查看: 1317|回复: 1
[提问] 请教,以下内容要如何理解?
发表于 2014-5-17 08:46:07 | 显示全部楼层 |阅读模式
To set and restore system variables, you can also the ai_sysvar function.
This function is available in AutoCAD since a while.
It's defined in acaddoc20XX.lsp (ai_utils.lsp or acad.mnl in older versions), so it's automatically loaded in each document.
Quote
;;; --- ai_sysvar ------------------------------------------
;;; Change system variable settings and save current settings
;;; (Note: used by *merr* to restore system settings on error.)
;;; The <vars> argument is used to...
;;;   restore previous settings (ai_sysvar NIL)
;;;   set a single sys'var (ai_sysvar  '("cmdecho" . 0))
;;;   set multiple sys'vars (ai_sysvar '(("cmdecho" . 0)("gridmode" . 0)))
;;; defun-q is needed by Visual Lisp for functions which redefine themselves.
;;; it is aliased to defun for seamless use with AutoLISP.
Anywhere in the code, you can call ai_sysvar to save the current value of one or more sysvar and set it a new value (or not).
Example:
    1. ;; save and set "osmode" to 0
    2. (ai_sysvar '("osmode" . 0))
    3. ...
    4. ;; save and set "orthomode" to 1 and only save "autosnap"
    5. (ai_sysvar '(("orthomode" . 1) ("autosnap" . nil)))
    6. ...
    7. ;; restor all sysvars
    8. (ai_sysvar nil)
<EDIT> I forgot to say, the implementation of ai_sysvar is quite interesting with the use of defun-q which allows to store the list of var names ans values within the function.
发表于 2014-5-17 09:06:30 | 显示全部楼层
找到ai_sysvar的定义,一切都清楚了
http://www.askcad.com/bbs/thread-47222-1-1.html
GMT+8, 2025-5-24 18:37 , Processed in 0.185659 second(s), 26 queries , Gzip On.
