查看: 1282|回复: 2
[提问] 如何框选所有物体过滤不同的物体改变其颜色
发表于 2014-5-24 09:46:57 | 显示全部楼层 |阅读模式
如图框选所有直线和文字,直线颜色变成红色,文字颜色变成黄色.谢谢
  1. (defun c:TT()
  2. (setq ss (ssget))
  3.       (if (= t1 "TEXT")
  4. (PROGN
  5. (COMMAND "CHPROP" ?? "" "Color" "2" "" )
  6. )
  7. )
  8.       (if (= t1 "LINE")
  9. )
  10. (COMMAND "CHPROP" ?? "" "Color" "1" "" )
  11. )
  12. )
  13. )
发表于 2014-5-24 10:02:57 | 显示全部楼层
  1. (defun c:tt ()
  2.   (setq ss (ssget '((0 . "text,line"))))
  3.   (setq ss1 (ssget "p" '((0 . "text"))))
  4.   (command "chprop" ss1 "" "color" "2" "")
  5.   (command "select" ss "")
  6.   (setq ss1 (ssget "p" '((0 . "line"))))
  7.   (command "chprop" ss1 "" "color" "1" "")
  8.   (princ)
  9. )
 楼主| 发表于 2014-5-24 13:37:10 | 显示全部楼层
xyp1964 发表于 2014-5-24 10:02
感谢xyp1964 的帮助,谢谢
就是代码又臭又长  发表于 2014-5-24 15:49
GMT+8, 2025-5-24 20:03 , Processed in 0.223668 second(s), 36 queries , Gzip On.
