查看: 915|回复: 0
[提问] 各位大大v帮我看看 为什么重启CAD自定义命令失效
发表于 2014-7-18 15:03:02 | 显示全部楼层 |阅读模式
在明经上下载的别人的
各位大大 版主  高手  帮我看看 为什么重启CAD自定义命令失效
哪个地方有问题???
  1. (princ "\n启动命令:test")
  2. (defun c:test ()
  3.   (setvar "cmdecho" 0)
  4.   (vl-load-com)
  5.   (setq dcl_id (load_dialog "Test.dcl"))
  6.   (new_dialog "userset" dcl_id)
  7.   (read_from_registry)
  8.   (write_to_wdy)
  9.   (action_tile "onekeyset" "(onekeyset)")
  10.   (action_tile "purgeall" "(purgeall)")
  11.   (action_tile "ok" "(read_from_wdy) (done_dialog 1001)")
  12.   (setq dd (start_dialog))
  13.   (if (= dd 1001)
  14.       (progn
  15.         (write_to_registry)
  16.         (alert "★提示:\n自定义快捷命令已设置成功!\n重新打开AutoCAD后,自定义快捷命令才会全部生效!")
  17.         (wdy_qidong)
  18.       )
  19.   )
  20. )
  21. ;;;*****自定义快捷命令 程序********
  22. (defun onekeyset ()  ;一键设置
  23.   (purgeall)
  24.   (set_tile "wdy501" "te1")
  25.   (set_tile "wdy502" "te2")
  26.   (set_tile "wdy503" "te3")
  27.   (set_tile "wdy504" "te4")
  28.   (set_tile "wdy505" "te5")
  29. )
  30. (defun purgeall () ;自定义快捷键全部清除
  31.   (set_tile "wdy501" "")
  32.   (set_tile "wdy502" "")
  33.   (set_tile "wdy503" "")
  34.   (set_tile "wdy504" "")
  35.   (set_tile "wdy505" "")
  36. )
  37. ;;;***读取注册表 程序开始***
  38. (defun read_from_registry ()
  39.   (setq rfreg_wdy501 (vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy501"))
  40.   (setq rfreg_wdy502 (vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy502"))
  41.   (setq rfreg_wdy503 (vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy503"))
  42.   (setq rfreg_wdy504 (vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy504"))
  43.   (setq rfreg_wdy505 (vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy505"))
  44. )
  45. ;;;***读取注册表 程序结束***
  46. ;;;*****写入WDY 程序开始*****
  47. (defun write_to_wdy ()
  48.   (if rfreg_wdy501 (set_tile "wdy501" rfreg_wdy501) (set_tile "wdy501" ""))
  49.   (if rfreg_wdy502 (set_tile "wdy502" rfreg_wdy502) (set_tile "wdy502" ""))
  50.   (if rfreg_wdy503 (set_tile "wdy503" rfreg_wdy503) (set_tile "wdy503" ""))
  51.   (if rfreg_wdy504 (set_tile "wdy504" rfreg_wdy504) (set_tile "wdy504" ""))
  52.   (if rfreg_wdy505 (set_tile "wdy505" rfreg_wdy505) (set_tile "wdy505" ""))
  53. )
  54. ;;;*****写入WDY 程序结束*****
  55. ;;;*****读取WDY 程序开始*****
  56. (defun read_from_wdy ()
  57.   (setq rfw_wdy501 (get_tile "wdy501"))
  58.   (setq rfw_wdy502 (get_tile "wdy502"))
  59.   (setq rfw_wdy503 (get_tile "wdy503"))
  60.   (setq rfw_wdy504 (get_tile "wdy504"))
  61.   (setq rfw_wdy505 (get_tile "wdy505"))
  62. )
  63. ;;;*****读取WDY 程序结束*****
  64. ;;;***写入注册表 程序开始
  65. (defun write_to_registry ()
  66. (vl-registry-write "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy501" rfw_wdy501)
  67. (vl-registry-write "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy502" rfw_wdy502)
  68. (vl-registry-write "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy503" rfw_wdy503)
  69. (vl-registry-write "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy504" rfw_wdy504)
  70. (vl-registry-write "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Hotkey" "wdy505" rfw_wdy505)
  71. )
  72. ;;;***写入注册表 程序结束
  73. ;;;***自定义命令 程序开始***
  74. (defun wdy_qidong ()
  75.   (read_from_registry)
  76.   (if rfreg_wdy501 (eval (read (strcat "(defun c:" rfreg_wdy501 "() (c:wdy_test1))"))))
  77.   (if rfreg_wdy502 (eval (read (strcat "(defun c:" rfreg_wdy502 "() (c:wdy_test2))"))))
  78.   (if rfreg_wdy503 (eval (read (strcat "(defun c:" rfreg_wdy503 "() (c:wdy_test3))"))))
  79.   (if rfreg_wdy504 (eval (read (strcat "(defun c:" rfreg_wdy504 "() (c:wdy_test4))"))))
  80.   (if rfreg_wdy505 (eval (read (strcat "(defun c:" rfreg_wdy505 "() (c:wdy_test5))"))))
  81. )
GMT+8, 2025-5-24 09:26 , Processed in 0.211816 second(s), 27 queries , Gzip On.
