查看: 5830|回复: 10
[源码] 统计线长及面积对话框函数
发表于 2014-6-4 23:04:40 | 显示全部楼层 |阅读模式
统计的线长,面积一般会显示在命令行,或发送到剪贴板,如果同时统计面积和线长的时候,发送到剪贴板就不那么方便了。
因此采用对话框的形式,可以调整两种单位,转换米制或毫米制(1:1),精度显示,补零。分别复制。
对话框函数 (sk_area_dcl aa cd )aa为面积数值 cd为长度数值
统计代码采用该贴代码。
请帮忙修改下,谢谢!http://bbs.mjtd.com/forum.php?mo ... &fromuid=338795
  1. (defun c:tt(/ ename i l modelspace obj ss text1 text2 totalarea totlength)
  2.   (if (setq ss (ssget'((0 . "*line,arc,circle,ellipse"))))
  3.     (progn
  4.       (vl-load-com)
  5.       (setq modelspace (vla-get-Modelspace (vla-get-activeDocument (vlax-get-acad-object))))
  6.       (setq l (sslength ss) i 0 totalarea 0 totlength 0)
  7.       (repeat l
  8.         (setq ename (ssname ss i))
  9.         (setq obj (vlax-ename->vla-object ename))
  10.   (if (vlax-property-available-p obj "area")
  11.     (setq totalarea (+ (vlax-get-property obj 'area) totalarea))
  12.     )
  13.   (if (= (cdr (assoc 0 (entget ename))) "MLINE")
  14.     (setq totlength (+ totlength (ml-length ename)))
  15.     (setq totlength (+ totlength (vlax-curve-getdistatparam ename (vlax-curve-getendparam ename))))
  16.     )
  17.   (setq i (1+ i))
  18.   )
  19.       (setq text1 (rtos (* totalarea 0.000001) 2 4))
  20.       (setq text2 (rtos (* totlength 0.001) 2 4))
  21.       (sk_area_dcl  totalarea totlength)
  22.     )
  23.   )
  24.   (princ)
  25. )
  26. (defun ml-length (ename / j d ptlist)
  27.   (foreach n (entget ename)
  28.     (if (= (car n) 11)
  29.       (setq ptlist (cons (cdr n) ptlist))
  30.     )
  31.   )
  32.   (reverse ptlist)
  33.   (setq j 0 d 0)
  34.   (repeat (1- (length ptlist))
  35.     (setq d (+ d (distance (nth j ptlist) (nth (1+ j) ptlist))))
  36.     (setq j (1+ j))
  37.   )
  38.   d
  39. )
  40. (defun sk_area_dcl(aa cd / dcl_id chk CLIP_BORD DCL F HTM  STR)
  41.   (setq bak_dimzin(getvar 'dimzin))
  42.   (if (and aa cd (numberp aa)(numberp cd))
  43.     (progn
  44.   (setq DCL (vl-filename-mktemp nil nil ".Lsp"))
  45.   (setq f (open dcl "w"))
  46.   (foreach s '(
  47. "sk_area:dialog {"
  48. "    label = \"统计\" ;"
  49. "    :boxed_column {"
  50. "        fixed_height = true ;"
  51. "        height = 6 ;"
  52. "        label = \"统计\" ;"
  53. "        width = 70 ;"
  54. "        :column {"
  55. "         children_alignment = left ;"
  56. "                    fixed_width = true ;"
  57. "                    width = 50 ;"
  58. "            :row {"
  59. "                    fixed_width = true ;"
  60. "                    width = 35 ;"
  61. "    children_alignment = top ;"
  62. "                :edit_box {"
  63. "                    key = \"sk_total_l\" ;"
  64. "                    label = \"总长度:\" ;"
  65. "                    fixed_width = true ;"
  66. "                    width = 20 ;"
  67. "                }"
  68. "                :radio_row {"
  69. "                    alignment = left ;"
  70. "                    fixed_width = true ;"
  71. "                    width = 16 ;"
  72. "                    :radio_button {"
  73. "                        label = \"米\" ;"
  74. "         value = \"1\" ;"
  75. "         key = \"sk_radio1\" ;"
  76. "                    fixed_width = true ;"
  77. "                    width = 8 ;"
  78. "                    }"
  79. "    spacer;"
  80. "    spacer;"
  81. "                    :radio_button {"
  82. "                        label = \"毫米\" ;"
  83. "         key = \"sk_radio2\" ;"
  84. "                    fixed_width = true ;"
  85. "                    width = 8 ;"
  86. "                    }"
  87. "                }"
  88. "    spacer;"
  89. "    spacer;"
  90. "    spacer;"
  91. "         :popup_list {"
  92. "                    label = \"精度\" ;"
  93. "                    key = \"sk_jingdu1\" ;"
  94. "                    fixed_width = true ;"
  95. "                    width = 20 ;"
  96.        "}"
  97. "                :button {"
  98. "                    fixed_width = true ;"
  99. "                    key = \"sk_copy1\" ;"
  100. "                    label = \"复制(&L)\" ;"
  101. "                    width = 4 ;"
  102. "                }"
  103. "            }"
  104. "            :row {"
  105. "    children_alignment = top ;"
  106. "                :edit_box {"
  107. "                    key = \"sk_total_a\" ;"
  108. "                    label = \"总面积:\" ;"
  109. "                    fixed_width = true ;"
  110. "                    width = 20 ;"
  111. "                }"
  112. "                :radio_row {"
  113. "                    alignment = left ;"
  114. "                    fixed_width = true ;"
  115. "                    width = 16 ;"
  116. "         children_alignment = left ;"
  117. "                    :radio_button {"
  118. "                        label = \"平方米\" ;"
  119. "         key = \"sk_radio3\" ;"
  120. "         value = \"1\" ;"
  121. "                    fixed_width = true ;"
  122. "                    width = 8 ;"
  123. "                    }"
  124. "                    :radio_button {"
  125. "                        label = \"平方毫米\" ;"
  126. "         key = \"sk_radio4\" ;"
  127. "                    fixed_width = true ;"
  128. "                    width = 8 ;"
  129. "                    }"
  130. "                }"
  131. "         :popup_list {"
  132. "                    label = \"精度\" ;"
  133. "                    key = \"sk_jingdu2\" ;"
  134. "                    fixed_width = true ;"
  135. "                    width = 20 ;"
  136.        "}"
  137. "                :button {"
  138. "                    fixed_width = true ;"
  139. "                    key = \"sk_copy2\" ;"
  140. "                    label = \"复制(&A)\" ;"
  141. "                    width = 4 ;"
  142. "                }"
  143. "            }"
  144. "        }"
  145. "        :boxed_column {"
  146. "            alignment = centered ;"
  147. "            children_alignment = centered ;"
  148. "         :toggle {"
  149. "    key = \"sk_dimzin1\" ;"
  150. "    label = \"去零\" ;"
  151. "    value = \"1\" ;"
  152. "}"
  153. "            :edit_box {"
  154. "                key = \"sk_paste1\" ;"
  155. "                label = \"当前剪贴板文字:\" ;"
  156. "                    fixed_width = true ;"
  157. "                    width = 50 ;"
  158. "            }"
  159. "    spacer;"
  160. "    spacer;"
  161. "    spacer;"
  162. "        }"
  163. "    spacer;"
  164. "    }"
  165. "    spacer;"
  166. "    ok_only;"
  167. "}"
  168.   )
  169.   (write-line s f))
  170.   (close f)
  171.   (setq dcl_id (load_dialog DCL))
  172.   (vl-file-delete DCL)
  173.   (if (> dcl_id 0)
  174.     (progn
  175.       (setq htm (vlax-create-object "htmlfile"))
  176.       (defun sk_GetClipboard();获取剪切板
  177.         (setq Clip_Bord (Vlax-Get-Property (Vlax-Get htm 'ParentWindow) 'ClipboardData))
  178.         (Vlax-Invoke Clip_Bord 'GetData "text")
  179.         )
  180.       (defun sk_SetClipboard(clip);设置剪切板
  181.         (Vlax-Invoke Clip_Bord 'SetData "text" clip)
  182.         )
  183.       (defun sk_ClearClipboard();清空
  184.         (setq Clip_Bord (Vlax-Get-Property (Vlax-Get htm 'ParentWindow) 'ClipboardData))
  185.         (Vlax-Invoke Clip_Bord 'ClearData "text")
  186.         )
  187.       (defun Show_list(Key Newlist)
  188.         (start_list Key)
  189.         (mapcar 'add_list Newlist)
  190.         (end_list)
  191.         )
  192.       (new_dialog "sk_area" dcl_id)
  193.       (if(setq str(sk_GetClipboard))(set_Tile "sk_paste1" str))
  194.       (or jingdu01 (setq jingdu01 3))
  195.       (or jingdu02 (setq jingdu02 3))
  196.       (or sk_dimzin1 (setq sk_dimzin1 1))
  197.       (Show_list "sk_jingdu1" '( "0" "00" "000" "0000" "00000" "000000" "0000000" "00000000"))
  198.       (Show_list "sk_jingdu2" '( "0" "00" "000" "0000" "00000" "000000" "0000000" "00000000"))
  199.       (if (and jingdu01 (= (type jingdu01) 'INT))(set_tile "sk_jingdu1" (itoa (1- jingdu01))))
  200.       (if (and jingdu02 (= (type jingdu02) 'INT))(set_tile "sk_jingdu2" (itoa (1- jingdu02))))
  201.       (if (and sk_dimzin1 (= (type sk_dimzin1) 'INT))(progn (set_tile "sk_dimzin1" (itoa sk_dimzin1))(if(= sk_dimzin1 1)(setvar 'dimzin 8)(setvar 'dimzin 0))))
  202.       (if cd(set_Tile "sk_total_l" (if (= (get_Tile "sk_radio1") "1")(rtos (* cd 0.001) 2 jingdu01)(rtos cd 2 jingdu01))))
  203.       (if aa(set_Tile "sk_total_a" (if (= (get_Tile "sk_radio3") "1")(rtos (* aa 0.000001) 2 jingdu02)(rtos aa 2 jingdu02))))
  204.     (Action_Tile "sk_copy1" "(sk_SetClipboard (get_Tile \"sk_total_l\"))
  205.     (if (setq str (sk_GetClipboard))(set_Tile \"sk_paste1\" str))")
  206.     (Action_Tile "sk_copy2" "(sk_SetClipboard (get_Tile \"sk_total_a\"))
  207.     (if (setq str (sk_GetClipboard))(set_Tile \"sk_paste1\" str))")
  208.       (Action_Tile "sk_jingdu1" "(setq jingdu01 (1+ (atoi(get_tile \"sk_jingdu1\" )))) (set_Tile \"sk_total_l\" (if (= (get_Tile \"sk_radio1\") \"1\")(rtos (* cd 0.001) 2 jingdu01)(rtos cd 2 jingdu01)))")
  209.       (Action_Tile "sk_jingdu2" "(setq jingdu02 (1+ (atoi(get_tile \"sk_jingdu2\" )))) (set_Tile \"sk_total_a\" (if (= (get_Tile \"sk_radio3\") \"1\")(rtos (* aa 0.000001) 2 jingdu02)(rtos aa 2 jingdu02)))")
  210.       (Action_Tile "sk_radio1" "(set_Tile \"sk_total_l\" (rtos (* cd 0.001) 2 jingdu01))")
  211.       (Action_Tile "sk_radio2" "(set_Tile \"sk_total_l\" (rtos cd 2 jingdu01))")
  212.       (Action_Tile "sk_radio3" "(set_Tile \"sk_total_a\" (rtos (* aa 0.000001) 2 jingdu02))")
  213.       (Action_Tile "sk_radio4" "(set_Tile \"sk_total_a\" (rtos aa 2 jingdu02))")
  214.       (Action_Tile "sk_dimzin1" "(setq sk_dimzin1 (atoi (get_tile \"sk_dimzin1\" )))(if(= sk_dimzin1 1)(setvar 'dimzin 8)(setvar 'dimzin 0))
  215.       (set_Tile \"sk_total_l\" (if (= (get_Tile \"sk_radio1\") \"1\")(rtos (* cd 0.001) 2 jingdu01)(rtos cd 2 jingdu01)))
  216.       (set_Tile \"sk_total_a\" (if (= (get_Tile \"sk_radio3\") \"1\")(rtos (* aa 0.000001) 2 jingdu02)(rtos aa 2 jingdu02)))
  217.       ")
  218.     (setq chk (start_dialog))
  219.   ))
  220.   (unload_dialog dcl_id)
  221.       )
  222.     )
  223.   (and bak_dimzin(setvar 'dimzin bak_dimzin))
  224.   (princ)
  225.   )
选择完结果就出来了,又何必用对话框?  发表于 2014-6-5 18:36
参与人数 1明经币 +1 金钱 +50 收起 理由
lucas_3333 + 1 + 50 E大,谢谢! Awesome work!
    共1人打赏
发表于 2014-6-5 08:01:27 | 显示全部楼层
一大早就看到了好东西,谢谢楼主了!
发表于 2014-6-5 08:19:28 | 显示全部楼层
  1. (defun c:tt ()
  2.   (if (setq ss (ssget '((0 . "*line,arc,circle,ellipse"))))
  3.     (progn
  4.       (setq lst(xyp-ss2list ss)
  5.             lst1  (mapcar 'xyp-CurveLength lst)
  6.             lst2  (vl-remove-if '(lambda (x) (xyp-etype x "line")) lst)
  7.             lst2  (mapcar '(lambda (x) (vla-get-area (vlax-ename->vla-object x))) lst2)
  8.             text1 (strcat "总面积为: " (rtos (apply '+ lst2) 2 4))
  9.             text2 (strcat "总长度为: " (rtos (apply '+ lst1) 2 4))
  10.       )
  11.       (xyp-Put-Cliptext (strcat text1 "\n" text2))
  12.       (princ "\n")(princ text1)
  13.       (princ "\n")(princ text2)
  14.     )
  15.   )
  16.   (princ)
  17. )
edata + 1 很给力!
发表于 2014-6-5 09:26:22 | 显示全部楼层
D:\桌面\1111咋回事?
发表于 2014-6-5 10:19:01 | 显示全部楼层
正在学习DCL,参考学习的好东东。感谢楼主无私奉献,
 楼主| 发表于 2014-6-5 14:25:01 | 显示全部楼层
xiaobaixiaobu 发表于 2014-6-5 09:26
咋回事?
应该是原来剪贴板的文本超出DCL处理范围。
可以忽略。
发表于 2018-1-12 11:08:02 | 显示全部楼层
请问E大,我想把默认改为毫米,要改哪个呢?谢谢
 楼主| 发表于 2018-1-12 11:28:37 | 显示全部楼层
  3.     (progn
  4.       (vl-load-com)
  7.       (repeat l
  12.     )
  16.     )
  17.   (setq i (1+ i))
  18.   )
  22.     )
  23.   )
  24.   (princ)
  25. )
  30.     )
  31.   )
  33.   (setq j 0 d 0)
  36.     (setq j (1+ j))
  37.   )
  38.   d
  39. )
  43.     (progn
  46.   (foreach s '(
  51. "        height = 6 ;"
  53. "        width = 70 ;"
  54. "        :column {"
  57. "                    width = 50 ;"
  58. "            :row {"
  60. "                    width = 35 ;"
  62. "                :edit_box {"
  66. "                    width = 20 ;"
  67. "                }"
  68. "                :radio_row {"
  71. "                    width = 16 ;"
  74. "         key = \"sk_radio1\" ;"
  75. "                    fixed_width = true ;"
  76. "                    width = 8 ;"
  77. "                    }"
  78. "    spacer;"
  79. "    spacer;"
  80. "                    :radio_button {"
  81. "                        label = \"毫米\" ;"
  82. "         value = \"1\" ;"
  85. "                    width = 8 ;"
  86. "                    }"
  87. "                }"
  88. "    spacer;"
  89. "    spacer;"
  90. "    spacer;"
  95. "                    width = 20 ;"
  96.        "}"
  97. "                :button {"
  101. "                    width = 4 ;"
  102. "                }"
  103. "            }"
  104. "            :row {"
  106. "                :edit_box {"
  111. "                }"
  120. "                    fixed_width = true ;"
  121. "                    width = 8 ;"
  122. "                    }"
  123. "                    :radio_button {"
  124. "                        label = \"平方毫米\" ;"
  125. "         key = \"sk_radio4\" ;"
  126. "         value = \"1\" ;"
  128. "                    width = 8 ;"
  129. "                    }"
  130. "                }"
  136.        "}"
  137. "                :button {"
  141. "                    width = 4 ;"
  142. "                }"
  143. "            }"
  144. "        }"
  148. "         :toggle {"
  152. "}"
  153. "            :edit_box {"
  158. "            }"
  159. "    spacer;"
  160. "    spacer;"
  161. "    spacer;"
  162. "        }"
  163. "    spacer;"
  164. "    }"
  165. "    spacer;"
  166. "    ok_only;"
  167. "}"
  168.   )
  170.   (close f)
  174.     (progn
  179.         )
  182.         )
  186.         )
  190.         (end_list)
  191.         )
  217.       ")
  219.   ))
  221.       )
  222.     )
  224.   (princ)
  225.   )
发表于 2018-1-12 11:30:48 | 显示全部楼层
发表于 2018-1-14 13:49:44 | 显示全部楼层
能改为这样的对话框吗?
GMT+8, 2025-9-17 06:51 , Processed in 0.220092 second(s), 29 queries , Gzip On.
