查看: 1555|回复: 5
[已解答] 请问一下这个循环怎么用右键退出
发表于 2014-7-8 15:07:04 | 显示全部楼层 |阅读模式
(defun C:t00 ()
(while t
  (command "dimdiameter")
  (while (/= (getvar "CMDACTIVE") 0) (command PAUSE))
发表于 2014-7-8 15:11:44 | 显示全部楼层
当while后面为nil时就退出了,你写成T当然不退出了
 楼主| 发表于 2014-7-8 15:38:43 | 显示全部楼层
当while后面为nil时就直接退出了,一次都不执行了。我想可以重复标注圆,也就是下面程序的效果
(defun c:33 ()
(setq clay (getvar "clayer"))
(command "Layer" "s" "03-标注层" "")
(while (setq p(entsel "\n指定新的标注:"))
(command"dimdiameter")(getvar"cmdactive")(command p)
    (while(/=(getvar"cmdactive")0)(command pause))
(command "Layer" "s" clay "")
所以,while后跟变量  发表于 2014-7-8 15:44
 楼主| 发表于 2014-7-8 15:52:47 | 显示全部楼层
(defun C:t00 ()
(setq        ent (entlast)
        key t
(while key
  ;(while (/= (getvar "CMDACTIVE") 0) (command PAUSE))
那么变量如何判断鼠标右键?
发表于 2014-7-8 22:10:32 | 显示全部楼层
为什么要用entlast?
如果使用
(while (setq ent(entsel))
(commmand……
)怎样?
发表于 2014-7-9 08:18:33 | 显示全部楼层
  1. (defun c:tt ()
  2. (setvar "CMDECHO" 0)
  3. (while (and (setq s1 (entsel "\n选择圆: "))
  4.                     (wcmatch (cdr(assoc 0 (entget(car s1)))) "ARC,CIRCLE"))
  5.   (command "_.DIMDIAMETER" s1)
  6.   (while (> (getvar "CMDACTIVE") 0) (command PAUSE))
  7. )
  8. (princ)
  9. )
GMT+8, 2025-5-24 07:22 , Processed in 0.185047 second(s), 27 queries , Gzip On.
