查看: 1532|回复: 3
[提问] 求助:如何得出多义线直线两端点?
发表于 2014-6-7 17:29:52 | 显示全部楼层 |阅读模式
(setq pt3 (osnap pt2 "midp"))这个是得出中点
如何得出多义线直线两端点?
  1. (DEFUN C:tt()
  2. (setq nm 0)
  3.          (while   (setq test t)
  4.            (while test
  5.                   (setq ss (entsel "\n请点选矩形:"))
  6.                   (setq test (not ss))
  7.            )
  8. (setvar "cmdecho" 0)
  9. (command "LAYER" "S" (cdr (assoc 8 (entget (car ss)))) "" )
  10. (setq obj (vlax-ename->vla-object (car ss)))
  11. (setq PT2 (vlax-curve-getclosestpointto obj (cadr ss)))
  12. (setq pt3 (osnap pt2 "midp"))
  13. (vla-getboundingbox obj 'minpoint 'maxpoint )
  14. (setq maxpoint (vlax-safearray->list maxpoint)
  15. minpoint (vlax-safearray->list minpoint)
  16. maxpoint (trans maxpoint 0 1)
  17. minpoint (trans minpoint 0 1)
  18. dx (/ (- (car maxpoint) (car minpoint)) 2.0)
  19. dy (/ (- (cadr maxpoint) (cadr minpoint)) 2.0)
  20. mpt1 (list (+ (car minpoint) dx) (+ (cadr minpoint) dy)))
发表于 2014-6-7 19:31:37 | 显示全部楼层
(while (not (setq ss (entsel "\n请点选矩形:"))))
偏方:
(setq pta (osnap pt2 "end"))
(setq ptb (mapcar '+ pt3 (mapcar '- pt3 pta)))
请参考 vlax-curve-get*** 函数
发表于 2014-6-7 20:22:00 | 显示全部楼层
(setq pra (vlax-curve-getParamatpoint e (vlax-curve-getClosestPointTo e (trans pt 1 0))))
(setq pt1 (trans (vlax-curve-getPointAtParam e (fix pra)) 0 1))
(setq pt2   (trans (vlax-curve-getPointAtParam e (1+ (fix pra))) 0 1))
pt,pt1,pt2均为UCS坐标
 楼主| 发表于 2014-6-9 08:42:59 | 显示全部楼层
谢谢,非常好.
GMT+8, 2025-8-26 04:13 , Processed in 0.203250 second(s), 29 queries , Gzip On.
