查看: 2834|回复: 9
[提问] 求一个“块添加实体”和“块移出实体”的程序
发表于 2014-6-24 13:45:10 | 显示全部楼层 |阅读模式
1明经币
求一个块添加实体和快删除实体的工具
要求
1、块添加实体:先选择源块,再选择要添加的图元。
2、块移出实体:直接点选要从图块中移出的实体,执行完后被删除的实体仍然保留在图中而不在块中。
Lee-mac的大作不是太好用,求各位大神各显神通哦
发表于 2014-6-24 14:06:18 | 显示全部楼层
发表于 2014-6-24 16:08:16 | 显示全部楼层
(defun c:c2x ( / *error* acd app dbx def doc dwg dwl ent enx err inc lst mat obj sel vrs xrl )
    (defun *error* ( msg )
        (if (and (= 'vla-object (type dbx)) (not (vlax-object-released-p dbx)))
            (vlax-release-object dbx)
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
    (while (setq def (tblnext "block" (null def)))
        (if (= 4 (logand 4 (cdr (assoc 70 def))))
            (setq xrl (vl-list* "," (cdr (assoc 2 def)) xrl))
    (cond
        (   (= 1 (getvar 'xloadctl))
            (princ "\nXLOADCTL system variable is set to 1, xref source drawings are locked.")
        (   (not
                (and
                    (setq sel
                        (LM:ssget "\nSelect objects to copy to xref: "
                            (list "_:L"
                                (list
                                   '(0 . "~VIEWPORT")
                                   '(-4 . "<NOT")
                                       '(-4 . "<AND")
                                           '(0 . "INSERT") (cons 2 (apply 'strcat (cdr xrl)))
                                       '(-4 . "AND>")
                                   '(-4 . "NOT>")
                                    (if (= 1 (getvar 'cvport))
                                        (cons 410 (getvar 'ctab))
                                       '(410 . "Model")
                        (while
                            (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect xref: ")))
                                (cond
                                    (   (= 7 (getvar 'errno))
                                        (princ "\nMissed, try again.")
                                    (   (= 'ename (type ent))
                                        (if (or (/= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
                                                (not (member (cdr (assoc 2 enx)) xrl))
                                            (princ "\nSelected object is not an xref.")
                        ent
        (   (progn
               (setq dbx
                   (vl-catch-all-apply 'vla-getinterfaceobject
                       (list (setq app (vlax-get-acad-object))
                           (if (< (setq vrs (atoi (getvar 'acadver))) 16)
                               "objectdbx.axdbdocument" (strcat "objectdbx.axdbdocument." (itoa vrs))
               (or (null dbx) (vl-catch-all-error-p dbx))
            (prompt "\nUnable to interface with ObjectDBX.")
        (   (not
                (and
                    (setq dwg (cdr (assoc 1 (tblsearch "block" (cdr (assoc 2 enx))))))
                    (setq dwg (findfile dwg))
            (prompt "\nUnable to locate xref source drawing.")
        (   (progn
                (vlax-for doc (vla-get-documents app)
                    (setq dwl (cons (cons (strcase (vla-get-fullname doc)) doc) dwl))
                (not
                    (or (setq doc (cdr (assoc (strcase dwg) dwl)))
                        (and (not (vl-catch-all-error-p (setq err (vl-catch-all-apply 'vla-open (list dbx dwg)))))
                             (setq doc dbx)
            (prompt (strcat "\nUnable to interface with xref source drawing:\n" (vl-catch-all-error-message err)))
        (   (setq mat (revrefgeom ent)
                  mat (vlax-tmatrix (append (mapcar 'append (car mat) (mapcar 'list (cadr mat))) '((0.0 0.0 0.0 1.0))))
                  acd (vla-get-activedocument app)
            (repeat (setq inc (sslength sel))
                (setq obj (vlax-ename->vla-object (ssname sel (setq inc (1- inc))))
                      lst (cons obj lst)
                (vla-transformby obj mat)
            (vlax-invoke acd 'copyobjects lst (vla-get-modelspace doc))
            (vla-saveas doc dwg)
            (vla-reload (vla-item (vla-get-blocks acd) (cdr (assoc 2 enx))))
            (foreach obj lst (vla-delete obj)) ;; Comment this line to retain original objects
(defun LM:ssget ( msg params / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget params))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
(defun revrefgeom ( ent / ang enx mat ocs )
          ang (cdr (assoc 050 enx))
          ocs (cdr (assoc 210 enx))
    (list
        (setq mat
            (mxm
                (list
                    (list (/ 1.0 (cdr (assoc 41 enx))) 0.0 0.0)
                    (list 0.0 (/ 1.0 (cdr (assoc 42 enx))) 0.0)
                    (list 0.0 0.0 (/ 1.0 (cdr (assoc 43 enx))))
                (mxm
                    (list
                        (list (cos ang)     (sin ang) 0.0)
                        (list (- (sin ang)) (cos ang) 0.0)
                       '(0.0 0.0 1.0)
                    (mapcar '(lambda ( v ) (trans v ocs 0 t))
                             (1.0 0.0 0.0)
                             (0.0 1.0 0.0)
                             (0.0 0.0 1.0)
        (mapcar '- (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx)))))
            (mxv mat (trans (cdr (assoc 10 enx)) ocs 0))
(defun trp ( m )
    (apply 'mapcar (cons 'list m))
(defun mxm ( m n )
    ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
(vl-load-com)
(princ
    (strcat
        "\n:: Version 1.2 | \\U+00A9  "
        (menucmd "m=$(edtime,0,yyyy)")
        " XXXXXXX::"
        "\n:: Type \"c2x\" to Invoke ::"
发表于 2014-6-24 16:53:01 | 显示全部楼层
LeeMac的为什么不好用?
另外请编辑标题,【Gu_xl】前缀是G版的专属标记,
确实有点问题,加入的对象没有夹点  发表于 2014-10-16 15:07
发表于 2014-6-24 21:26:07 | 显示全部楼层
我还以为G版又出大作了
发表于 2014-6-24 21:47:52 | 显示全部楼层
有大师的作品,能够吸收消化为己所用才是学习之道!
发表于 2014-6-25 12:39:13 | 显示全部楼层
这个比较有用 帮你顶起来
 楼主| 发表于 2014-10-16 14:30:39 | 显示全部楼层
xyp1964 发表于 2014-6-24 14:06
一直在秀,从不共享
属于e派工具箱内置功能!  发表于 2014-10-18 11:37
发表于 2014-10-17 12:47:20 | 显示全部楼层
探索者2011版本自带就有这个程序的
发表于 2014-10-17 12:59:01 | 显示全部楼层
微笑忘记过去 发表于 2014-10-16 14:30
一直在秀,从不共享
饿着肚子看别人吃火锅,那心情~~~~
GMT+8, 2025-5-24 01:25 , Processed in 0.176192 second(s), 27 queries , Gzip On.
