如下:
;;;面积计算并统计
(defun c:mjjstj(/ ACADDOC ACADSPC OBJAREA OBJLLPOINT OBJRUPOINT SELECTIONSET TEXTBASEPOINT TEXTHEIGHT TEXTINDEX TEXTOBJ)
   (vl-load-com)
   (setq AcadDoc (vla-get-activedocument (vlax-get-acad-object)))
   (if (= (getvar "TILEMODE") 1)(setq AcadSpc (vla-get-modelspace AcadDoc))(setq AcadSpc (vla-get-paperspace AcadDoc)))
   (setq TextHeight (getdist "\n输入标注文字高度:")
Textbh (getstring "\n输入编号前缀:")
TextIndex 1
    (setq f (getfiled "指定输出文件路径" "" "xls" 1) f (open f "a"));;;指定输出文件路径
  (write-line "编号\t面积(㎡)" f)
     (ssget '((0 . "CIRCLE,LWPOLYLINE,ELLIPSE")))
(command "layer" "M" "计算面积" "C" "6" "" "LT" "CONTINUOUS" "" "");设置一个标注图层
(command "style" "tukou" "黑体" "0" "0.7" "0" "" "")
(setvar"dimzin"0);;保留小数位数时如果位数不足可以补零
   (setq Selectionset (vla-get-activeselectionset AcadDoc))
   (if (and TextHeight Selectionset TextIndex)
     (vlax-for Obj Selectionset
       (setq ObjArea (vla-get-area obj)
      ObjLlPoint nil
      ObjRuPoint nil
       (vla-GetBoundingBox Obj 'ObjLlPoint 'ObjRuPoint)
       (setq TextBasePoint (mapcar '(lambda(x y) (/ (+ x y) 2)) (vlax-safearray->list ObjLlPoint)(vlax-safearray->list ObjRuPoint))
      TextObj (vla-addtext AcadSpc (strcat Textbh (itoa TextIndex) "=" (rtos (/ ObjArea 1)2 2) "㎡") (vlax-3d-point TextBasePoint) TextHeight)
(write-line (strcat (strcat Textbh (itoa TextIndex)) "\t" (rtos (/ ObjArea 1)2 2) ) f)
       (vla-put-alignment TextObj acAlignmentCenter)
       (vla-put-TextAlignmentPoint TextObj (vlax-3d-point TextBasePoint))
    (setq TextIndex (1+ TextIndex))
(close f)
(princ "面积标注完毕,要统计请选择统计对象,不统计请按esc")
  (if (setq ss (ssget '((0 . "CIRCLE,LWPOLYLINE,ELLIPSE"))))
      (vl-load-com)
      (setq l (sslength ss) k 0 tarea 0 )
      (repeat l
        (setq ename (ssname ss k))
        (setq obj (vlax-ename->vla-object ename))
        (if (vlax-property-available-p obj "area")
          (setq tarea (+ (vlax-get-property obj 'area) tarea))
        (setq k (1+ k))
      (setq insPt0 (getpoint "\n请输入文字插入点: "))
(setq tarea (/ tarea 1))
(setq bb (strcat Textbh"="Textbh"1+"Textbh"2+...+"Textbh (itoa l)"="(rtos tarea 2 2)"㎡"))
(command "_text" insPt0 TextHeight "" bb 0)
(princ )
    (princ "\n未选择对象")
  (setvar "cmdecho" 1)
  (prin1)
发表于 2018-9-8 22:06:33 | 显示全部楼层
经过我的测试,这个插件不好用。
1,会自动生成mj模式的字体,没有该字体的会显示乱码
2,无法统计总面积
3,最终面积是平方毫米,不是平方米
综上,不建议下载。
就是这个,不建议下载。
发表于 2024-3-29 14:53:13 | 显示全部楼层
hao3ren 发表于 2014-5-9 17:33
自己修改修改啊,看你求了那么多帖子
我程序也不会写,大概改了下
(defun c:mjjstj(/ ACADDOC ACADSPC OB ...
算了几次,这个单位是平方毫米~
发表于 2019-7-3 12:38:33 | 显示全部楼层
改下就好了~
(write-line (strcat (strcat Textbh (itoa TextIndex)) "\t" (rtos (/ ObjArea 1e6)2 3) ) f)
发表于 2014-5-9 17:33:45 | 显示全部楼层
自己修改修改啊,看你求了那么多帖子
我程序也不会写,大概改了下
   (vl-load-com)
TextIndex 1
   (setq tarea 0 )
      ObjLlPoint nil
      ObjRuPoint nil
       (setq tarea (+ ObjArea tarea))
(close f)
(setq l (sslength ss))
  (prin1)
 楼主| 发表于 2014-5-9 18:14:54 | 显示全部楼层
自己修改修改啊,看你求了那么多帖子
我程序也不会写,大概改了下
谢谢!就是这样。满足要求。
发表于 2014-5-9 22:15:24 | 显示全部楼层
增加个从左到右从上到下的排序更好点
发表于 2014-5-9 22:23:31 | 显示全部楼层
(defun c:mjjstj(/ OBJLLPOINT OBJRUPOINT TEXTHEIGHT TEXTINDEX f ss e i obj l tarea)
  (vl-load-com)
  (setq TextHeight (getdist "\n输入标注文字高度:")Textbh(getstring "\n输入编号前缀:")
        f(getfiled "指定输出文件路径" "" "txt" 1));;;指定输出文件路径
  (if f(progn
         (setq f(open f "a")i 0 TextIndex 1 tarea 0
         (repeat(SSlength ss)
           (setq e(ssname ss i)i(1+ i)
                 Obj(vlax-ename->vla-object e))
           (setq l(cons(list(mapcar'(lambda(x y)(/ (+ x y)2))(vlax-safearray->list ObjLlPoint)(vlax-safearray->list ObjRuPoint))
                            (vla-get-Area(vlax-ename->vla-object e)))l)))
         (foreach x(vl-sort l'(lambda(x y)(<(last x)(last y))))
           (write-line(setq txt(strcat Textbh(itoa TextIndex)"\t"(setq area(rtos(last x)2 2))))f)
           (entmake(list'(0 . "TEXT")'(8 . "计算面积")(cons 10 (car x))(cons 1 (STRCAT(vl-string-subst"=""\t"txt)"㎡"))
                        (CONS 40 TextHeight)'(7 . "tukou")(cons 11 (car x))'(72 . 1)))
           (setq tarea(+(atof area)tarea)
                 TextIndex(1+ TextIndex)))
         (close f)
         (entmake(list'(0 . "TEXT")'(8 . "计算面积")(cons 10 (setq e(getpoint"\n请输入文字插入点: ")))
                      (cons 1(strcat Textbh"="Textbh"1+"Textbh"2+...+"Textbh (itoa TextIndex)"="(rtos tarea 2 2)"㎡"))
                        (CONS 40 TextHeight)'(7 . "tukou")(cons 11 e)'(72 . 1)))
    (alert"没有选择文件"))
flytoday + 1 排序杂乱~
发表于 2014-5-10 20:46:03 | 显示全部楼层
能不能再修改一下:1、将小数点向左移6位,小数位只留2位呢?
                  2、取消前辍
                  3、输出设一个开关,需要则输出,不需要则不输出
发表于 2014-5-10 20:46:36 | 显示全部楼层
自己修改修改啊,看你求了那么多帖子
我程序也不会写,大概改了下
                  2、取消前辍
 楼主| 发表于 2014-5-11 14:42:53 | 显示全部楼层
  (vl-load-com)
程序中   (cons 1(strcat Textbh"="Textbh"1+"Textbh"2+...+"Textbh (itoa TextIndex)"="(rtos tarea 2 2)"㎡"))
这句中的(itoa TextIndex)恐怕应该改为(itoa i),不然,统计项数目与实际不相符。
发表于 2015-7-12 10:23:55 | 显示全部楼层
                  2、取消前辍
发表于 2016-2-26 20:42:55 | 显示全部楼层
谢谢答主,请收下我的膝盖
GMT+8, 2025-5-4 04:50 , Processed in 0.217898 second(s), 30 queries , Gzip On.
