- *fr:dialog{
- label="《開金工具箱》--(查找/替换)文字功能(适用于text、mtext)";
- spacer;
- :column{
- :boxed_row{
- :text_part{
- label="查找文字:";
- key="cz";
- :edit_box{
- key="text_find";
- edit_limit=80;
- edit_width=65;
- value="";
- :boxed_row{
- :text_part{
- label="替换为:";
- key="th";
- :edit_box{
- key="text_replace";
- edit_limit=80;
- edit_width=65;
- value="";
- spacer;
- :boxed_row{
- :button{
- label="查找";
- key="select";
- :boxed_row{
- :text_part{
- label="-->共找到()组字符";
- key="t3";
- :button{
- label="缩放为(ZOOM)-->";
- key="selecta";
- :boxed_row{
- :button{
- label="修改";
- key="selectb";
- :button{
- label="全部修改";
- key="selectc";
- initial_focus=text_find;
- spacer;
- ok_cancel;
注:程序点击缩放时,点一次自动缩放下一个字符.谢谢 |
