查看: 1447|回复: 4
[提问] 何让两句COMMANF"Pline"画的线和箭头成一个整体
发表于 2014-7-13 13:18:02 | 显示全部楼层 |阅读模式
(command "Pline" pt1 "W" "0" "0" pt2 "")
                   (command "")
                   (setq pt1 pt2
                         i   (1+ i)
               (setq pt3 (polar pt1 ku 300))
               (command "Pline" pt1 "W" "60" "0" pt3 "")
如何让两句COMMANF"Pline"画的线和箭头成一个整体,而不是一段段分开的线
发表于 2014-7-13 16:21:30 | 显示全部楼层
  1. ;; (aaa (setq p1 (getpoint  "\n基点<退出>: "))(setq p2 (getpoint p1  "\n基点<退出>: ")))
  2. (defun aaa (pt1 pt2 / pt3)
  3.   (setq pt3 (polar pt2 (angle pt1 pt2) 300))
  4.   (command "Pline" "non" pt1 "W" "0" "0" "non" pt2 "W" "60" "0"  "non" pt3 "")
  5. )
发表于 2014-7-13 14:00:26 | 显示全部楼层
(command "line" pt1 "W" "0" "0" pt2  "W" "60" "0" (polar pt1 ku 300) "")
但不知是否背离楼主本意
 楼主| 发表于 2014-7-13 14:05:27 | 显示全部楼层
(setq pt1 pt2
                         i   (1+ i)
                   )这个不要了?
 楼主| 发表于 2014-7-13 15:58:19 | 显示全部楼层
直接一个pline画,箭头会出现在每一个pt1点上,我想要的是只在最后的点上出现箭头
GMT+8, 2025-5-24 11:50 , Processed in 0.186147 second(s), 31 queries , Gzip On.
