查看: 1382|回复: 3
[源码] 求助,哪位大大帮着改一改
发表于 2014-7-2 10:51:20 | 显示全部楼层 |阅读模式
主要功能是,在输入一条直线厚,自动偏移指定的距离,并归入各自图层,下面是源码,在执行完直线后,在下面就不执行了,哪位大大帮着改一改,谢谢了
  1. (defun c:bs2 (/ oldlayer dis o)
  2.   (prompt "***输入单线变管***")
  3.   (command "undo" "be")
  4.   (setq oldlayer (getvar "CLAYER"))
  5.   (setvar "cmdecho" 0)
  6.   (command "-layer" "M" "管径" "" "Color" 2 "" "l" "continous" "" "")
  7.   (command "-layer" "M" "管中心线" "" "Color" 2 "" "l" "dash" "" "")
  8. (command "line"  (getpoint "\n第一点:") (getpoint "\n第二点:") "")
  9. (setq ss (entlast))
  10. (command "offset" ss (/ dis 2) o '(-9999999 -9999999) "")
  11.     (command "change" (ssget "l") "" "p" "la" "管径" "")
  12.     (command "offset" ss (/ dis 2) o '(9999999 9999999) "")
  13.     (command "change" (ssget "l") "" "p" "la" "管径" "")
  14. (setvar "CLAYER" oldlayer)
  15.   (command "undo" "e")
  16. )
不知道 undo命令 加的对不对?
发表于 2014-7-2 10:57:02 | 显示全部楼层
先查 dis 的值
发表于 2014-7-2 11:51:16 | 显示全部楼层
offset句中的“o”是什么?
发表于 2014-7-9 12:47:33 | 显示全部楼层
还是用Mline直接画吧,不用编程了。
GMT+8, 2025-5-24 09:44 , Processed in 0.167173 second(s), 25 queries , Gzip On.
