- 积分
- 333
- 明经币
- 个
- 注册时间
- 2014-4-13
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
我想用下面这段程序画出上面的图形,可得出的确实下面的图形,想请各位看看是什么原因,还有图中那个角度标注始终表不出来,能否也帮忙看看,谢谢各位了
(defun dcx1()
(command "limits" '(list -100 -100 ) '(list 900 1200))
(command "zoom" "a")
(command "osnap" "off" "") ;关闭目标捕捉
(command "ortho" "off" "") ;关闭捕捉命令
(command "layer" "n" "centerl,cusolidl,xsolidl,cusolidlcx, bhatchl,dividel,demension"
"c" 1 "centerl" "L" "center" "centerl" "lw" 0.15 "centerl"
"c" 3 "cusolidl" "L" "continuous" "cusolidl" "lw" 0.30 "cusolidl"
"c" 2 "cusolidlcx" "L" "continuous" "cusolidl" "lw" 0.30 " cusolidlcx"
"c" 5 "xsolidl" "L" "continuous" "xsolidl" "lw" 0.15 "xsolidl"
"c" 4 "bhatchl" "L" "continuous" "bhatchl" "lw" 0.15 "bhatchl"
"c" 2 "dividel" "L" "divide" "dividel" "lw" 0.15 "dividel"
"c" 6 "demension" "L" "continuous" "demension" "lw" 0.15 "demension" "")
(command "ltscale" 5 "centerl")
(command "ltscale" 5 "dividel")
(setq ptc1 (list 100 235)
ptc2 (list 265 235)
ptc3 (list 265 310)
ptc4 (list 265 160)
(command "line" ptc1 (polar ptc2 0 32) "") ; 水平中心线
(command "line" ptc3 ptc4 "") ; 垂直中心线
(setq h0 10
zk 14
H 16.75
da0 110
ak 35.0 ;槽型角
K 4.5
K1 7
r 1.5 ;槽底圆角半径
m 8
(setq dp0 ptc2)
(setq ac (/ (* 2.0 pi) zk)
ak (/ (* ak pi) 180.0)
dp1 (polar dp0 (* 0.5 pi) (* 0.5 da0))
dp2 (polar dp1 (* 1.5 pi) h0)
dp3 (polar dp0 (+ (* 0.5 pi) ac) (- (* 0.5 da0) K))
dp4 (polar dp0 (+ (* 0.5 pi) ac) (- (* 0.5 da0) K h0))
dp5 (polar dp0 (+ (* 0.5 pi) ac) (* 0.5 da0))
dp6 (polar dp0 (+ (* 0.5 pi) ac) (- (* 0.5 da0) (- H r) (* r (/ (cos (* 0.5 ak)) (sin (* 0.5 ak))))))
dp7 (polar dp6 (- (+ (* 0.5 pi) ac) ak) (* 0.5 da0))
dis (if (> m 4)
(* 0.333 (- (car dp6) (car dp0)))
(* 0.50 (- (car dp6) (car dp0)))
dp8 (list (- (car dp6) dis) (cadr dp6))
dp9 (polar dp8 (- (+ (* 0.5 pi) ac) ak) (* 0.5 da0))
dp10 (polar dp0 (+ (* 0.5 pi) (* 3 ac)) (* 0.5 da0))
dp11 (polar dp0 (- (* 0.5 pi) ac ac) (* 0.5 da0))
(setq dp12 (polar dp0 (* 0.5 pi) (+ (* 0.5 da0) (* 0.5 (- K1 K))))
dp13 (polar dp12 (* 1.5 pi) K1)
dp14 (polar dp13 (* 0.5 pi) (* 0.5 (- K1 K)) )
dp15 (polar dp14 (* 0.5 pi) K )
dp16 (polar dp0 (- (* 0.5 pi) ac) (+ (* 0.5 da0)(* 0.5 (- K1 K))))
dp17 (polar dp0 (- (* 0.5 pi) ac) (* 0.5 da0))
(command "layer" "s" "cusolidl" "")
(command "arc" dp1 "e" dp3 "r" (* 0.5 da0) "")
(setq ob1 (entlast))
(command "arc" dp2 "e" dp4 "r" (* 0.5 da0) "")
(command "line" dp6 dp7 "")
(command "line" dp8 dp9 "")
(command "trim" dp7 "" dp4 dp3 "")
(command "line" dp0 dp5 "")
(command "fillet" "r" r "fillet" dp5 dp7 "")
(setq cc4 (entlast))
(command "trim" dp1 "" dp7 dp9 "")
(command "trim" dp2 "" dp8"")
(setq ob3 (ssget "w" (list (car dp5) (cadr dp0)) (polar dp1 (* 0.25 pi) 2)))
(command "array" "w" (polar dp1 (* 0.25 pi) 2) (list (car dp5) (cadr dp0)) "" "p" dp0 5 (/ (* 4 ac 180) pi) "")
(setq ro1 (list (- (car dp0) (* 0.6 da0)) (+ (cadr dp0) (* 0.6 da0)))
ro2 (list (+ (car dp0) (* 0.6 da0)) (- (cadr dp0) (* 0.6 da0)))
(command "rotate" "w" ro1 ro2 "" dp0 (- 0(/ (* 1 ac 180) pi)))
(command "arc" "c" dp0 dp10 dp11 "")
(command "layer" "s" "demension" "")
(command "line" dp16 dp17 "")
(command "arc" dp17 "e" dp15 "r" (* 0.5 da0) "")
(command "arc" dp16 "e" dp12 "r" (* 0.5 da0) "")
(command "arc" dp17 "e" dp14 "r" (* 0.5 da0) "")
(dim-v dp13 dp12 (- 0 (* 0.4 da0)) "")
(dim-v dp14 dp15 (- 0 (* 0.3 da0)) "")
(setq ppH (polar dp1 (* 1.5 pi) H) )
(dim-v ppH dp1 (- 0 (* 0.5 da0))"")
(command "dimradius" (list cc4 (polar dp0 0 8)) (polar dp0 (* 0.25 pi) (* 0.35 da0)))
(setq wp0 (polar dp0 (* 0.5 pi) (* 0.6 da0)))
(command "line" dp1 wp0 "")
