查看: 2519|回复: 7
[源码] 坐标网格程序,还没有调试完毕,欢迎大家一起来打酱油~~~
发表于 2014-7-9 18:04:06 | 显示全部楼层 |阅读模式
  1. (defun makeline (p1 p2)
  2.   (entmakex (list '(0 . "line") (cons 10 p1) (cons 11 p2)))
  3. )
  4. (defun maketext (str pt ang h)
  5.   (entmakex
  6.     (list '(0 . "text") (cons 1 str) (cons 10 pt) (cons 50 ang) (cons 40 h))
  7.   )
  8. )
  9. (defun c:zbwg ()
  10.   (setq os (getvar "osmode"))
  11.   (setq P1 (getpoint "输入左下角坐标:")
  12.         P2 (getcorner P1 "\n输入右上角坐标:")
  13.         BL (getint "输入间隔距离<50>:")
  14.         )
  15. (if (not bl) (setq bl 50))
  16. (setq len-x (- (car p2) (car p1))
  17.        len-y (- (cadr p2) (cadr p1))
  18.        remx (rem (car p1) bl)
  19.        remy (rem (cadr p1) bl)
  20.        xwgs (fix (/ len-x bl))
  21.        ywgs (fix (/ len-y bl))
  22.        i 1
  23.        ii 1
  24.        zg (* bl 0.1)
  25.        )
  26.   (setvar "osmode" 0)
  27.   (repeat xwgs
  28.     (setq pt1 (polar p1 0 (- (* bl i) remx))
  29.           pt2 (polar pt1 (* pi 0.5) len-y))
  30.     (makeline pt1 pt2)
  31.     (setq str (strcat "X=" (rtos (car pt1) 2 0)))
  32.     (setq str-pt1 (polar pt1 pi zg)
  33.           str-pt2 (polar pt2 pi zg)
  34.           str-pt2 (polar str-pt2 (* pi 1.5) (* (strlen str) zg))
  35.           )
  36.     (maketext str str-pt1 (* pi 0.5) zg)
  37.     (maketext str str-pt2 (* pi 0.5) zg)
  38.     (setq i (1+ i))
  39.   )
  40.   (repeat ywgs
  41.     (setq pt1 (polar p1 (* pi 0.5) (- (* bl ii) remy))
  42.           pt2 (polar pt1 0 len-x))
  43.     (makeline pt1 pt2)
  44.     (setq str (strcat "Y=" (rtos (cadr pt1) 2 0)))
  45.     (setq str-pt1 (polar pt1 (* pi 0.5) zg)
  46.           str-pt2 (polar pt2 (* pi 0.5) zg)
  47.           str-pt2 (polar str-pt2 pi (* (strlen str) zg))
  48.           )
  49.     (maketext str str-pt1 0 zg)
  50.     (maketext str str-pt2 0 zg)
  51.     (setq ii (1+ ii))
  52.   )
  53.   (setvar "osmode" os)
  54.   (princ)
  55. )
发表于 2014-7-9 19:27:15 | 显示全部楼层
打酱油的路过……
发表于 2014-7-10 08:41:05 | 显示全部楼层
 楼主| 发表于 2014-7-10 09:46:18 | 显示全部楼层
xyp1964 发表于 2014-7-10 08:41
院长,帮我改一下呗.
1.程序开始,保存所有系统变量到C:\\ACADVAR.TXT,程序结束,读取C:\\ACADVAR.TXT恢复变量
2.求个函数,判断图层是否存在,若不存在添加图层(MKlay 图层名 颜色 线型)
发表于 2014-7-10 13:10:02 | 显示全部楼层
RE: 坐标网格程序,还没有调试完毕,欢迎大家一起来打酱油~~~
77077 发表于 2014-7-14 04:46
院长,帮我改一下呗.
2.求个函数,判断图层是否存在,若不存在添加图层(MKlay 图层名 颜色 线型) ...
(setq lay (tblsearch "layer" "多边形编号"))
    (if (= lay nil)
        (command "layer" "n" "多边形编号" "c" "4" "多边形编号" "")
发表于 2015-1-9 21:16:38 | 显示全部楼层
真牛逼,很需要哈。
GMT+8, 2025-6-3 11:54 , Processed in 0.204722 second(s), 31 queries , Gzip On.
