查看: 23003|回复: 38
[源码] 把参照绝对路径改为相对路径
发表于 2014-5-23 15:42:07 | 显示全部楼层 |阅读模式
;这几天修改别人的图,被参照图的绝对路径搞的很烦,一怒之下,写了一个改参照绝对路径为相对路径的lisp,还不够完满,运行效率不高,望高手帮修改指教.
(defun c:xfx (/ ss ffg k path files path2 path3 tmq m m2 n n2 total tst temp xpath i obj)
  (vl-load-com)
(defun ffg-getfolder (msg startpath / winshell shfolder ffg path1 catchit)
  (setq winshell (vlax-create-object "Shell.Application"))
  (setq shfolder (vlax-invoke-method winshell 'browseforfolder 0 msg 1 startpath))
  (setq catchit (vl-catch-all-apply '(lambda ()
           (setq shfolder (vlax-get-property shfolder 'self))
           (setq path1 (vlax-get-property shfolder 'path))
  (if (vl-catch-all-error-p catchit)
    nil
    path1
(setvar "cmdecho" 0);主程序
  (setq tst nil
m 0
ss (ssget "x" '((0 . "insert")))
  (setq ffg (getvar "dwgprefix"));获取当前文件路径,
  (setq k (vl-string-position 92 ffg 3 nil));查找第二个"\",减少选择路径对话框展开层数(删除硬盘符号和第一级目录),不会有人把文件放在硬盘根目录吧?
  (setq path (ffg-getfolder "请选择参照文件所在的目录:" (substr ffg 1 k)));获取参照目录
  (setq files (vl-directory-files path "*.dwg" 1));列出目录下所有文件
  (setq m (vl-string-mismatch ffg path 0 0));前面有多少个相同的字符
  (if (>= m (strlen ffg))
      (setq tst t)
    );_ 结束prgon
      (setq n 0
     n2 0
     path3 ""
     tmq (substr path 1 m)
      );参照路径前面相同部分
      (setq path2 (vl-string-left-trim tmq ffg));删除参照路径前面相同部分
      (setq m2 (strlen path2))
      (repeat m2
(setq temp (ascii (substr path2 (- m2 n) 1)))
(if (= temp 92)
   (setq n2 (+ 1 n2))
);_ 结束if
(setq n (+ 1 n))
      );_ 结束repeat
      (repeat n2
(setq path3 (strcat ".." (chr 92) path3))
      );_ 结束repeat
    );_ 结束progn
  );_ 结束if
  (if tst
    (setq xpath (vl-string-left-trim ffg path));删除参照前面的绝对路径,
    (setq xpath (substr path (+ 1 m)))
  (setq i 0
total 0
  (repeat (sslength ss)
    (setq obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget (ssname ss i))))))
    (if (and
   (= (vla-get-isxref obj) :vlax-true)
   (vl-position (strcat (vla-get-name obj) ".dwg") files);参照图块是否在文件列表
(if (= xpath "")
     (vla-put-path obj (strcat "." (chr 92) xpath (vla-get-name obj) ".dwg"))
   );_ 结束progn
     (if tst
       (vla-put-path obj (strcat "." (chr 92) xpath (chr 92) (vla-get-name obj) ".dwg"));目录前面添加".\",目录后面添加"\"
       (vla-put-path obj (strcat path3 xpath (chr 92) (vla-get-name obj) ".dwg"));
     );_ 结束if
   );_ 结束progn
);_ 结束if
(setq total (+ 1 total))
      );_ 结束progn
    );_ 结束if
    (setq i (1+ i))
  );_ 结束repeat
  (command "-xref" "r" "*")
  (if (> total 0)
    (prompt (strcat "\n总共有 \" " (itoa total) " \"个参照物体路径改为相对路径."))
    (prompt (strcat "\n未找到合适的参照物体路径!"))
  (setvar "cmdecho" 1)
);_ 结束defun
 楼主| 发表于 2014-5-23 20:40:23 来自手机 | 显示全部楼层
参照有时候很方便的,比如签名,出图日期,几十张图纸,改一个文件就可以搞定。
回复 支持 2 反对 0
发表于 2014-5-23 18:41:31 来自手机 | 显示全部楼层
最讨厌设计院的图插入参照啦………你说没事搞布局与参照干嘛………烦不烦啊…………给别人电子档时候参照没给打开缺这缺那……有时让人打印出来没内容………电子就是让人看滴舒服………别跟哥讲版权别跟哥讲院里不让给…借口很多…………电子图用于施工、预算比较方便点…给人方便给已方便………………希望那个什么什么设计别参照啦………别用布局啦
发表于 2022-10-26 18:52:16 | 显示全部楼层
;改一下,增加如果参照存在,只改路径,增加支持父目录,子目录,孙目录。。。。。。。
(defun c:WBCZ (/ file scale1 pt0 i total ss filename ent obj elist blkdef)
(vl-load-com)
(defun ffg-path-xiangdui (path-file / tst m m2 ffg n n2 path3 path2 temp xpath path-xiangdui)
  (setq tst nil
    m 0
  (setq m (vl-string-mismatch ffg path-file 0 0))
    (setq tst t)
    (setq n 0
      n2 0
      path3 ""
    (setq path2 (substr ffg (1+ m)))
    (repeat m2
     (if (= temp 92)
      (setq n2 (+ 1 n2))
     (setq n (+ 1 n))
    (repeat n2
  (setq xpath (substr path-file (1+ m)))
  (if (= xpath "")
    (setq path-xiangdui (strcat "." (chr 92) xpath))
    (if tst
     (setq path-xiangdui (strcat path3 xpath))
  path-xiangdui
(if (setq file (getfiled "选择参照文件" (strcat (getvar "dwgprefix") "\\") "dwg" 16))
   (if (= (tblobjname "block" (vl-filename-base file)) nil)
     (setq scale1 (getvar "userr4"))
     (if (equal scale1 0 0.0001)
       (setq scale1 1.00)
       (setvar "userr4" scale1)
     (setq scale1 (getreal (strcat "\n请输入图形放大系数 < " (rtos scale1 2 2) " >:"))
       scale1 (if scale1
           scale1
           (getvar "userr4")
     (setq pt0 (getpoint "\n指定插入点:"))
     (setq i 0
       total 0
     (setq ss (ssget "x" '((0 . "insert"))))
      (if (and
       (= (vla-get-name obj) (vl-filename-base file))
    (setq filename (vla-get-name obj))
    (vla-put-path obj (ffg-path-xiangdui file))
    (setq total (1+ total))
      (setq i (1+ i))
     (prompt (strcat "\n参照已经存在,仅仅修改路径。修改了 " (itoa total) " 个名称为\" " filename " \"的参照块路径."))
(if pt0
   (command "-xref" "a" file "s" scale1 "r" "0.0" pt0)
   (setq ent (entget (ssname (ssget "L" '((0 . "insert"))) 0)))
   (setq obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 ent))))
   (setq elist (entget (tblobjname "block" (cdr (assoc 2 ent)))))
   (setq blkdef (vlax-ename->vla-object (cdr (assoc 330 elist))))
   (vla-put-path blkdef (ffg-path-xiangdui file))
(command "_xref" "r" "*")
发表于 2014-5-24 10:03:16 | 显示全部楼层
支持一下!
发表于 2014-5-24 13:53:28 | 显示全部楼层
傻才不用参照---
发表于 2014-5-29 22:37:11 | 显示全部楼层
我也到过,别人发的图,里面的外部参照就不发,到处缺图,烦
发表于 2014-5-30 09:12:14 | 显示全部楼层
很实用
发表于 2014-5-30 10:59:42 | 显示全部楼层
奇怪 需要其他的系统函数还是什么情况 为啥我cad2014加载不了呢
发表于 2014-5-30 13:11:31 | 显示全部楼层
这么多代码啊,看看下面这个,论坛里面找来的,具体谁的忘了,时间有点久了
  1. ;;;;参照图块路径改为“相对路径” 且 自动重载XREF
  2. (defun C:Tools-BLK-XrefPathAutoLoad (/ ssg xpath i obj enl elist blkdef path n)
  3.   (setq ssg (ssget "x" '((0 . "insert"))))
  4.   (setq XPath (getvar "dwgprefix")) ;_取得当前文档路径
  5.   (setq i 0)
  6.   (setq n 0)
  7.   (if ssg
  8.     (repeat (sslength ssg)
  9.       (setq obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (setq enl (entget (ssname ssg i)))))))
  10.       (if (= (vla-get-isxref obj) :vlax-true) ;_判断给定的图块是否为XRef图块
  11.         (progn
  12.           ;;(vla-put-path obj (strcat xpath (vla-get-name obj) ".dwg"));_参照图块路径改为“绝对路径
  13.           (setq elist (entget (tblobjname "block" (cdr (assoc 2 enl))))) ;_获取参照图块的图元表
  14.           (setq blkdef (vlax-ename->vla-object (cdr (assoc 330 elist))))
  15.           (setq path (vla-get-path blkdef)) ;_取得外部参照的路径
  16.           (setq path (vl-filename-base path)) ;_去掉文件的路径和扩展名,返回文件的名称
  17.           (vla-put-path blkdef (strcat ".\" path ".dwg")) ;_参照图块路径改为“相对路径”
  18.     (setq n (1+ n))
  19.         )
  20.       )
  21.       (setq i (1+ i))
  22.     )
  23.   )
  24.   (if (> n 0)
  25.     (progn
  26.       (command "_xref" "r" "*")
  27.       (princ "\n**** Xref路径已改为“相对路径”****")
  28.     )
  29.     (princ "\n**** 没有外部参照 或 外部参照没有加载 ****")
  30.   )
  31.   (princ)
  32. )
 楼主| 发表于 2014-6-3 18:12:16 | 显示全部楼层
你这段代码好象不能修改参照路径更改后的图,比如:原来被参照的文件放在文件根目录下,现在改为子目录下.
GMT+8, 2025-9-14 04:17 , Processed in 0.326092 second(s), 31 queries , Gzip On.
