查看: 3239|回复: 10
[提问] 谁能破译三维实体DXF码
发表于 2014-5-14 16:24:14 | 显示全部楼层 |阅读模式
mnjoo ih m mk          ni ^*+0;:,4 ^*+0\^[ nf ^LR mnhqoqoqkjol QK o  mjqlffffffffffffff fqfffffffffffffffj:rooh n:rono >,27:>;:-
n rn _nm mnhqoqoqkjol |=0;&
{rn rn {rn {m {rn {rn |3*2/
{rn rn {rn {rn {l {n |,7:33
{rn rn {rn {rn {rn {k {rn {m |9><:
{rn rn {rn {j {i {l {rn {h 90-(>-; ,6183: |9><:
{rn rn {rn {g {f {l {rn {no 90-(>-; ,6183: |300/
{rn rn {rn {rn {nn {k |/3>1:r,*-9><:
{rn rn {rn nomgqj im o oqglhgklklkkoioolnh o oqjkjfnojfijkhknkol ro n ro 90-(>-;@) V V V V |9><:
{rn rn {rn {nm {nl {l {rn {nk 90-(>-; ,6183: |300/
{rn rn {rn {rn {nj {j |/3>1:r,*-9><:
{rn rn {rn nomgqj rnngqj o o roqglhgklklkkoioomgk oqjkjfnojfijkhknkkh n ro ro 90-(>-;@) V V V V |<0:;8:
{rn rn {rn {ni {nh {ng {nf 90-(>-; {i {rn |9><:
{rn rn {rn {mo {mn {l {rn {mm 90-(>-; ,6183: |300/
{rn rn {rn {rn {ml {g |/3>1:r,*-9><:
{rn rn {rn jfl rnngqj o roqglhgklklkkoioolnh o oqjkjfnojfijkhknkol ro rn ro 90-(>-;@) V V V V |<0:;8:
{rn rn {rn {mk {mj {ml {mi -:):-,:; {f {rn |<0:;8:
{rn rn {rn {nh {nn {mh {mg -:):-,:; {i {rn |<0:;8:
{rn rn {rn {nn {ni {mf {lo -:):-,:; {i {rn |<0:;8:
{rn rn {rn {ln {lm {nn {nf -:):-,:; {mn {rn |:;8:
{rn rn {rn {ll rnokqllhmmnkjlfmklh {lk gkqonmfghgjfmllhgf {nn {lj 90-(>-; _h *1410(1 |9><:
{rn rn {rn {rn {li {l {rn {lh -:):-,:; ,6183: |300/
{rn rn {rn {rn {ng {nm |/3>1:r,*-9><:
{rn rn {rn jfl im o ro oqglhgklklkkoioolnh oqjkjfnojfijkhknlfm rn ro ro 90-(>-;@) V V V V |<0:;8:
{rn rn {rn {lg {lf {nj {mi 90-(>-; {nl {rn |<0:;8:
{rn rn {rn {mh {nj {ko {kn -:):-,:; {f {rn |<0:;8:
{rn rn {rn {nj {mh {lm {km 90-(>-; {f {rn |:;8:
{rn rn {rn {kl rnokqllhmmnkjlfmkmf {kk gkqonmfghgjfmllfnh {ml {kj 90-(>-; _h *1410(1 |<0:;8:
{rn rn {rn {mj {mk {ni {mg 90-(>-; {f {rn |:;8:
{rn rn {rn {ki rklqmkkmkkkglnffkmk {lk nkjqnojfikgmffjghi {mh {kh 90-(>-; _h *1410(1 |<0:;8:
{rn rn {rn {ko {kg {nh {lo 90-(>-; {li {rn |:;8:
{rn rn {rn {ll o {ki ngoqj {mf {kf 90-(>-; _h *1410(1 |<0:;8:
{rn rn {rn {jo {ng {kg {jn -:):-,:; {mn {rn |<0:;8:
{rn rn {rn {ng {jo {mj {km -:):-,:; {mn {rn |):-+:'
{rn rn {rn {jn n {jm |):-+:'
{rn rn {rn {nf n {jl |,+->687+r<*-):
{rn rn {rn fhgqjojhnlfgojfjgl nmqoojhnlfgojfjghg hiqhmflgkfmghjikki roqkhfnioiolifnfionh roqkhfnioiolifnfionm oqhljlfgoofoiijfjjg V V |300/
{rn rn {rn {rn {kg {mo |/3>1:r,*-9><:
{rn rn {rn gnoqhkffffffffffgf rmgqmjooooooooooook o o o n n o o 90-(>-;@) V V V V |<0:;8:
{rn rn {rn {lf {ml {jo {jk -:):-,:; {nl {rn |<0:;8:
{rn rn {rn {ml {lg {jj {ji -:):-,:; {nl {rn |<0:;8:
{rn rn {rn {jj {mf {mk {kn 90-(>-; {li {rn |:;8:
{rn rn {rn {ki o {kl kljqj {ko {jh 90-(>-; _h *1410(1 |:;8:
{rn rn {rn {lk rnmhqjooooooooooonn {kk nmhqjooooooooooonn {lm {jg -:):-,:; _h *1410(1 |):-+:'
{rn rn {rn {kn n {jf |):-+:'
{rn rn {rn {mi n {io |,+->687+r<*-):
{rn rn {rn ikmqffkmgionfkokoi rigqjojhnlfgojfjgmf hiqhmflgkfmghjilgf oqkhfnioiolifnfiooi oqkhfnioiolifnfioih oqhljlfgoofoiijfjmj V V |):-+:'
{rn rn {rn {lo n {in |,+->687+r<*-):
{rn rn {rn noohqhhfoinhohmmhj rfhqhhfoinhohmmhknl lnqgonhlnmfijllfif roqkhfnioiolifnfiooi oqkhfnioiolifnfioih oqhljlfgoofoiijfjmj V V |<0:;8:
{rn rn {rn {mf {jj {ln {jn 90-(>-; {li {rn |,+->687+r<*-):
{rn rn {rn nomgqj im o o rn o V V |<0:;8:
{rn rn {rn {lm {ln {lg {jk 90-(>-; {mn {rn |:;8:
{rn rn {rn {im o {ll kljqj {kg {il 90-(>-; _h *1410(1 |/061+
{rn rn {rn nomgqj im o |/061+
{rn rn {rn flgqmjoooooooooonn rmgqmkfffffffffffmf nlgqjnmligflinhloi |:;8:
{rn rn {rn {im rklqmkkmkkkglnfflfj {kk nkjqnojfikgmffjghk {jo {ik 90-(>-; _h *1410(1 |<0:;8:
{rn rn {rn {kg {ko {lf {ji 90-(>-; {li {rn |:;8:
{rn rn {rn {kl o {im ngoqj {jj {ij 90-(>-; _h *1410(1 |,+->687+r<*-):
{rn rn {rn nomgqj rnngqj o rn o o V V |,+->687+r<*-):
{rn rn {rn gnoqhj rmgqmkfffffffffffkl nlgqjnmligflinhlof n o o V V |/061+
{rn rn {rn jfl rnngqj o |/061+
{rn rn {rn iglqmkffffffffffgf rmgqmkfffffffffffli nlgqjnmligflinhloi |/061+
{rn rn {rn nomgqj rnngqj o |):-+:'
{rn rn {rn {jn o {ii |,+->687+r<*-):
{rn rn {rn jfl im o n o o V V |,+->687+r<*-):
{rn rn {rn inlqhmoflgmfmhhmjl knqmhfoinhohmmhkkf lnqgonhlnmfijllfkk oqkhfnioiolifnfionh roqkhfnioiolifnfionm oqhljlfgoofoiijfjjg V V |,+->687+r<*-):
{rn rn {rn jfl rnngqj o o n o V V |/061+
{rn rn {rn jfl im o |
发表于 2014-5-14 17:49:01 来自手机 | 显示全部楼层
有何意义?
 楼主| 发表于 2014-5-15 23:44:16 | 显示全部楼层
意义当然有呀。可以更方便的操作三维实体。。。可以了解桌子公司的程序的结构。。说不定这里有CAD的核心技术呢。
发表于 2014-5-19 17:33:35 | 显示全部楼层
走都不会,想跑啊
发表于 2014-5-19 18:00:24 | 显示全部楼层
如果是优秀的数据结构,桌子公司 不会藏着 不用。一定是数据结构本身有问题。
 楼主| 发表于 2014-5-20 08:20:13 | 显示全部楼层
meja 发表于 2014-5-19 17:33
走都不会,想跑啊
走谁不会。
发表于 2014-7-1 14:53:14 | 显示全部楼层
这是ACIS实体的数据,当时Autodesk购买使用权。其实也没什么神秘的,下面的函数就能将其解码,但没啥用,最多能得到长方体的长宽高等数据。如果你使用AutoCAD命令acisout将目标实体输出成SAT文件,里面显示差不多的内容。
;其中data就是我们通过entget的到数据
(defun decode-code-ele-data (data / liste)
  (foreach n data
      (if (= (car n) 1)
        (setq liste (cons (cons 1 (decode-code-acis (cdr n))) liste))
        (setq liste (cons n liste))
  (reverse liste)
(defun decode-code-acis        (s / n l)
  (setq n "")
  (while (> (strlen s) 0)
    (setq l (substr s 1 1)
          s (substr s 2)
          n (strcat n
                    (if        (= " " l)
                      (chr (- 159 (ascii l)))
参与人数 1明经币 +2 收起 理由
Gu_xl + 2 赞一个!
 楼主| 发表于 2014-7-2 21:19:38 | 显示全部楼层
行家一出手,就知有没有。
发表于 2014-12-19 11:53:39 | 显示全部楼层
谁还知道更多这方面的资料呀,我急需啊
发表于 2014-12-19 11:55:57 | 显示全部楼层
我正要寻找用lisp  vlisp中关于三维操作的资料,我想编个三维建模修改出图的小程序
GMT+8, 2025-5-19 11:40 , Processed in 0.186163 second(s), 34 queries , Gzip On.
