查看: 1669|回复: 2
[已解答] 请教怎么实现利用redraw或grvecs按要求闪烁显示绘制的图元
发表于 2014-7-21 11:27:05 | 显示全部楼层 |阅读模式
请教下各位,怎么实现redraw或grvecs绘制图元时能闪几下,闪动频率和次数希望能定制。
(defun c:gg()
        (setq pt1 (list 0 0 0))
        (setq pt2 (list 50 50 0))
        (setvar "dimzin" 1)
        (setq old_time (atoi (substr (rtos (getvar "cdate") 2 20) 10 8)))
        (while t
                (setq new_time (atoi (substr (rtos (getvar "cdate") 2 20) 10 8)))
                (setq pass_time (- new_time old_time))
                (cond
                ((> 200 pass_time 198)(grdraw pt1 pt2 2 1))
                ((> 400 pass_time 398)(redraw))
                ((> 600 pass_time 598)(grdraw pt1 pt2 2 1))
                ((> 800 pass_time 798)(redraw))
                ((> 1000 pass_time 998)(grdraw pt1 pt2 2 1))
                (t  nil)
        ;(redraw)
发表于 2014-7-21 13:01:45 | 显示全部楼层
看看这个行不行
(defun c:tt ()
  (setvar "cmdecho" 0)
  (setq na (car (entsel "\n选择:")))
  (glint na 3)
(defun glint (na i)
  (repeat i
    (command "delay" "200")
    (redraw na 2)
    (redraw)
    (command "delay" "100")
    (redraw na 1)
    (redraw)
 楼主| 发表于 2014-7-21 18:07:26 | 显示全部楼层
谢谢分享源码
GMT+8, 2025-5-24 07:19 , Processed in 0.174086 second(s), 27 queries , Gzip On.
