查看: 1171|回复: 2
[提问] 怎么把一个图层里面的所有东西都移动到指定的图层呢?
发表于 2014-7-20 11:15:11 | 显示全部楼层 |阅读模式
(defun c:lpjzh() ;lpjzh=梁配筋转换
(setq hcl-lpj-h (ssget "x" (list (cons 8 "0"))));hcl-lpj-h=后处理-梁配筋-水平
(command "chprop" hcl-lpj-h "" "la" 0_MV "" "")
写到这里就写不下去了?
发表于 2014-7-20 11:23:53 | 显示全部楼层
search CHPROP...
发表于 2014-7-20 17:49:34 | 显示全部楼层
  1. (defun c:lpjzh ()                        ;lpjzh=梁配筋转换
  2.   (setq        hcl-lpj-h (ssget "x" (list (cons 8 "0")))
  3.         0_MV          "图层2"
  4.   )                                        ;hcl-lpj-h=后处理-梁配筋-水平
  5.   (command "chprop" hcl-lpj-h "" "la" 0_MV "")
  6.   (princ)
  7. )
GMT+8, 2025-5-24 07:34 , Processed in 0.166193 second(s), 25 queries , Gzip On.
