| 高飞鸟大师的源码
  (defun C:am (/ ss l i totalarea ename obj entarea)
  (if (setq ss (ssget))
      (vl-load-com)
      (setq modelspace (vla-get-Modelspace (vla-get-activeDocument (vlax-get-acad-object))))
      (setq l (sslength ss) i 0 totalarea 0 totlength 0)
      (repeat l
        (setq ename (ssname ss i))
        (setq obj (vlax-ename->vla-object ename))
(if (vlax-property-available-p obj "area")
          (setq totalarea (+ (vlax-get-property obj 'area) totalarea))
(if (= (cdr (assoc 0 (entget ename))) "MLINE")
   (setq totlength (+ totlength (ml-length ename)))
   (setq totlength (+ totlength (vlax-curve-getdistatparam ename (vlax-curve-getendparam ename))))
        (setq i (1+ i))
      (setq text1 (strcat "总面积为: " (rtos totalarea 2 4) "平方单位")
     text2 (strcat "总长度为: " (rtos totlength 2 4) "单位")
      (if (setq insertpt (getpoint "\n请输入文字插入点: "))
(if (setq height (getdist "\n请输入文字高度:"))
   (setq insertp1 (vlax-3d-point insertpt)
  insertp2 (vlax-3d-point (polar insertpt (* 1.5 Pi) (* 1.5 height)))
         textobj1 (vla-addtext modelspace text1 insertp1 height)
  textobj2 (vla-addtext modelspace text2 insertp2 height)
(defun ml-length (ename / j d ptlist)
  (foreach n (entget ename)
    (if (= (car n) 11)
      (setq ptlist (cons (cdr n) ptlist))
  (reverse ptlist)
  (setq j 0 d 0)
  (repeat (1- (length ptlist))
    (setq d (+ d (distance (nth j ptlist) (nth (1+ j) ptlist))))
    (setq j (1+ j))
  d
 高飞版主的代码是将结果插入到文档中的,我想能不能用下面的的方式,即弹出结果?
  ;;;调用vb输入框 by Xran
;;;promptstr 提示信息
;;;title 窗体标题栏信息
;;;default 缺省值
(defun inputbox (promptstr title default)
  (vla-eval (vlax-get-acad-object)
      (strcat "ThisDrawing.setVariable "USERS5",inputBox (""
        promptstr
        title
        default
  (getvar "users5")
