查看: 1202|回复: 1
[提问] 各位高手看看怎么复制不了
发表于 2014-6-5 21:55:39 | 显示全部楼层 |阅读模式
(defun c:fv(/ mydoc myhndl myobj llpoint urpoint);提取容方框的角点
  (vl-load-com)
  (setq mydoc(vla-get-activedocument (vlax-get-acad-object)))
  (SETQ BLKEN (car (entsel "\n选择图框:")))
  (setq myhndl(cdr (assoc 5(entget BLKEN))))
  (setq blkobj (vlax-ename->vla-object BLKEN));;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(setq blkn (vla-get-name blkobj))
(setq xvar (vla-GetAttributes blkobj))
(setq svar (vlax-variant-value xvar))
(setq PX (vla-get-XScaleFactor blkobj));X比例
(setq PY (vla-get-YScaleFactor blkobj));y比例
(setq PZ (vla-get-ZScaleFactor blkobj));z比例
(SETQ BL(* PY 1000))
(SETQ CAR40 (* 3 PY))
     (IF (= PY PX)
    (SETQ BL (* PY 1000)))
      (setq BLQ1 (strcase "1:"))
    (SETQ BLQ2 (RTOS BL 2 0))
    (setq BLQ (strcat BLQ1 BLQ2))
(setq att_obj_list (vlax-safearray->list svar))
(foreach obj att_obj_list
(setq tag (vla-get-tagstring obj))
(setq val (vla-get-textstring obj))
(setq str1 (strcat tag "\t" val))
  (if (= tag "证件类型" ) (setq aa1 val))
  (if (= tag "登记字号" ) (setq aa2 val))
  (if (= tag "证载占地面积" ) (setq aa3 val))
  (if (= tag "证载建筑面积" ) (setq aa4 val))
  (if (= tag "证层数" ) (setq aa5 val))
  (if (= tag "证结构" ) (setq aa6 val))
  (if (= tag "坐落地址" ) (setq aa7 val))
  (if (= tag  "备注") (setq  aa8 val))
(setq att_tab_list (cons str1 att_tab_list))
(setq myobj(vla-handletoobject mydoc myhndl))
  (setq err(vl-catch-all-apply 'vla-GetBoundingBox (list myobj 'llpoint 'urpoint)))
  ;(if (vl-catch-all-error-p err)
   ; (princ "\n不能为所选图元建立包容方框,程序退出!")
  ; ; (progn
; (setq p1(vlax-safearray->list llpoint));提取minpoint坐标
  ;(setq p2(vlax-safearray->list urpoint));提取minpoint坐标
  ;(COMMAND "ZOOM" "W" P1 P2);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;生成完毕后在正中显示
;(princ val )
   (dfggg)
  ;(princ "\n已完成!请检查!")
  ;(prin1)
(defun dfggg();块属性数据修改
  (vl-load-com)
  (SETQ ENK NIL)
  (SETQ ENK (car (entsel "\n选择要修改的附图图框:")))
(setq Block_obj (vlax-ename->vla-object ENK))
(setq blkn (vla-get-name Block_OBJ))
(setq New_BXVAR (vla-GetAttributes Block_OBJ))
(setq Block_svar (vlax-variant-value New_BXVAR))
(setq Block_obj_list (vlax-safearray->list Block_svar))
(foreach Block_obj Block_obj_list
(setq tag (vla-get-tagstring Block_obj))
(setq va2 (vla-get-textstring Block_obj))
(setq Block_str (strcat tag "\t" val))
(setq Block_tab_list (cons Block_str Block_tab_list))
(setq att_data_list(cons (list tag val) att_data_list))
  (SETQ New_tag1 "证件类型")
  (setq bb1 aa1)
(if (= (vla-get-tagstring Block_obj) New_tag1)
(vla-put-textstring Block_obj bb1)
     (SETQ New_tag1 "登记字号")
  (setq bb2 aa2)
(vla-put-textstring Block_obj bb2)
   (SETQ New_tag1 "证载占地面积")
  (setq bb3 aa3)
(vla-put-textstring Block_obj bb3)
  (SETQ New_tag1 "证载建筑面积")
  (setq bb4 aa4)
(vla-put-textstring Block_obj bb4)
    (SETQ New_tag1 "证层数")
(setq bb5 aa5)
(vla-put-textstring Block_obj bb5)
   (SETQ New_tag1 "证结构")
(setq bb6 aa6)
(vla-put-textstring Block_obj bb6)
  (SETQ New_tag1 "坐落地址")
  (setq bb7 aa7)
(vla-put-textstring Block_obj bb7)
    (SETQ New_tag1 "备注")
(setq bb8 aa8)
(vla-put-textstring Block_obj bb8)
发表于 2014-6-6 11:06:44 | 显示全部楼层
这样提问
会有人来解答么
我很怀疑
GMT+8, 2025-8-26 04:14 , Processed in 0.143049 second(s), 27 queries , Gzip On.
